  3. Domoticz
  4. <SOLVED> What is wrong with my S_Wind V_Direction value? Never changes...
8 Posts 3 Posters 3.0k Views 3 Watching
  • edsteveE
    edsteveE
    edsteve
    wrote on last edited by edsteve
    I am using a "dummy-sketch" to keep it simple. The sketch sends and updates the data for windspeed and gust to the Domoticz controller whenever i change the values in the skript. But when i change the value for val_wdirection the wind direction never changes in Domoticz. How come?
    It seems there is something wrong with this part of the sketch, right?
        unsigned int val_wdirection = 15;
        if(last_wdirection != val_wdirection)
           last_wdirection = val_wdirection;
           send(msgWDirection.set(val_wdirection, 1));
           Serial.print("WD: ");
           Serial.println(val_wdirection);
    And this is the complete sketch:
    #define CHILD_ID_WIND 1
    unsigned int val_wspeed;
    unsigned int val_wgust;
    unsigned int val_wdirection;
    unsigned int last_wspeed;
    unsigned int last_wgust;
    unsigned int last_wdirection;
    MyMessage msgWSpeed(CHILD_ID_WIND, V_WIND);
    MyMessage msgWGust(CHILD_ID_WIND, V_GUST);
    MyMessage msgWDirection(CHILD_ID_WIND, V_DIRECTION);
        present(CHILD_ID_WIND, S_WIND);
    //  gw.process();
    //  currentTime = millis();
        unsigned int val_wspeed = 12;
        if(last_wspeed != val_wspeed)
           last_wspeed = val_wspeed;
           send(msgWSpeed.set(val_wspeed, 1));
           Serial.print("WS: ");
           Serial.println(val_wspeed);
        unsigned int val_wgust = 4;
        if(last_wgust != val_wgust)
           last_wgust = val_wgust;
           send(msgWGust.set(val_wgust, 1));
           Serial.print("WG: ");
           Serial.println(val_wgust);
    The wind direction always say 20NNE. Temp and Chill also says 20 degrees and i have no idea where the number 20 comes from.
    I drives me crazy. I don't know what to do :/
    mfalkviddM AWIA 2 Replies Last reply
    • edsteveE edsteve
      //  gw.process();
      The sketch looks ok to me.
      Could you post the serial debug output from the node with two different values?
      • edsteveE edsteve
        //  gw.process();
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        @edsteve Just a guess.. You seem to be sending an unsigned int (wind variables) as a float with one decimal with set(x, 1). It can very well be that this is not casted as expected.
        Try it with set(x)
        • edsteveE
          edsteveE
          edsteve
          Wow. I am happy to see answers :)
          @mfalkvidd
          Thats the serial log, which seems okay to me:
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSF:SID:OK,ID=1
          14 TSM:FPAR
          51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          69 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          73 TSF:MSG:FPAR OK,ID=0,D=1
          789 TSF:MSG:READ,3-3-1,s=255,c=3,t=8,pt=1,l=1,sg=0:1
          878 TSF:MSG:READ,8-8-1,s=255,c=3,t=8,pt=1,l=1,sg=0:1
          2058 TSM:FPAR:OK
          2059 TSM:ID
          2060 TSM:ID:OK
          2062 TSM:UPL
          2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2075 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2079 TSF:MSG:PONG RECV,HP=1
          2082 TSM:UPL:OK
          2084 TSM:READY:ID=1,PAR=0,DIS=1
          2088 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          2103 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
          2113 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          2125 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          2131 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=9,pt=0,l=0,sg=0,ft=0,st=OK:
          2138 MCO:REG:REQ
          2141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          2147 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          2152 MCO:PIM:NODE REG=1
          2154 MCO:BGN:INIT OK,TSP=1
          2159 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=8,pt=7,l=5,sg=0,ft=0,st=OK:12.0
          WS: 12
          2167 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=9,pt=7,l=5,sg=0,ft=0,st=OK:4.0
          WG: 4
          2176 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=10,pt=3,l=2,sg=0,ft=0,st=OK:15
          WD: 3
          @AWI
          I tried. Without success.
          Is there a clue why it is 20NNE? Also the temperature shows 20 in the picture from first post. Even though there is only the nrf24l01 connected. No sensor. Maybe the problem is related to this number. Just guessing also :)
          I used this arduino with a temp sensor before. Can that be conected? Hmm
          AWIA 1 Reply Last reply
          • edsteveE edsteve
            @mfalkvidd
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=1
            14 TSM:FPAR
            2058 TSM:FPAR:OK
            2059 TSM:ID
            2060 TSM:ID:OK
            2062 TSM:UPL
            2082 TSM:UPL:OK
            2138 MCO:REG:REQ
            WS: 12
            WG: 4
            WD: 3
            @AWI
            AWIA
            AWIA
            AWI
            @edsteve something strange in the last two lines of the serial dump. You can see the node sending 15 while the print shows 3...
            Domoticz also has some peculiarities. The 20 is probably default and and a full circle is 16 values ;)
            • edsteveE
              edsteveE
              edsteve
              My mistake. I actually edit it right after i posted. But i think you were faster than me :)
              Yeah. I read about the magic number 16. Thats why i test with 15 :D
              If i understand that right Domoticz goes from 0 to 16 instead of 0 to 360. So 15 should do fine.
              So now i am out of guesses and clues :/
              • edsteveE edsteve
                AWIA
                AWIA
                AWI
                @edsteve This is from a wind sensor which is reporting the right values. As you can see I send the (float) windDirection as (int)windDirection / 16 to Domoticz (destinationNode 0). If sent to another node I can just use the float value (in degrees).
                   	if (destinationNode == 0){			//send winddirection Deg/16 (for Domoticz)
                   		send(windDirectionMsg.setDestination(destinationNode).set((int)lastWindDirection/16));
                   	} else {
                   		send(windDirectionMsg.setDestination(destinationNode).set(lastWindDirection, 1));
                • edsteveE
                  edsteveE
                  edsteve
                  Thanks for still coping with me. Tried playing with your suggestions but no success as well.
                  But i found the problem.
                  SOLUTION:
                  I just gave the wind-sensor-node a different NODE_ID manually and now it updates the direction value.
                  Seems there was some problems with old data when i used this arduino as a temp sensor.
