  3. How to tell to an ESP8266 node who is its ESP8266 Wifi gateway? Or each ESP8266 is a gateway for itself?
3 Posts 2 Posters 1.0k Views 2 Watching
  • S Offline
    skassa
    I created an ESP8266 Wifi gateway and everything is working very well.
    Now I need to create a node: mi question is... what the directive to say to the node who is its gateway?
    Or every ESP8266 has to be a gateway for itself?
    I'm using Openhab2.
    This is my sketch, what I'm missing, please? My gateway as 192.168.0.95 as IP address
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "xxxx"
    #define MY_WIFI_PASSWORD "xxx"
    #define MY_IP_ADDRESS 192,168,0,88
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
    #define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
    #define MY_NODE_ID 1
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #include <ArduinoOTA.h>
    #define RELAY1 12
    #define RELAY2 13
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    void before()
    pinMode(RELAY1,OUTPUT);
    pinMode(RELAY2,OUTPUT);
    digitalWrite(RELAY1, loadState(RELAY1)?RELAY_OFF:RELAY_ON);
    digitalWrite(RELAY2, loadState(RELAY2)?RELAY_OFF:RELAY_ON);
    sendSketchInfo("LuciFinestrone", "1.0");
    present(RELAY1, S_BINARY, "luceFinestrone",true);
    //present(RELAY2, S_BINARY, "light2",true);
    if (message.type==V_STATUS) {
    // Change relay state
    digitalWrite(message.sensor, message.getBool()?RELAY_ON:RELAY_OFF);
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    • S skassa
      I'm using Openhab2.
      #define RELAY1 12
      #define RELAY2 13
      void before()
      Welcome to the forum @skassa !
      Yes, normally each esp8266 will be each own gateway. Most controllers support many gateways.
      • S Offline
        skassa
        thank you very much! ;)
