  3. A lot of NACKs
A lot of NACKs
8 Posts 2 Posters 2.2k Views 2 Watching
  • mppM
    mppM
    mpp
    wrote on last edited by mpp
    The following code results in a st=NACK for send msg2 and msg3:
    send(msg1);
    send(msg2);
    send(msg3);
    This results in a st=OK for all
    send(msg1);
    wait(LONG_WAIT);
    send(msg2);
    wait(LONG_WAIT);
    send(msg3);
    A power issue perhaps?
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
    • mppM mpp
      send(msg1);
      send(msg2);
      send(msg3);
      send(msg1);
      wait(LONG_WAIT);
      send(msg2);
      wait(LONG_WAIT);
      send(msg3);
      @mpp yes this is a common problem. Adding delays seems to be the most popular solution but a more stable power supply might be good as well.
      • mppM
        mppM
        mpp
        Unfortunately adding delays will cost battery. I'll do some testing with different power supplies.
        • mppM mpp
          @mpp or skip the power supply and run directly off the batteries :)
          • mppM
            mppM
            mpp
            :) that's the idea yes. But the thing is, I'm seeing these messages through the serial interface when USB powered. Not sure what to expect when I power the node from the battery.
            • mppM mpp
              @mpp disconnect Vcc from the usb and run the node from batteries while looking at the serial output maybe?
              • mppM
                mppM
                mpp
                Thx for the tip. Only vcc or vcc and ground? Wouldn't want to damage my laptop...
                • mppM mpp
                  @mpp ground needs to be connected, otherwise the signal levels for the serial won't match.
