  3. Domoticz
  4. How to send serial commands (v_var) from Domoticz to serial gateway
2 Posts 2 Posters 2.9k Views 2 Watching
  • I
    I
    Inso
    wrote on last edited by Inso
    I´m working on this for days now, with no conclusion.
    I´d like to send commands to my Arduino Gateway from Domotics, using my DzVents script.
    As the commands won´t fit predefinded types, I´d like to use the v_var1 - 5 (as shown on the list on https://www.mysensors.org/download/serial_api_20#set,-req)
    I found the json url commands
    (https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's),
    and also an example
    (on https://forum.mysensors.org/topic/4933/using-the-selector-switch-in-domoticz-tutorial/2 ) :
    http://192.168.2.110:8080/json.htm?type=command&param=switchlight&idx=971&switchcmd=Set%20Level&level=0
    Set f.e. to a virtual dimmer switch, I can now read the command on the Arduino sketch
    message.type == V_PERCENTAGE
    and get the value sended.
    My problem is, I can´t find out why "param=switchlight" on Domotics results in "V_PERCENTAGE" on MySensors. And what I have to send to get the "V_VAR1".
    Mayber there is also an easier way to send commands to MySensors - maybe send serial commands directly?
    Gateway (and also Domoticz server) is an RPi3.
    • I
      I
      iahim67
      @Inso - you can eventually register a few TEXT devices with one of your Arduino sensors, like:
      present(LCD_LINE1_CHILD_ID, S_INFO, LCD_LINE1);
      then periodically ask data back from Domoticz like:
        if (!line1received) {
          request(LCD_LINE1_CHILD_ID, V_TEXT);
      #if DEBUG == 1
          Serial.println("Requested line1 from gw !");
          wait(5000, 2, V_TEXT); // wait for 5s or until a message of type V_TEXT is received
      just define this first:
      bool line1received = false;
      For more details on the DzVents (2.4x) side have a look in the Domoticz installation folder, there are a few good DzVents examples, this is the path in Windows7:
      C:\Program Files (x86)\Domoticz\scripts\dzVents\examples
      Hope it helps ...
