  3. Changing CE/CS Pins used
4 Posts 3 Posters 3.7k Views 1 Watching
  • greglG
    greglG
    gregl
    Hi Hek,
    In the earlier library versions we specified the pins for CE/CS when we specified the relay or sensor function( is it a function?)
    ie: "Sensor gw(9,10);"
    Now you have moved these default values into the sensor.h file:
    * @param _cepin The pin attached to RF24 Chip Enable on the RF module (defualt 9)
    * @param _cspin The pin attached to RF24 Chip Select (default 10)
    Sensor(uint8_t _cepin=9, uint8_t _cspin=10);
    My question is, can i override these pin values by continuing to call the function with the values i require?
    ie: Sensor gw(8,9);
    or....do i need to change sensor.h /relay.h as i need?
    ( same applies with the interupt pin...i need to use pin D3.)
    Greg
    • T
      ToSa
      Code Contributor
      Yes, that's exactly how you would do it - the defaults only apply if the function is called without parameters.
        And D3 is actually not used at the moment. So you can safely detach the cable between IRQ from radio to D3 without losing any functionality (as of today).
        • greglG
          greglG
          gregl
          Fantastic.. Thanks for this.
