  3. Moisture reading inverse in Domoticz
11 Posts 3 Posters 1.9k Views 2 Watching
  • dzjrD Offline
    dzjrD Offline
    dzjr
    Hello everyone here at MySensors,
    I have made a mysensors sketch to measure soil moisture in the garden, the sketch work properly, so it is not falling apart ;)
    Only the value in Domoticz is the opposite of what it really is.
    If I have the sensor loose on the desk I get 20cb as value (irrigation advise) and when I put the sensor in a glass of water I get 100cb (dangerously dry)
    is there a possibility to turn this into domoticz, or is the problem in the mysensors sketch?
    I read the value in this way:
     int moistureLevel11 = (1023 - analogRead(VOCHT_PUT_1_PIN))/ 10.23;
        if (moistureLevel11 != lastsoilValue11) {
        send (msg11.set(moistureLevel11));
        lastsoilValue11 = moistureLevel11;}
    And With: S_Moisture
    I Use Mysensors 2,3 and Domoticz Beta V4.10064
    thank you in advance
    dzjr
    • dzjrD dzjr
      dzjr
      @dzjr the debug log from the node would be useful to see which number is being sent.
      If the value needs to be inverted in the sketch, just remove this part:
      1023 -
      dzjrD 1 Reply Last reply
        1023 -
        dzjrD Offline
        dzjrD Offline
        dzjr
        @mfalkvidd
        Thank Your for the reply,
        I removed the 1023 - And it looks bij now, i think that i have to tweak it to get te right value.
        The node i have combined in a gateway, do i get a good debug than with #my_debug ?
        • dzjrD dzjr
          @mfalkvidd
          @dzjr MY_DEBUG should work fine
            dzjrD Offline
            dzjrD Offline
            dzjr
            @mfalkvidd
            This is the MyDebug output:
            0 MCO:BGN:INIT GW,CP=R-NGA---,VER=2.3.0
            3 MCO:BGN:BFR
            741 GWT:TIN:IP=192.168.0.145
            1744 MCO:BGN:STP
            1746 MCO:REG:NOT NEEDED
            1748 MCO:BGN:INIT OK,TSP=NA
            39316 GWT:TSA:ETH OK
            39375 GWT:RFC:MSG=0;0;3;0;2;
            39382 GWT:RFC:MSG=0;0;3;0;2;Get Version
            45932 GWT:RFC:MSG=0;0;3;0;18;PING
            55858 GWT:RFC:MSG=0;0;3;0;18;PING
            65783 GWT:RFC:MSG=0;0;3;0;18;PING
            75709 GWT:RFC:MSG=0;0;3;0;18;PING
            85635 GWT:RFC:MSG=0;0;3;0;18;PING
            95560 GWT:RFC:MSG=0;0;3;0;18;PING
            105486 GWT:RFC:MSG=0;0;3;0;18;PING
            115411 GWT:RFC:MSG=0;0;3;0;18;PING
            125337 GWT:RFC:MSG=0;0;3;0;18;PING
            i have edit the sketch to this:
            int moistureLevel11 = (analogRead(VOCHT_PUT_1_PIN)) / 5.8;
            i only have to adjust the " / 5.8 " for the right value in the ground.
            Thank you for helping!
            dzjr
            • gbuicoG Offline
              gbuicoG Offline
              gbuico
              @dzjr , glad you solved your problem .. but... can you please share which sensor are you using to measure the soil moisture?
              I found a lot of sensor suitable for in-house measuring but nothing for outside which is not becoming unusable very quickly.
              Whatever information is highly appreciated...
              Giacomo
              dzjrD 2 Replies Last reply
              • dzjrD Offline
                dzjrD Offline
                dzjr
                @gbuico
                I use the soil humidity sensor with the external pcb.
                Only I find the measured range somewhat disappointing, I get when completely in water, not the measured value "saturated" it lingers on irrigation.
                so if you have a different solution, I am very much recommended.
                dzjr
                this sensor i use
                • gbuicoG gbuico
                  Giacomo
                  dzjrD Offline
                  dzjrD Offline
                  dzjr
                  @gbuico
                  the external pcb has been built in a housing together with the arduino and the relay board.
                  I am controlling the sensor printing with a transistor circuit which I then make a measurement every 15 minutes.
                  I have laid a cable between the PCB and the sensors.
                  • gbuicoG Offline
                    gbuicoG Offline
                    gbuico
                    @dzjr this is what I also had in mind but... are you using a commercial sensor or you built one yourself?
                    When I say "sensor" I mean the device that is currently in the soil.
                    I checked different commercial sensor and all seem to become unusable in a very short time... this is why I'm really interested in your solution
                    • gbuicoG gbuico
                      dzjrD Offline
                      dzjrD Offline
                      dzjr
                      @gbuico
                      I now use the commercial sensors from the above link.
                      Because the sketch I was still testing the sensors I only tried in a plant or loose on my desk with a glass of water.
                      For the control I make an output of the arduino high and use it to control the transistors.
                      I will try to post a photo tomorrow.
                      dzjr
                      • gbuicoG gbuico
                        Giacomo
                        dzjrD Offline
                        dzjrD Offline
                        dzjr
                        @gbuico 2_1540402589263_IMG_20181023_103053.jpg 1_1540402589223_IMG_20181023_103032.jpg 0_1540402589194_IMG_20181023_103110.jpg
                        11.8k
                        113.2k
