  2. Enclosures / 3D Printing
  3. Enclosure for Temp + Humidity node with OLED display
6 Posts 4 Posters 4.3k Views 6 Watching
  • T
    titvs
    Hi everyone,
    Already posted this over at the troubleshooting section, so im posting here also for whoever is interested. My "compact" temperature + humidity node enclosure with a little window for a 0.96" OLED display.
    Every part is in place using the printed spacers and the back is attached with 2 self drilling screwers.
    https://www.thingiverse.com/thing:3019468
    2_1532525241892_03-back.jpg 1_1532525241892_02-inside.jpg 0_1532525241892_01-front.jpg
    • bjacobseB
      bjacobseB
      bjacobse
      Looks good :-)
      T 1 Reply Last reply
      • bjacobseB bjacobse
        Looks good :-)
        titvs
        @bjacobse said in Enclosure for Temp + Humidity node with OLED display:
        Looks good :-)
        Thanks! :relaxed:
        • alowhumA
          alowhumA
          alowhum
          I hide my sensors in old library books. I try to get the name of the book to be a pun on the sensor inside. So for example, I have an air quality sensor that is inside a murder mystery called "poison".
          • pihomeP
            pihomeP
            pihome
            Can you share sketch and connection?
            PiHome - Smart Heating Control
            • T
              titvs
              @pihome Sure! Its no trade secret. ;)
              Ive used the U8g2lib for the display which is connected at A4 and A5, as defined in the code.
              You should power the display directly to a good power source (3.3 ~ 5.5V) since you are also powering a radio module.
              Its basically the temp+hum sketch where Ive included some lines of code for the display. At boot it displays the message "Connecting…". If the gateway or repeater is offline or out of range, it wont do anything else unless MY_TRANSPORT_WAIT_READY_MS is of a different value than the default (not pretty sure but ive read that the default is to wait forever).
              It will then display temp + hum with a small chain icon at the bottom (connected). If the gateway goes offline it displays "Disconnected!"
              Im not sure if this is bug free, so feel free to debug and add new functionalities. :)
              // Enable debug prints
              //#define MY_DEBUG
              //#define MY_RS485
              #define MY_RF24_CHANNEL 1   //////////////
              #define MY_RF24_PA_LEVEL RF24_PA_HIGH   //////////////
              #include <DHT.h>
              #include <U8g2lib.h>  //////////////////////
              #include <Wire.h>    /////////////////////////
              U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, A5, A4);   // U8G2 Constructor (PINS: A5 - Clock SCL ; A4 - Data SDA)
              #define DHT_DATA_PIN 3
              // Set this offset if the sensor has a permanent small offset to the real temperatures.
              // In Celsius degrees (as measured by the device)
              #define SENSOR_TEMP_OFFSET 0
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              float lastTemp;
              float lastHum;
              uint8_t nNoUpdatesTemp;
              uint8_t nNoUpdatesHum;
              bool metric = true;
              DHT dht;
              void before(){
                 u8g2.begin();
                 u8g2.firstPage();
                 do {
                   u8g2.setFont(u8g2_font_helvR14_tf);
                   u8g2.drawStr(38,15,"OLED");
                   u8g2.drawStr(15,35,"Temp+Hum");
                   u8g2.drawStr(46,60,"v1.2");
                 } while ( u8g2.nextPage() );
                delay(3000);
                u8g2.clear();
                 u8g2.firstPage();
                 do {
                   u8g2.drawStr(3, 32, "Connecting...");
                sendSketchInfo("TEMPHUM_OLED", "1.2");
                present(CHILD_ID_HUM, S_HUM);
                u8g2.clear();
                  u8g2.firstPage();
                  do {
                      u8g2.setFont(u8g2_font_haxrcorp4089_tr); // 7 PIXEL HIGHT
                      u8g2.drawStr(1,12,"WARNING: UPDATE_INTERVAL");
                      u8g2.drawStr(1,24,"is smaller than supported by");
                      u8g2.drawStr(1,36,"the sensor!");
                  delay(4000);
               while (transportCheckUplink() == false){
                u8g2.firstPage();
                do {
                  u8g2.setFont(u8g2_font_helvR14_tf); // 14 px height
                  u8g2.drawStr(3, 32, "Disconnected!");
                dht.readSensor(true);
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  // apply the offset before converting to something different than Celsius degrees
                  if (!metric) {
                  // Reset no updates counter
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  Serial.print("T: ");
                  Serial.println(temperature);
                } else {
                  nNoUpdatesTemp++;
                if (isnan(humidity)) {
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  Serial.print("H: ");
                  Serial.println(humidity);
                } else {
                  nNoUpdatesHum++;
                u8g2.firstPage();
                do {
                u8g2.setFont(u8g2_font_fub30_tn);
                u8g2.setCursor(2, 35);
                u8g2.print(temperature, 1);
                u8g2.setFont(u8g2_font_inb16_mf);
                u8g2.drawGlyph(88, 35, 0x00b0); // degree
                u8g2.drawStr(100, 35, "C");
                u8g2.setCursor(70, 60);
                u8g2.print(humidity, 0);
                u8g2.drawStr(100, 60, "%");
                u8g2.setFont(u8g2_font_open_iconic_thing_2x_t); // 16 pix height
                u8g2.drawGlyph(45, 60, 0x0048); // drop
                u8g2.setFont(u8g2_font_open_iconic_www_2x_t); // 16 pix height
                u8g2.drawGlyph(2, 60, 0x004f); // CONNECTION ICON
                //sleep(UPDATE_INTERVAL);
                delay(UPDATE_INTERVAL);  // POWERED NODE
