v2.2 node and v1.4 pi gw
I have a fully working MYS system consisting of 5 v1.5 nodes and v1.4 pi gw (the only pi gw available before v2.1 was introduced)
Everything is working fantastic. Recently, I started to experiment with nrf52DK that naturally drove me to creating a v2.2 node.
The node is not recognized by my current pi gw (expected), BUT! if I briefly power on v2.2 serial GW based on Nano, then not only Nano GW recognizes the node, but my old pi gw starts getting messages from it, EVEN if I power off v2.2 gw later on.
So, I assume when I switch on the v2.2 gw, something happens (like handshaking) at the node level so it actually starts sending messages.
The question is: can I implement this "something" via #defines and omit powering on v2.2 gw to kick-start the node.
My current defines:
MY_NODE_ID xx MY_PARENT_NODE_ID 0 MY_PARENT_NODE_IS_STATICI also tried:
MY_REGISTRATION_FEATURE (false) MY_CORE_COMPATIBILITY_CHECK (false)with no sucess.
Before I switch on v2.2gw I've got the following debug from the node:
24167 !TSM:UPL:FAIL 24168 TSM:FPAR 24170 TSM:FPAR:STATP=0 24172 TSM:ID 24173 TSM:ID:OK 24174 TSM:UPL -
When your v2.2 node starts up, it starts a handshake sequence. This is only supported on a v2.2 gateway. If not answered correctly, then the Node assumes that no gateway is available, and will not communicate with your v1.4 gw
When you start your GW based on nano, the node completes it's handshake sequence, and can communicate with your older gateway afterwards
If I remember right, the GW can be upgraded to v2.2, and still communicate with nodes with earlier library versions. (Actually it works for me, as I haven't updated all my nodes in a long time, and the GW is updated recently)
Works for me as well. GW with 2.2 and nodes with everything from 1.4 up to 2.2.
