  3. Issues with NACK on RFM69HW
9 Posts 5 Posters 2.0k Views 5 Watching
  • R Offline
    R Offline
    Ryanmt
    wrote on last edited by Ryanmt
    Re: EasyPCB and RFM69 Issues
    Following on from the thread above I have done some further debugging to try narrow down the issue.
    My setup currently is 3x EasyPCB nodes, non H version of the RFM69. Powered by debugger but also attached battery power.
    They sync up very very sporadically. Most of the time they will not talk to the gateway.
    My gateway is a D1 mini with the H version of the radio. I have tried 2 different radios and both perform the same.
    Antenna type on everything is the coiled versions common on ebay but i have experimented with the SMA style antenna on a node and a 17cm dipole on the gateway
    Everything is running on 433mhz.
    Sensor Log -
     __  __       ____
            |___/                      2.2.0
    16 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    30 TSM:INIT:TSP OK
    32 TSM:INIT:STATID=49
    34 TSF:SID:OK,ID=49
    36 TSM:FPAR
    38 TSM:FPAR:STATP=0
    40 TSM:ID
    43 TSM:ID:OK
    43 TSM:UPL
    1263 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    3270 TSM:UPL
    4489 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    6496 TSM:UPL
    7714 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    9721 TSM:UPL
    10940 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    12947 !TSM:UPL:FAIL
    12949 TSM:FPAR
    12949 TSM:FPAR:STATP=0
    12953 TSM:ID
    12953 TSM:ID:OK
    12955 TSM:UPL
    14176 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    16183 TSM:UPL
    17401 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    19410 TSM:UPL
    20629 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    22636 TSM:UPL
    23855 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    25862 !TSM:UPL:FAIL
    25864 TSM:FPAR
    25864 TSM:FPAR:STATP=0
    25868 TSM:ID
    25868 TSM:ID:OK
    25870 TSM:UPL
    27090 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    29100 TSM:UPL
    30318 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    32325 TSM:UPL
    33544 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    35553 TSM:UPL
    36771 !TSF:MSG:SEND,49-49-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    38782 !TSM:UPL:FAIL
    38785 TSM:FPAR
    38785 TSM:FPAR:STATP=0
    38789 TSM:ID
    38789 TSM:ID:OK
    38791 TSM:UPL
    Gateway Log
    60 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0
    103 TSF:LRT:OK
    118 TSM:INIT
    132 TSF:WUR:MS=0
    152 TSM:INIT:TSP OK
    173 TSM:INIT:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 8
    cnt
    connected with xxxxxxxxx, channel 9
    dhcp client start...
    339 TSM:READY:ID=0,PAR=0,DIS=0
    371 MCO:REG:NOT NEEDED
    scandone
    897 GWT:TPC:CONNECTING...
    1424 GWT:TPC:CONNECTING...
    1952 GWT:TPC:CONNECTING...
    2357 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    2417 TSF:MSG:PINGED,ID=49,HP=1
    3673 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    ip:192.168.5.19,mask:255.255.255.0,gw:192.168.5.1
    3801 GWT:TPC:CONNECTING...
    3829 GWT:TPC:IP=192.168.5.19
    3860 MCO:BGN:STP
    3878 MCO:BGN:INIT OK,TSP=1
    3906 GWT:TPC:IP=192.168.5.19
    3937 GWT:RMQ:MQTT RECONNECT
    3994 GWT:RMQ:MQTT CONNECTED
    4023 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    5584 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    5643 TSF:MSG:PINGED,ID=49,HP=1
    6900 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    8810 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    8869 TSF:MSG:PINGED,ID=49,HP=1
    10126 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    pm open,type:2 0
    12047 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    12108 TSF:MSG:PINGED,ID=49,HP=1
    13365 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    15273 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    15333 TSF:MSG:PINGED,ID=49,HP=1
    16591 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    18501 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    18562 TSF:MSG:PINGED,ID=49,HP=1
    19820 !TSF:MSG:SEND,0-0-49-49,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    21728 TSF:MSG:READ,49-49-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    21788 TSF:MSG:PINGED,ID=49,HP=1
    My sketches
    (Default MockSensor sketch)
    * MockMySensors
    * This skecth is intended to crate fake sensors which register and respond to the controller
    * Barduino 2015, GizMoCuz 2015
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM69
    #define MY_RF69_FREQUENCY RF69_433MHZ // Set your frequency here
    #define MY_NODE_ID 49
    #define MY_PARENT_NODE_ID 0
    //#define MY_RFM69_NEW_DRIVER
    //#define MY_RADIO_RFM95
    #define RADIO_ERROR_LED_PIN 4  // Error led pin
    #define RADIO_RX_LED_PIN    6  // Receive led pin
    #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_NAME "MockMyRyanmt"
    #define SKETCH_VERSION "v0.5"
    << Removed default sketch code below >>
    And the gateway is the default esp8266mqtt gateway sketch.
    #define MY_BAUD_RATE 9600
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_GATEWAY_ESP8266
    #define MY_NODE_ID 1
    #define MY_RF69_IRQ_PIN D2
    #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
    #define MY_RF69_SPI_CS D8
    // Set MQTT client id
    #define MY_MQTT_USER "xxxxxxx"
    #define MY_MQTT_PASSWORD "xxxx"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "xxxxxx"
    #define MY_ESP8266_PASSWORD "xxxxxx"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192,168,5,3
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    I have tried the new driver option on both the sensor and gateway but same issue. Looks like I only have 1 way communications?
    Things I have tried
    • Double checking the soldering
    • Building multiple gateways and using different radios on the gateway
    • Moving the sensors very close or few meters apart
    • Using a radio on the gateway with a 17cm wire as apposed to the coiled antena
    So the current status is they gain 2 way comms occasionally and when they're within 5cm. The range is very very small!
    Anybody got any ideas what I could try next? Is there a way to confirm the ebay seller has sold me the correct frequency radios? Should I look more into the antennas perhaps? I have tried a dipole and have a node with both the coiled ebay antennas and an SMA one but the results are always the same.
    If the vendor had sold me the wrong frequency radios is there any way to check? Would it cause severe range issues like this?
    • R Ryanmt
      Sensor Log -
       __  __       ____
              |___/                      2.2.0
      26 TSM:INIT
      28 TSF:WUR:MS=0
      30 TSM:INIT:TSP OK
      34 TSF:SID:OK,ID=49
      36 TSM:FPAR
      38 TSM:FPAR:STATP=0
      40 TSM:ID
      43 TSM:ID:OK
      43 TSM:UPL
      3270 TSM:UPL
      6496 TSM:UPL
      9721 TSM:UPL
      12947 !TSM:UPL:FAIL
      12949 TSM:FPAR
      12953 TSM:ID
      12953 TSM:ID:OK
      12955 TSM:UPL
      16183 TSM:UPL
      19410 TSM:UPL
      22636 TSM:UPL
      25862 !TSM:UPL:FAIL
      25864 TSM:FPAR
      25868 TSM:ID
      25868 TSM:ID:OK
      25870 TSM:UPL
      29100 TSM:UPL
      32325 TSM:UPL
      35553 TSM:UPL
      38782 !TSM:UPL:FAIL
      38785 TSM:FPAR
      38789 TSM:ID
      38789 TSM:ID:OK
      38791 TSM:UPL
      Gateway Log
      103 TSF:LRT:OK
      118 TSM:INIT
      132 TSF:WUR:MS=0
      152 TSM:INIT:TSP OK
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 8
      cnt
      scandone
      3860 MCO:BGN:STP
      pm open,type:2 0
      My sketches
      * MockMySensors
      // Wait times
      Things I have tried
      @ryanmt great work on the troubleshooting so far. You've covered all the test scenarios we usually use.
      One thing you could do is to define MY_SIGNAL_REPORT_ENABLED. I have not tried it myself and I am not sure how the report is displayed, but it should give some additional info on the signal levels.
      Perhaps defining MY_RFM69_ATC_MODE_DISABLED can help, to get rid of the possibility that ATC messes things up (it shouldn't, but who knows?)
      You could also enable MY_DEBUG_VERBOSE_RFM69 which will give additional debug output.
      I have configured my gateway to report signal levels. You are welcome to use my sketch for inspiration if you find it useful.
      As for the right frequency, one way is to just set your frequency to the other supported frequencies (315, 433, 868, 915) and see if you can get messages through. The loss of signal for using the wrong frequency seems to be 20 to 80dB, depending on frequency so it could absolutely cause this type of problem.
      I am not aware of any external marking or a register to read to figure out which model you've got.
      https://forum.mysensors.org/topic/4741/rfm69-frequency-question might give some extra insight into how the rfm69 radios work.
      If you have a SDR, you could use it to check the signal strength.
        wrote on last edited by gohan
        Look also at my project on how to read RSSI and tx power that are also nice info for debugging.
        https://forum.mysensors.org/post/77660
        • R Offline
          R Offline
          Ryanmt
          Thanks guys,
          I tried enabling #define MY_SIGNAL_REPORT_ENABLED but it made no difference to the output.
          Also tried a few of those sketches but neither would compile properly - I guess im missing something!
          Just bought this
          https://www.ebay.co.uk/itm/162961285195
          now for a long wait from China!
          S gohanG 2 Replies Last reply
          • R Ryanmt
            Thanks guys,
            Just bought this
            @ryanmt sorry I have missed this thread. I'm following now as well if I can help out with any hardware questions.
            How are you powering the nodes? (Booster or lowered bod?) Can you upload a picture of the nodes and gateway? Sometimes more eyes can spot something.
            You should not power the nodes both with the debugger and battery. Please de-attach the VCC from ftdi debugger. You should only have Gnd rx and TX connected while debugging. Rst can be connectws if you want.
            The biggest concern is in most cases power or antenna.
            • R Ryanmt
              Thanks guys,
              Just bought this
              @ryanmt if you tried my sketch it would not compile since you are probably missing the display libraries, but you should just use the code that reads the rssi and power info and than print those values either on serial debug or another lcd screen you may have
              • R Offline
                R Offline
                Ryanmt
                Got my SDR and installed the software.
                Seems to work well, on 433mhz I can see signals from my car keyfob etc.
                When my sensors are powered on though - nothing, looks like nothing is broadcast atall.
                Stumped now. properly stumped :-( When I get time I will perhaps try a non mysensors sketch to activate the radio see if I can get any TX then. Does anybody have any good sensors?
                I want to think its a bad batch of radios but they are from 3 different sellers.
                alexsh1A 1 Reply Last reply
                  you could try to compile the sketch with the 866 and 916Mhz andd see if by change some signal shows up
                  • R Ryanmt
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @ryanmt can you please try to use any AVR instead of Wemos for the GW?
                    Are you 100% sure you have HW version?
                    Try with and without
                    12.1k
