💬 PogoPins
What's the smallest hole ptich that I can do pogo pins with? e.g. is 1.27mm pitch possible?
Yes, 1.27mm pitch should be possible with pogo pins (I have never done them myself, though).
You need to buy the smaller pogo pins (diameter 0.68mm). Some examples by other hackaers can be found e.g. at
- http://blog.spitzenpfeil.org/wordpress/projects/the-pogo-key-1-27mm-avr-isp-pogo-pin-adapter/
- http://blog.spitzenpfeil.org/wordpress/2013/11/12/the-pogo-key-1-27mm-avr-isp-adapter-take-ii/
- http://blog.spitzenpfeil.org/wordpress/2013/07/05/tiny-pcbs-vs-large-isp-headers-pogo-pins-to-the-rescue/
- https://www.tindie.com/products/ElectronutLabs/pogoprog-model-c-pogo-pin-programmer-swd-2-pack/
I made a simple adapter for Pro Minis, Used on it own for new boards with connection holes
If you slide on some dupont cable covers as a guide it makes it easy to program a soldered board
1 out of 4
💬 AC-DC double solid state relay module
OpenHardware.io • 17 Apr 2016, 14:21 • openhardware.io 25 Mar 2024, 20:01 -
💬 SimSpirit Motion Simulator Support 360° Yaw, Pitch and Roll
OpenHardware.io • 10 Jul 2023, 16:54 • openhardware.io 10 Jul 2023, 16:54 -
💬 MyGateway
OpenHardware.io • 18 Aug 2020, 03:59 • openhardware.io 10 days ago -
💬 In-wall scene controller OLED keypad
OpenHardware.io • 1 Jan 2018, 03:23 • openhardware.io 29 Feb 2024, 03:55 -
💬 air quality motherboard for sensor.community project
OpenHardware.io • 12 days ago • openhardware.io 12 days ago
