  3. [SOLVED] arduino & battery
6 Posts 4 Posters 1.5k Views 5 Watching
  • G
    G
    gian72
    Hello to everyone!
    I need some info about a compatible mini pro arduino board (3.3v 8mhz).
    Removing the power led and removing the power regulator I get power consumption in the uA area. But if I connect the nrf24 when it goes to sleep it consumes around 1.21 mA. The nrf24 is "untouched": I've only added the 470uF capacitor.
    Do you know what I can do to get in the uA area with the nrf attached?
    Thanks!
    Gianluca
    M 1 Reply Last reply
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      Try another NRF module.
      • G gian72
        Hello to everyone!
        Thanks!
        Gianluca
        manutremo
        @gian72 that unit might be bad. If you're using breadboard wires, I'd recommend recheck in them, I've also seen this issue when using bad wires giving unreliable connections.
        • G
          G
          gian72
          thanks very much for the quick replys. I will try to exchange the radio module (now it is soldered to the arduino with some spare wires I have).
          I'll let you know.
          Gianluca
          • Nca78N
            Nca78N
            Is your nrf24 initialized and put to sleep by MySensors ?
            If yes then I agree with the others, replace it.
            If not then it's normal with many clones that consume a lot when connected and not initialized. In that case put a MySensors script using sleep on your board.
            Also, 470uF is way too much, it's supposed to be 4.7 and up to something like 47.
            • G
              G
              gian72
              Thanks so much for the suggestions!.
              I've changed the nrf module with another one and now I've got 4.60uA in sleep... now I'm very satisfied!
              Ciao Gianluca
