  3. Combination of gateway and relay code
6 Posts 2 Posters 1.7k Views 2 Watching
  • S
    scalpel
    Hi. I am an amateur programmer. I connected the buzzer to the gate and added the alarm functionality. It works but if the gateway gets some data from other sensor, the alarm stops working.
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    void before()
        pinMode(RELAY_1, OUTPUT);
        digitalWrite(RELAY_1, LOW);
     pinMode(A0, OUTPUT);
      present(1, S_BINARY);
       if (message.type==V_STATUS) {
        while (message.getBool() == 1){
        beep();
        // Write some debug info
        Serial.print(message.sensor);
    void beep()
        tone(A0, 4200); //Wygeneruj sygnał o częstotliwości 4000Hz na pinie A5
        wait(100);
        noTone(A0);
        wait(100);
        wait(100);
        noTone(A0);
        wait(10000);
    • S scalpel
      * LEDs (OPTIONAL):
      void before()
          beep();
      void beep()
          wait(100);
          noTone(A0);
          wait(100);
          wait(100);
          noTone(A0);
          wait(10000);
      @scalpel this code
      beep();
      instructs the gateway to beep forever. There is no code in beep() that will change message, it will always be the same message.
      • S
        scalpel
        wrote on last edited by scalpel
        But if gateway receive some data from sensors, example temperature it stop beeping. Maybe while function should be in loop()?
        look
        2018-04-02 19:54:21.356 User: mietek initiated a switch command (771/Alarm/On) /<<---START BEEPING :+1:
        2018-04-02 19:54:21.465 (ArduinoOdbiornik) Lighting 2 (Alarm)
        2018-04-02 19:54:21.588 Error: OTGW: Error received!
        2018-04-02 19:54:34.675 (OpenTherm) Temp (Control Setpoint)
        2018-04-02 19:54:34.682 (OpenTherm) General/Percentage (Maximum Relative Modulation Level)
        2018-04-02 19:54:34.688 (OpenTherm) Thermostat (Zadana ogrzewania)
        2018-04-02 19:54:34.694 (OpenTherm) General/Percentage (Modulacja palnika)
        2018-04-02 19:54:34.700 (OpenTherm) Temp (Isense)
        2018-04-02 19:54:34.708 (OpenTherm) Temp (Boiler Water Temperature)
        2018-04-02 19:54:34.714 (OpenTherm) Temp (DHW Temperature)
        2018-04-02 19:54:34.720 (OpenTherm) Temp (Outside Temperature)
        2018-04-02 19:54:34.725 (OpenTherm) Temp (Return Water Temperature)
        2018-04-02 19:54:34.731 (OpenTherm) Thermostat (DHW Setpoint)
        2018-04-02 19:54:34.735 (OpenTherm) Thermostat (Max_CH Water Setpoint)
        2018-04-02 19:54:51.739 Error: OTGW: Error received!
        2018-04-02 19:55:20.879 Error: OTGW: Error received!
        2018-04-02 19:55:21.434 (rflink) Temp (Zewnątrz)
        2018-04-02 19:55:32.899 (ArduinoOdbiornik) Temp (Parter) // <<--- STOP BEEPING:-1:
        • S scalpel
          look
          @scalpel could you move the debug info prints in receive() to the beginning of receive() instead of the end, and re-run your test and post the result?
          • S
            scalpel
            I will try tomorrow. Thanks
            • S
              scalpel
              Need more tests, but looks like it works. Thanks
