  3. Mysensort mit DHT12 (i2C)
3 Posts 2 Posters 3.0k Views 2 Watching
  • michlb1982M
    michlb1982M
    michlb1982
    Hello
    Does anyone built up an Mysenors Humidity Node with an DHT12 it is an I2C sensor...
    but I2C is needet for the NRF24+ or?
    • michlb1982M michlb1982
      Hello
      @michlb1982 the nrf radio uses SPI, not I2C.
      I haven't seen anyone using the dht12, but there are examples that use other i2c sensors.
      https://www.mysensors.org/build/pressure
      https://www.mysensors.org/build/light-bh1750
      https://www.mysensors.org/build/rfid
      • michlb1982M
        michlb1982M
        michlb1982
        wrote on last edited by michlb1982
        Well i did it... i've got a working MYSENSOR with DHT12...
        here the Code ... its not nice but it works...
        // Enable debug prints
        // Define Node ID
        #define MY_NODE_ID 128
        //#define MY_REPEATER_FEATURE
        #include <DHT12.h>
        #include <Wire.h>
        DHT12 dht12;
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 30000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
          sendSketchInfo("DHT12", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          //metric = getControllerConfig().isMetric;
          Wire.begin();
          //dht12.readSensor(true);
          float temperature = dht12.readTemperature();
          if (isnan(temperature)) {
            lastTemp = temperature;
            // apply the offset before converting to something different than Celsius degrees
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            Serial.println(temperature);
          } else {
            nNoUpdatesTemp++;
          float humidity = dht12.readHumidity();
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
          } else {
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
          //wait(UPDATE_INTERVAL); //for repeaters
        i Used this library: https://github.com/Bobadas/DHT12_library_Arduino/blob/master/README.md
        here the datasheet of the dht12: http://www.robototehnika.ru/file/DHT12.pdf
