  3. RFM69 ATC not working?
39 Posts 6 Posters 4.7k Views 7 Watching
  • T Offline
    T Offline
    TSD
    I want to use my MySensors/RFM69HW node with the lowest power possible. However, with ATC enabled, I noticed that the power is always adjusted to the maximum level possible. To investigate, I did an experiment in which I disabled ATC and increased the radio power from -2dBm to 13dBm and have the node send the receiving RSSI and sending RSSI. I recorded both the node voltage and current, as shown in the image below.
    It is clear that the radio power is linearly increased, which is good. However, the reported receiving/sending RSSIs do not change, as shown by the following gateway log (format: TX power, receiving RSSI, sending RSSI):
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-2.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-98.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-66.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-1.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-96.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-67.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:0.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-99.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:1.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-102.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-64.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:2.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-100.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-62.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:3.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-61.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:4.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:5.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-60.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:6.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-92.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:7.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-97.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-59.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:8.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:9.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:10.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:11.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:12.00
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-58.000
    TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:13.00
    The receiving RSSI is always about -100dBm and the sending RSSI is always around -60/-70 dBm.
    The RFM69HW has a 22uF ceramic capacitor and a 480uF elcap to decouple its power supply.
    I used MySensors 2.2.0 for this measurement, but I get the same result with 2.3.0.
    Does anyone have a clue what may be causing the RSSI to be independent of the transmit power?
    • T TSD
      @tsd are these numbers from the node’s own point of view, or the gateway’s? When (in the send/receive cycle) where they taken? How du you measure sending rssi?
      T 1 Reply Last reply
        T Offline
        T Offline
        TSD
        @mfalkvidd
        These numbers are from the node point of view.
        In the main loop, there's a piece of code that contains the RSSI measurements:
        RFM69_setTxPowerLevel(i);
        txPower     = RFM69_getTxPowerLevel();
        rssiReceive = RFM69_getReceivingRSSI();
        rssiSend    = RFM69_getSendingRSSI();
        send(msgRSSI.set(txPower,2));		// Send receiving RSSI
        send(msgRSSI.set(rssiSend,3));		// Send sending RSSI
        send(msgRSSI.set(rssiReceive,3));		// Send sending RSSI
        Should I use these functions differently?
        • T TSD
          @mfalkvidd
          @tsd I have not used getSensdingRSSI but according to
          https://www.mysensors.org/apidocs/group__RFM69Newgrp.html#ga80da4f9f4e901b6ff7ed23e77484e8a2 ATC must be enabled for it to work.
          • mfalkviddM Offline
            Maybe measuring rssi at the gateway gives a better result? See https://github.com/mfalkvidd/Arduino-MySensors-ESP8266-RFM69-Gateway/blob/master/Arduino-MySensors-ESP8266-RFM69-Gateway.ino#L105 for how I’ve done that.
              also, getReceivingRSSI will return the RSSI from the last received message. It shouldn't be affected by the TX power of the node, and it is probably only updated when a message is sent to the node.
                T Offline
                T Offline
                TSD
                @mfalkvidd
                I added a sending a temperature measurement before RFM69_getReceivingRSSI and enabled ATC, but get a similar result. The code is now as follows (I cleaned up the comments):
                txPower = RFM69_getTxPowerLevel();       // Get TX power
                float temperature = readTemp705x();      // Read temperature
                send(msgTemp.set(temperature, 1),0);    // Send temperature
                send(msgRSSI.set(txPower,2));		// Send TX power
                send(msgRSSI.set(rssiReceive,3));	// Send receiving RSSI
                The gateway log shows that the power is increased until the maximum allowed (20 dBm), but no change in RSSI.
                TSF:MSG:READ,12-12-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.8
                TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-79.000
                TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-42.000
                TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:17.00
                TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:20.00
                TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-43.000
                Any idea why this doesn't work?
                I'm using a Raspberry Pi gateway now, is it easy to measure RSSI on that as well? I can switch to an Arduino gateway if required.
                • T TSD
                  @mfalkvidd
                  @tsd sorry, no idea at the moment.
                  For the rpi gw, just edit https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp (add the receive function from my sketch and start from the make step)
                  T 2 Replies Last reply
                    T Offline
                    T Offline
                    TSD
                    @mfalkvidd
                    OK, tnx for now. I'll look at gateway rssi tomorrow evening
                      T Offline
                      T Offline
                      TSD
                      @mfalkvidd
                      I modified my code to include your receive function, but I wasn't sure how to use it in the main loop.
                      MyMessage msgTemp(1,V_TEMP);
                      MyMessage msgRSSI(2,V_LEVEL);
                      #define ARDUINO 100
                      // This space is intended to be used to include arduino libraries
                      #undef ARDUINO
                      present(1,S_SOUND);
                      receive(msgTemp);
                        int16_t rssiReceive = RFM69_getReceivingRSSI();
                        if (message.sender == 1 ) {
                          send(msgRSSI.set(rssiReceive,0));
                      I figured that you have to use your receive function to capture a message from the node and then do an RSSI measurement. Since I have a msgTemp coming from the node, I used that.
                      After compiling the code and running the SGW, I get the following error in the logs:
                      Serial - write failed: Resource temporarily unavailable
                      Do you know what I did wrong?
                      • T TSD
                        @mfalkvidd
                        #define ARDUINO 100
                        #undef ARDUINO
                        present(1,S_SOUND);
                        receive(msgTemp);
                        @tsd
                         present(1,S_SOUND);
                        should be
                        present(2,S_SOUND);
                        and you don’t need MyMessage msgTemp(1,V_TEMP);
                        I am not sure about the error. Are you using the rpi gw as serial, mqtt or ethernet gw? (What was your configure command?)
                          @tsd
                           present(1,S_SOUND);
                          should be
                          present(2,S_SOUND);
                          T Offline
                          T Offline
                          TSD
                          @mfalkvidd
                          I improved the power supply of the RFM (added linear regulator) on the gateway and the error is gone.
                          The code doesn't compile if I don't declare msgTemp, as I use msgTemp in the main loop.
                          Where should I see the message the GW is sending? On the node? I'm using a custom node without a serial connection, so I can't see incoming messages on the node. Is there a way to have the GW send the RSSI to its own log?
                            @tsd
                             present(1,S_SOUND);
                            should be
                            present(2,S_SOUND);
                            T Offline
                            T Offline
                            TSD
                            @mfalkvidd
                            I was using serial gateway by the way.
                            • T TSD
                              @mfalkvidd
                              @tsd I don’t know. I've always connected the gateways to my controller where I get logs and graphs.
                              Maybe you can use GATEWAY_DEBUG(text)
                                T Offline
                                T Offline
                                TSD
                                @mfalkvidd
                                #define GATEWAY_DEBUG(text)
                                or
                                doesn't show any additional messages in the log, besides the node messages.
                                In the mean time I installed Domoticz to try it your way, but don't see the USB port that I tried to make by installing the serial gateway (ttyUSB020, which is not in /dev yet, so should be free).
                                This command should take care of that, right?
                                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                Sorry to be such a pain, but I would really like to get this sorted out.
                                • T TSD
                                  @mfalkvidd
                                  or
                                  @tsd sorry for being unclear. This is how to use GATEWAY_DEBUG:
                                  GATEWAY_DEBUG("This message will be sent to the debug log")
                                  But I am not sure it is available in sketches and I don't have access to a computer at the moment.
                                  The configure command looks good. After running configure, did you continue with make, etc?
                                    T Offline
                                    T Offline
                                    TSD
                                    @mfalkvidd
                                    Do you mean
                                    #define MY_DEBUG_VERBOSE_GATEWAY
                                    That uses the GATEWAY_DEBUG("text") macro that you are referring to. I tried that, but it doesn't give any additional output in the log.
                                    Yes, this is the complete code I run:
                                    sudo ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                    sudo make install
                                    sudo systemctl start mysgw.service
                                    But ttyUSB020 doesn't appear in /dev afterwards, nor does Domoticz list it.
                                    • T TSD
                                      @mfalkvidd
                                      Do you mean
                                      sudo make install
                                      @tsd I think you'll need to run make before make install.
                                      configure prepares the settings for make
                                      make compiles the code into an executable file called mysgw, including changes to the cpp file and the settings from the configure command
                                      make install copies the mysgw executable to /etc/init.d/
                                      • T Offline
                                        T Offline
                                        TSD
                                        If I run "make install" while the code has not compiled yet, it will compile before installing. If you first run "make" seperately, "make install" will only install.
                                        I'm almost there. I configured an Ethernet gateway (couldn't get serial gateway to work) and can now see the temperature, receive RSSI and sending RSSI from the node in Domoticz.
                                        The gateway receive function shows up as "S_ARDUINO_REPEATER_NODE", but there's no data yet.
                                        What data should I pass on to your receive function? My gateway code is now as follows:
                                        #define ARDUINO 100
                                        #undef ARDUINO
                                        present(2,S_SOUND);
                                        receive(msgTemp);
                                        • T TSD
                                          #define ARDUINO 100
                                          #undef ARDUINO
                                          present(2,S_SOUND);
                                          receive(msgTemp);
                                          @tsd MySensors will automatically call receive() when the node receives a message. It should not be called manually.
                                          11.8k
                                          113.2k
