1.1k Posts 105 Posters 796.0k Views 98 Watching
  • bjacobseB bjacobse
    @sundberg84
    Redundancy, maybe you should get a second temp/humidity measurement device, just in case your current beer cooler temp node breaks down...
    @bjacobse or get redundant beer coolers :) Important to always have cool beer.
    bjacobseB dbemowskD 2 Replies Last reply
      bjacobseB
      bjacobseB
      bjacobse
      @mfalkvidd
      True but usually wines have a higher price and a more valuable - not starting a discussing/flame war what is best to drink...
        dbemowskD
        dbemowskD
        @mfalkvidd Can't have too much redundancy there...
          #362
          Made this 12 button keypad. Requires only one analog pin to read which button is pressed, and any button press can also wake an arduino from sleep:
          Consumes no power when no button is pressed.
            Here's a thread which covers it in more detail: https://forum.mysensors.org/topic/8936/6-8-buttons-battery-remote-node/36
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @neverdie what happens when you press two or more buttons ??
              • rozpruwaczR rozpruwacz
                #365
                @rozpruwacz Well, with the sketch I wrote (see link), you'd get the value of the first button pressed, and that's it. You'd have to release all the buttons before selecting a new button.
                In terms of the hardware itself, there's an order of precedence to the buttons, so at all times you'd only be able to read the value of a single button, even if more than one button were pressed. In a multi-button press scenario, the buttons of lower precedence are ignored.
                It's a good question though. If you needed to read more than one button simultaneously (such as, for example, move an RC car forward and turn right at the same time), this wouldn't do it. Seems like such a circuit would be possible though, maybe even one based on simple voltage dividing like this one. Somehow you'd need to sum unique resistances for each button pushed instead of just choose a single resistance. I can imagine doing that for a few buttons on an arduino, but maybe not as many as 12.
                  rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  @neverdie I'm asking because I Was trying to do something like this. If there was a resistor values set that would make all 2**n (where n is the number of buttons) choices spaced enough in voltage domain it would work, but I couldn't find such a set ...
                    #367
                    @rozpruwacz said in What did you build today (Pictures) ?:
                    That's why it might work if you needed it for only a few buttons. With only 1024 units of voltage, seems like you'd quickly run out of resolution if you tried to do more.
                    • sundberg84S
                      sundberg84S
                      #368
                      I built my first MysX daughter board which I will connect to my EasyPCB to drive a led strip.
                      This will power everything from 12v so 2 things. Power main board and dim LED strip.
                      • sundberg84S sundberg84
                        sundberg84S
                        sundberg84S
                        Do anyone knows it the back of a TO-220 always is connected to GND and if this should be connected to the board GND as well? Currently I have a exposed copper as a heatsink but this copper is not connected to GND.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @sundberg84
                          Depends on the manufacturer / device type.. So look in the datasheet of the one that you want to use.
                          sundberg84S dbemowskD 2 Replies Last reply
                          • tbowmoT tbowmo
                            @sundberg84
                            sundberg84S
                            sundberg84S
                            #371
                            @tbowmo
                            Thank you - I want to be able to use them all/different (ie. 5v, 3.3v, different manufacturer) so I wont connect it and just use it as a heatsink.
                            • tbowmoT tbowmo
                              @sundberg84
                              dbemowskD
                              dbemowskD
                              @tbowmo I agree, it would be per device specs. In many cases I see that connected to the middle pin (whatever that may be), but not always.
                                Made this two-button nRF52832 remote control:
                                It only draws power when one of the buttons is pressed.
                                • rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  nice :) what about range of the nRF52832 ? is it better than nfr24l01+ with pcb antenna ? I had problems with nrf24 and now I'm trying with rfm69. From first tests I can tell that it has much better range - but it is slightly larger and requires an antenna ...
                                    yes
                                      Assembled and tested final version of LoRa Leak Detector:
                                      Thanks to an external watchdog (TPL5010), it consumes very little current while sleeping. Also, the external watchdog will reboot the pro mini should it ever become unresponsive, so, in addition, it should be highly reliable.
                                      Nca78N 1 Reply Last reply
                                        @neverdie said in What did you build today (Pictures) ?:
                                        TPL5010
                                        That's a really nice IC, I was looking for something like that but it seems I didn't search with the right keywords.
                                        Thank you for sharing the discovery !
                                          Made a simple LoRa node using my CNC:
