  3. Humidity/Temp Program, Serial Monitor Issues
3 Posts 2 Posters 1.8k Views 1 Watching
  • N
    N
    NotYetRated
    Created a device using the humidity sensor code (http://mysensors.org/build/humidity).
    All appears to be working fine(aside from some wacky temps off by about 10 degrees F), except when I go in to serial monitor to see the units output, all I get is the below gibberish.
    ’ý
    ˇPž+šŒ21’úÙUٝS,;›’j˜ôŽØ"éUٝS)$º«)µÎq¤ÛI¶RSs%[º»q1©qÂüÙ÷šeÎ|ÌÅÉûI.þÀ!S)Z<ŸÖT›}rùÿº»@ٝSr‰z ü›5}ráÿ™PµâÂêÙ$þp ü¦¬µqš\ÿº»DyÍSsµÿ«‚üšeÎ|‘º€ü
    Any ideas?
    • hariH
      hariH
      hari
      make sure to select he proper baud rate in the serial monitor.
      N 1 Reply Last reply
      • hariH hari
        N
        N
        NotYetRated
        @hari DOH, that was it. Thanks!
