  3. Best sensor for quantifying magnitude of vibration?
5 Posts 4 Posters 1.2k Views 4 Watching
  • N Offline
    N Offline
    I have a small CNC for etching PCB's by isolation routing. The process creates vibration in the machine, which gets worse if there are lose bolts.
    I am wondering: what sensor could I attach to it that would let me measure the magnitude of vibration? If the amount of vibration seemed unusually large, perhaps it could notify me that I should tighten the bolts again.
    At the moment I'm imagining that maybe attaching a microphone to the CNC might provide this kind of magnitude information (which might be represented as loudness). However, is that the best I can do, or is there actually a better sensor that I might use?
      I can't think other than an accelerometer, the fun part will be to figure out what is the direction of the vibration in order to mount the sensors accordingly or use a 3 axis one
      • N Offline
        N Offline
        As @gohan says, this is the job for an accelerometer.
        Search "accelerometer machine vibration" or "accelerometer CBM" in Google and enjoy :)
        • JohnRobJ Offline
          JohnRobJ Offline
          JohnRob
          While not specifically answering your question... would loctite help?
          Or possibly nuts with self locking features (castle etc).
          N 1 Reply Last reply
          • JohnRobJ JohnRob
            N Offline
            N Offline
            @johnrob said in Best sensor for quantifying magnitude of vibration?:
            Yes, I think it would help. Not very easy to apply in this situation though, because most connections are t-nut without much thread pushing through to the other side.
