  3. Arduino ethernet gateway seems to be stuck in a loop
2 Posts 2 Posters 1.1k Views 2 Watching
  • N
    N
    nerukam
    I have built the Arduino ethernet gateway, this is the sketch I uploaded:
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,194   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 131
    #define MY_MAC_ADDRESS 0x5A, 0x41, 0x42, 0x76, 0xE6, 0xB1
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    When connecting the gateway to an ethernet port, I can ping the gateway on its IP.
    But Home Assistant can't connect to it:
    2017-12-07 14:12:37 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:12:37 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    2017-12-07 14:12:46 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.194', 5003).
    2017-12-07 14:12:46 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.194', 5003).
    2017-12-07 14:12:46 INFO (Thread-2) [mysensors.gateway_tcp] No response. Disconnected.
    2017-12-07 14:12:46 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:12:46 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    2017-12-07 14:12:57 ERROR (Thread-2) [mysensors.gateway_tcp] Receive from server failed.
    2017-12-07 14:12:57 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.194', 5003).
    2017-12-07 14:12:57 ERROR (Thread-2) [mysensors.gateway_tcp] Failed to shutdown socket at ('192.168.1.194', 5003).
    2017-12-07 14:12:57 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.194', 5003).
    2017-12-07 14:12:57 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:12:57 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    2017-12-07 14:13:06 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.194', 5003).
    2017-12-07 14:13:06 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.194', 5003).
    2017-12-07 14:13:06 INFO (Thread-2) [mysensors.gateway_tcp] No response. Disconnected.
    2017-12-07 14:13:06 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:13:06 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    2017-12-07 14:13:17 ERROR (Thread-2) [mysensors.gateway_tcp] Receive from server failed.
    2017-12-07 14:13:17 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.194', 5003).
    2017-12-07 14:13:17 ERROR (Thread-2) [mysensors.gateway_tcp] Failed to shutdown socket at ('192.168.1.194', 5003).
    2017-12-07 14:13:17 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.194', 5003).
    2017-12-07 14:13:17 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:13:17 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    2017-12-07 14:13:26 INFO (Thread-2) [mysensors.gateway_tcp] Closing socket at ('192.168.1.194', 5003).
    2017-12-07 14:13:26 INFO (Thread-2) [mysensors.gateway_tcp] Socket closed at ('192.168.1.194', 5003).
    2017-12-07 14:13:26 INFO (Thread-2) [mysensors.gateway_tcp] No response. Disconnected.
    2017-12-07 14:13:26 INFO (Thread-2) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.194', 5003)
    2017-12-07 14:13:26 INFO (Thread-2) [mysensors.gateway_tcp] Connected to ('192.168.1.194', 5003)
    And this is the serial debug output from the gateway:
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.1.194
    IP: 192.168.1.194
    This is my configuration.yml for Hass:
    <snip>
    mysensors:
      gateways:
        - device: '192.168.1.194'
    <snip>
    Why can't Home Assistant connect to the gateway, and why does the gateway seem to be stuck in some kind of loop?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      As you also suspect I think the gateway is rebooting at a regular interval. In my experience this can be due to two causes. Either due to a bug that was present in an older core arduino firmware version or due to the gateway doesn't get enough power to handle sending of messages. Sending messages requires more power than receiving messages.
      How did you program the gateway, ie what software and what version of software did you use? How do you power the gateway? Do you use the recommended capacitor close to the radio?
      See this post for info on arduino core versions with the bug:
      https://forum.mysensors.org/topic/6257/ethernet-gateway-home-assitant/4
      It was solved in version 1.6.18.
