  3. 5V boost converter smoked on first use
8 Posts 4 Posters 1.6k Views 3 Watching
  • G Offline
    G Offline
    grumpazoid
    I have purchased some of the recommended 5V boost boards at https://www.ebay.com/itm/DC-DC-Boost-Converter-Module-Step-Up-Module-1-5V-to-5V-500mA-for-phone-MP4-MP3/381185956688.
    As soon as I have applied approx 4VDC at the input (no load) the board my PSU has hit the current limit. No wanting to give up so easily I then tried an 18650, which produces some nice smoke.
    faulty board or operator error?
    Raspberry Pi 3B - Domoticz + Node Red
    Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
    Arduino Mega, RFLink 433Mhz
    Sonoff/ESP8266/Tasmota switches
    • G grumpazoid
      @grumpazoid I'd say operator error if you connected the power supply incorrectly, faulty board if you connected the power supply correctly ;-)
      • alowhumA Offline
        alowhumA Offline
        alowhum
        It's difficult to say with so little information.
        Do you have a picture of the board?
        How did you wire things up exactly? Are you sure you didn't reverse polarity? Perhaps you're sot supposed to run these without a load?
        • G Offline
          G Offline
          grumpazoid
          wrote on last edited by grumpazoid
          I was wondering about the no load.
          I've just carried our some further investigation . It looks like C3 that is connected between ground and 5V O/P has been shorted out with solder. I guess this would exceed the 500mA specified ;).
          • G Offline
            G Offline
            grumpazoid
            https://i.imgur.com/w38Goat.jpg
            • B Offline
              B Offline
              bjacobse
              This post is deleted!
              • B Offline
                B Offline
                bjacobse
                wrote on last edited by bjacobse
                This seems that E50D might be same as CE8301, but somehow they use a smaller cap, maybe to save money, try to replace C3 with a 100uf 16V electrolyte capacitor
                https://www.sunrom.com/p/5v-dc-dc-boost-step-up
                G 1 Reply Last reply
                • B bjacobse
                  G Offline
                  G Offline
                  grumpazoid
                  @bjacobse Thanks. In the end i removed the solder that was shorting out the capacitor and it now outputs 5V. Not sure how safe it is after the overheat
                  As an experiment I cut the track to take the LED out the circuit. This reduced the current from 2mA down to a few uA.
