  3. RGB Mosfet control. Which leg to pull to the hround
4 Posts 4 Posters 2.4k Views 5 Watching
    moskovskiy82
    There are different schematics on the net. One pull the signal to the ground
    Others the load.
    So which one is better?
    mfalkviddM Boots33B 2 Replies Last reply
    • M moskovskiy82
      Others the load.
      @moskovskiy82 theoretical difference: http://www.learningaboutelectronics.com/Articles/Difference-between-a-NPN-and-a-PNP-transistor
      Practical difference: not much in the Arduino home automation world. But I prefer NPN since that's what the MySensors examples use.
      • L
        L
        LastSamurai
        Imo in all cases the pulldown should be on the controlling pin (gate). Otherwise listen to @mfalkvidd ;)
        • M moskovskiy82
          Others the load.
          Boots33B
          Boots33B
          Boots33
          @moskovskiy82 Have a look at my Fire pit RGB striplight controller, The Mosfets in that project run very cool (can't detect any heat rise at all) with 10m of rgb strip lighting connected.
