  3. Super capacitor charger/balancer with system backup
8 Posts 3 Posters 4.5k Views 3 Watching
  • C
    C
    ceech
    The board charges super capacitors and balances them when the system voltage is available. If this power rail fails, super capacitors power bank takes over and sends power back to the power rail - it acts as uninterruptible power supply.
    Two capacitors are connected in series, pairs in parallel.
    System voltage can be from 3.3V up to 5V. Charging current is 600mA. Backup voltage is 3.15V. The main IC is LTC3110 and it handles all functions of the board.
    This board is intended to be a test board for super capacitor chargers and can supply backup power for limited amounts of time.
    10 boards will shortly be available for sale and design files will be available at OpenHardware.
    alexsh1A Bogus ExceptionB 2 Replies Last reply
    • C ceech
      alexsh1A
      alexsh1A
      alexsh1
      @ceech what the overall capacity? I'm trying to figure out how much it would last on one of my nodes before a charge is required. Assuming 5uA sleep consumption and updates are sent every 5 mins, for how long overall capacity is good for?
      C 1 Reply Last reply
      • alexsh1A alexsh1
        C
        C
        ceech
        @alexsh1 I've tested the board with electronic load. It provided 200mA for one minute at 3.15V.
        alexsh1A 1 Reply Last reply
        • C ceech
          alexsh1A
          alexsh1A
          alexsh1
          @ceech excellent and with what capacity please?
          • alexsh1A alexsh1
            C
            C
            ceech
            @alexsh1 Oh, yes. They are 1.5F, 2.7V each.
            • C ceech
              alexsh1A
              alexsh1A
              alexsh1
              @ceech you have some in series and some parallel, but with this constant discharge current, I estimate you must have around 6F capacitance.
              Enough to power Mega 2560 for 1 minute ;-)
              • C ceech
                Bogus ExceptionB
                Bogus ExceptionB
                Bogus Exception
                @ceech I guess not around just yet? I only saw the 4-cap model...?
                "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                -ATTiny, ATMega, STM32
                -Geek Channel: https://www.youtube.com/TheSalesEngineer
                • Bogus ExceptionB Bogus Exception
                  C
                  C
                  ceech
                  @Bogus-Exception They are ready:
                  http://www.ebay.com/itm/LTC3110-super-capacitor-charger-balancer-with-system-backup-/332255910339?ssPageName=STRK:MESE:IT
