  3. Atmega328p and flash memory
3 Posts 2 Posters 1.6k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Hello all,
    I'm trying to combine several sketches and unfortunately with signing i am running out of flash memory. The code cannot be optimised further.
    I do like atmega328p and wonder if there is any chance to use a serial SPI flash (the library is here https://github.com/LowPowerLab/SPIFlash) to accommodate a larger sketch size? Or my only option is to switch to atmega1284?
    Alex
    YveauxY 1 Reply Last reply
    • alexsh1A alexsh1
      Hello all,
      Alex
      YveauxY
      YveauxY
      @alexsh1 atmega328 does not support running code from external flash, so you are out of luck. You could also consider switching to a different cpu architecture (esp, atsamd, stm32,... ) with more flash.
      alexsh1A 1 Reply Last reply
      • YveauxY Yveaux
        alexsh1A
        alexsh1A
        alexsh1
        @Yveaux Thanks. This is a battery run multisensor so ESP8266 is not an option. ESP32 is an overkill. I'm not that much familiar with other platforms so I suppose my only option is atmega1284 :((
