  3. Is my repeater repeating?
4 Posts 3 Posters 2.1k Views 1 Watching
  • HeinzH
    HeinzH
    Heinz
    wrote on last edited by Heinz
    I tried to setup a sensor as repeater node. In the end I wondered if this node is used from the other nodes as repeater or if the messages went directly to the gateway. How can I find out how many hops a message took until it arrived at the controller? Is there a best practice for setting up repeater nodes... like "power off all sensors, start gateway, start repeaters after x seconds, start sensors after y seconds,...."
    Is there a way to read out the network topology?
    Any help is very appreciated...
    hekH 1 Reply Last reply
    • HeinzH Heinz
      @Heinz
      You can see topology in the MYSController..
        marceloaqno
        Code Contributor
        The only way to know how many hops a message took is to watch the serial output from all of your repeaters and gateway, a message only keeps the information from the last node.
        For a best practice, I would say to first turn on the gateway, repeater, sensors. But really it does not matter since the network is self-healing, and sensors will try to use the shortest route they can find.
        • HeinzH
          HeinzH
          Heinz
          @hek: thank you, MYSController helped a lot.
