  3. Gateway SD card logging of Node data
9 Posts 4 Posters 2.6k Views 4 Watching
  • A Offline
    A Offline
    amongstmyselves
    Hi all,
    I want to have the Gateway save the node data to a SD card. I don't want to run a computer 24/7 as we live off grid and that power luxury is not available. I have the SD card code working on the ESP8266 but I want to capture the data that is usually sent to the Controller to the SD card. How do I get access to that real time data coming from the nodes ?
    Cheers,
    Steve
      If you had a rpi it would be very easy using controllers or even just node-red. From the gw itself I have no idea, let's hope a developer passes by 😀
      ben999B 1 Reply Last reply
        ben999B Offline
        ben999B Offline
        ben999
        @gohan that sounds nice...
        Would it be "accessible" to log the desired data onto a seperate SD Card (not the OS one) connected straight to GPIO ?
          Data can be saved in different database formats that can be used to run statistics directly on the rpi. Why do you need data on SD?
            ben999B Offline
            ben999B Offline
            ben999
            This post is deleted!
            • A Offline
              A Offline
              amongstmyselves
              Thanks for "off topic" leads. :neutral_face: Yeah I'd imagine if I was using a RPI it would be quite simple but I am not. RPI for the job seems a waste though. I'll have to see if I can hack into the libraries maybe ?
                That's why I said that a developer may help, because you would probably need to hack the library a little bit
                • A Offline
                  A Offline
                  amongstmyselves
                  thanks for the help :simple_smile:
                  • korkenK Offline
                    korkenK Offline
                    korken
                    Hi! Did you manage to solve this issue? I have a similar requirement. I have a set of battery powered sensors on a remote cabin with very limited power supply during the winter. I think I can manage to continuously power an Arduino Mega gateway, but not a 4G router to send the sensor data to my database at home. I think the solution is to have the gateway buffering up sensor data, and then send it once a day or something. (After first powering up the 4G router through a relay).
                    I guess I have to hack into the Ethernet gateway code, like you mentioned. But what would be the best place to get to this information. What file/function I should begin digging into? Please advise, if you know the answer!
                    11.9k
                    113.3k
