  3. 2 dallas temp + 4 relays
39 Posts 6 Posters 6.4k Views 5 Watching
  • MGHaffM
    MGHaffM
    MGHaff
    Has anyone had any progress on sensor node with mysensors + multiple dallas temp sensors and multiple relays combining the codes? Any help would be greatly appreciated. I have been playing with this for a little more than a week off and on. a push in the right direction would be great!
    //#define MY_RF24_CE_PIN 49
    //#define MY_RF24_CS_PIN 53
    #define MY_NODE_ID 6
    #include <OneWire.h>
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    void before()
        pinMode(pin, OUTPUT);
      sensors.begin();
    void presentation() {
      sendSketchInfo("Fireplace interface", "1.1");
      //wait(LONG_WAIT);
         present(i+5, S_TEMP,"Fireplace Temp");
      //wait(SHORT_WAIT);
        present(sensor, S_BINARY);
      //wait(SHORT_WAIT);
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i+5).set(temperature,1));
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
       wait(SLEEP_TIME);
    And here is my serial print
     __  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    26 MCO:BGN:BFR
    28 TSM:INIT
    29 TSF:WUR:MS=0
    36 TSM:INIT:TSP OK
    37 TSM:INIT:STATID=6
    44 TSF:SID:OK,ID=6
    45 TSM:FPAR
    81 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    780 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    785 TSF:MSG:FPAR OK,ID=0,D=1
    2089 TSM:FPAR:OK
    2091 TSM:ID
    2092 TSM:ID:OK
    2094 TSM:UPL
    2097 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2104 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2109 TSF:MSG:PONG RECV,HP=1
    2111 TSM:UPL:OK
    2113 TSM:READY:ID=6,PAR=0,DIS=1
    2117 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2125 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2132 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    2142 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2158 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2165 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Fireplace interface
    2176 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    2183 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2191 TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2198 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2206 TSF:MSG:SEND,6-6-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2211 MCO:REG:REQ
    2215 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2222 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2227 MCO:PIM:NODE REG=1
    2229 MCO:BGN:STP
    2231 MCO:BGN:INIT OK,TSP=1
    Re: [Combining relay and temperature sketch](/topic/6782/combining-relay-and-temperature-sketch)
    dzjrD 1 Reply Last reply
    • MGHaffM MGHaff
      // Wait times
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
        //wait(LONG_WAIT);
        //wait(SHORT_WAIT);
        //wait(SHORT_WAIT);
          #else
         wait(SLEEP_TIME);
       __  __       ____
              |___/                      2.3.1
      26 MCO:BGN:BFR
      28 TSM:INIT
      29 TSF:WUR:MS=0
      36 TSM:INIT:TSP OK
      44 TSF:SID:OK,ID=6
      45 TSM:FPAR
      2089 TSM:FPAR:OK
      2091 TSM:ID
      2092 TSM:ID:OK
      2094 TSM:UPL
      2111 TSM:UPL:OK
      2211 MCO:REG:REQ
      2229 MCO:BGN:STP
      dzjrD
      dzjrD
      dzjr
      @mghaff i had also that problem, i have 4 relay's and 9 dallas sensors.
      if you want to look at it, i made a post of it at https://forum.mysensors.org/topic/9915/plant-watering-node
      prehaps it can help you.
      • rejoe2R
        rejoe2R
        rejoe2
        @mghaff: please avoid double postings. It would have been nice if you'd at least have made a link to this post in the other one you did on that topic here: https://forum.mysensors.org/post/95894.
        @both:
        Imo you should implement a "non-blocking" code, nut just add a sleep or wait at the end of loop or just delete that. Otherwise most likely either your DS18B20 will not deliver any meaningfull measurements or you will not be able to controll your relays...
        Please have a look at https://github.com/mysensors/MySensors/blob/master/examples/EnergyMeterPulseSensor/EnergyMeterPulseSensor.ino as a base example how to implement non-blocking code (path: sleepmode false) or have a look in the sketch I linked to in the answer to the other posting: https://forum.mysensors.org/post/95901
        dzjrD 2 Replies Last reply
        • rejoe2R rejoe2
          @both:
          dzjrD
          dzjrD
          dzjr
          @mghaff my sketch is working good, dallas and moisture readings are good, and i can control my relays.
          rejoe2R MGHaffM 2 Replies Last reply
          • dzjrD dzjr
            rejoe2R
            rejoe2R
            rejoe2
            @dzjr Didn't test that to be honest, but nevertheless, imho it is not a state of the art code design to use wait() nor is it best practice to use much hard-coded steps to do the same thing over and over. Rather use millis() for non-blocking coding and for-loops over comparable stuff, write to and read results from arrays. This keeps coding much easier to read and understand once you got the idea how it works.
            But what in the end counts: It works...
            • dzjrD dzjr
              MGHaffM
              MGHaffM
              MGHaff
              @dzjr I tried to use your sketch to get mine to work and it does not. I might just rebuild it all with new everything and try it again.
              • MGHaffM
                MGHaffM
                MGHaff
                Would this be my blocking loop?
                  //wait(LONG_WAIT);
                  //wait(SHORT_WAIT);
                  //wait(SHORT_WAIT);
                rejoe2R 1 Reply Last reply
                • MGHaffM MGHaff
                    //wait(LONG_WAIT);
                    //wait(SHORT_WAIT);
                    //wait(SHORT_WAIT);
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @mghaff Looks quite ok in the presentation() function.
                  You do not need the "pin" variable in presentation, so you might shorten that to:
                  for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
                  The "pin++" is needed in case you want to switch also the relays to a specific state. If you also want a completely flexible pin-assignment see sketch in https://forum.mysensors.org/topic/4847/multi-button-relay-sketch/33# as a very good example. There also the corresponding PIN is read from an predefined array (has some quite interesting button features also).
                  • MGHaffM
                    MGHaffM
                    MGHaff
                    wrote on last edited by MGHaff
                    I tried to combine a couple other sketches and the closest I got was this one. But it still does not give me values for my Dallas temp. if I try each sketch separate they work fine and present fine with readings. I am a newbie and have luck, yes i call it luck cause my other sensors work just fine.
                    My debug is
                    | / |_ / | ___ _ __ ___ ___ _ __ ___
                    | |/| | | | _
                    \ / _ \ _ \/ __|/ _ \|
                    _/ __|
                    | || | / | | _ \ _ | | _
                    |_
                    , |/ ___|| ||/_/|| |/
                    __/ 2.3.1
                    26 MCO:BGN:BFR
                    120 TSM:INIT
                    121 TSF:WUR:MS=0
                    129 TSM:INIT:TSP OK
                    130 TSM:INIT:STATID=8
                    136 TSF:SID:OK,ID=8
                    138 TSM:FPAR
                    174 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    448 TSF:MSG:READ,0-0-8,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    452 TSF:MSG:FPAR OK,ID=0,D=1
                    2181 TSM:FPAR:OK
                    2182 TSM:ID
                    2183 TSM:ID:OK
                    2185 TSM:UPL
                    2188 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2195 TSF:MSG:READ,0-0-8,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2200 TSF:MSG:PONG RECV,HP=1
                    2203 TSM:UPL:OK
                    2204 TSM:READY:ID=8,PAR=0,DIS=1
                    2209 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2217 TSF:MSG:READ,0-0-8,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2225 TSF:MSG:SEND,8-8-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
                    2233 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2250 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2257 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                    2268 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                    2276 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2283 TSF:MSG:SEND,8-8-0-0,s=21,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2290 TSF:MSG:SEND,8-8-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2298 TSF:MSG:SEND,8-8-0-0,s=21,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2306 TSF:MSG:SEND,8-8-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2314 TSF:MSG:SEND,8-8-0-0,s=21,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2321 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2328 TSF:MSG:SEND,8-8-0-0,s=22,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2336 TSF:MSG:SEND,8-8-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2343 TSF:MSG:SEND,8-8-0-0,s=22,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2352 TSF:MSG:SEND,8-8-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2359 TSF:MSG:SEND,8-8-0-0,s=22,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    2365 MCO:REG:REQ
                    2368 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2374 TSF:MSG:READ,0-0-8,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2379 MCO:PIM:NODE REG=1
                    2382 MCO:BGN:STP
                    Hello world, I am a sensor.
                    2383 MCO:BGN:INIT OK,TSP=1
                    Starting new measurement(s)
                    Sensor #0 says it is -127.00 degrees
                    Sensor #1 says it is -127.00 degrees
                    zzzzZZZZzzzzZZZZzzzz
                       The MySensors Arduino library handles the wireless radio link and protocol
                       between your home built sensors/actuators and HA controller of choice.
                       The sensors forms a self healing radio network with optional repeaters. Each
                       repeater and gateway builds a routing tables in EEPROM which keeps track of the
                       network topology allowing messages to be routed to nodes.
                       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                       Copyright (C) 2013-2015 Sensnology AB
                       Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                       Documentation: http://www.mysensors.org
                       Support Forum: http://forum.mysensors.org
                       This program is free software; you can redistribute it and/or
                       modify it under the terms of the GNU General Public License
                       version 2 as published by the Free Software Foundation.
                       DESCRIPTION
                       Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                       http://www.mysensors.org/build/temp
                       The cool thing about this temperature sensor (pun intended) is thay you can attach multiple Dallas temperature sensors outputs to the same arduino pin. They will all automatically be recognised as separate sensors.
                       At the moment of writing (februari 2017) you need older versions of the Dallas and OneWire libraries. Please check the website or forum to see if this is still the case.
                       Modifications by anonymous user so that it can now simultaneously function as a MySensors repeater.
                    #define MY_RADIO_RF24                            // A 2.4Ghz transmitter and receiver, often used with MySensors.
                    //#define MY_RF24_PA_LEVEL RF24_PA_MIN              // This sets a low-power mode for the radio. Useful if you use the verison with the bigger antenna, but don' want to power that from a separate source. It can also fix problems with fake Chinese versions of the radio.
                    //#define MY_RADIO_RFM69                          // 433Mhz transmitter and reveiver.
                    #define MY_NODE_ID 8
                    // Choose if you want this sensor to also be a repeater.
                    // #define MY_REPEATER_FEATURE                    // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
                    // Are you using this sensor on battery power?
                    //#define BATTERY_POWERED                   // Just remove the two slashes at the beginning of this line if your node is battery powered. It will then go into deep sleep as much as possible. But when it' sleeping it can' work as a repeater.
                    // These defines and variables can be changed:
                    #define COMPARE_TEMP 1                            // Send temperature only if changed? 1 = Yes 0 = No. Can save battery.
                    #define ONE_WIRE_BUS 3                            // Pin where Dallas sensor(s) is/are connected.
                    #define MAX_ATTACHED_DS18B20 16                   // Maximum amount of teperature sensors you can connect to this arduino (16).
                    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    #define NUMBER_OF_RELAYS 3 // Total number of attached relays
                    unsigned long measurementInterval = 30000;        // Time to wait between reads (in milliseconds).
                    // You should not change these:
                    float lastTemperature[MAX_ATTACHED_DS18B20];      // creates an array to hold the previous temperature measurements for each possible sensor.
                    int numSensors = 0;                               // variable to contain the number of found attached sensors.
                    boolean metric = true;                            // old Mysensors??
                    unsigned long measurementSleepTime = 0;           // variable to store the Sleep time if the node is battery powered.
                    // Mysensors settings
                    MyMessage msg(0, V_TEMP);                         // Sets up the message format that we'l be sending to the MySensors gateway later.
                    void before()
                      sensors.begin();                              // Startup up the OneWire library. It allows multiple sensors to talk over one wire (one pin).
                      for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
                      for (int i = 0; i < MAX_ATTACHED_DS18B20; i++) {
                        lastTemperature[i] = 0;  //Pre-filling array with 0's.
                      sensors.setWaitForConversion(false);            // requestTemperatures() will not block current thread
                    #ifdef BATTERY_POWERED
                      measurementSleepTime = measurementInterval;
                      measurementInterval = 1;                    // We'll let Sleep take over the scheduling. When the arduino is asleep, millis doesn't increment anymore (time stops as it were). To fix this, we'l set the measurement interval time to 1, so that when the arduino wakes up it will immediately try to measure again.
                      Serial.begin(115200);                           // for serial debugging.
                      Serial.print("Hello world, I am a sensor. \n ");
                      sendSketchInfo("Temperature Sensor", "1.2");    // Send the sketch version information to the gateway and Controller
                      numSensors = sensors.getDeviceCount();          // Fetch the number of attached temperature sensors
                      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
                        present(i+21, S_TEMP);                          // Present all sensors to controller (16 maximum).
                      // You should not change these variables:
                      static boolean isMeasuring = true;                // Used to indicate when the time is right for a new measurement to be made.
                      static boolean isCalculating = false;                     // Used to bridge the time that is needed to calculate the temperature values by the Dallas library.
                      static unsigned long currentMillis = 0;                   // The millisecond clock in the main loop.
                      static unsigned long previousMeasurementMillis = 0;       // Used to remember the time of the last temperature measurement.
                      static int16_t conversionTime = 0;                        // Used to store the time needed to calculate the temperature from measurements.
                      currentMillis = millis(); // The time since the sensor started, counted in milliseconds. This script tries to avoid using the Sleep function, so that it could at the same time be a MySensors repeater.
                      // Let's measure the temperature
                      if (isMeasuring == true && currentMillis - previousMeasurementMillis >= measurementInterval) { // If we're not calculating, and enough time has passed, we'll start again.
                        isMeasuring = false; // We're measuring, so let's take it off our to-do list.
                        Serial.print("Starting new measurement(s)\n");
                        previousMeasurementMillis = currentMillis; // Mark the time of the initialiation of this measurement.
                        // query conversion time. Apparently it takes a while to calculate.
                        //CONVERSION_TIME = sensors.millisToWaitForConversion(sensors.getResolution());
                        conversionTime = millisToWaitForConversion(sensors.getResolution());
                        isCalculating = true; //Next step is to re-calculate the temperature again.
                      // Next, let's calculate and send the temperature
                      if (isCalculating == true && currentMillis > previousMeasurementMillis + conversionTime ) {
                        isCalculating = false; // check calculating off the to-do list too.
                        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) { // Loop through all the attached temperatur sensors.
                          float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.; // Fetch and round temperature to one decimal
                          Serial.print("Sensor #");
                          Serial.print(i);
                          Serial.print(" says it is ");
                          Serial.print(temperature);
                          Serial.print(" degrees\n");
                          if (temperature != -127.00 && temperature != 85.00) { // avoid working with measurement errors.
                            if (COMPARE_TEMP == 1 && lastTemperature[i] == temperature) {
                              Serial.print("Not sending it though, because it's the same temperature as before.\n");
                            } else {
                              Serial.print("Sending the temperature to the gateway.\n");
                              send(msg.setSensor(i).set(temperature, 1));
                              lastTemperature[i] = temperature; // Save new temperatures to be able to compare in the next round.
                        // Both tasks are done. Time to wait until we should measure again.
                        Serial.print("zzzzZZZZzzzzZZZZzzzz\n");
                        unsigned long quicktimecheck = millis(); // check how much time has passed during the measurement (can be up to 750 milliseconds), and then calculate from that how long to sleep until the next intended measuring time.
                        unsigned long sleeptime = measurementSleepTime - (quicktimecheck - previousMeasurementMillis); //How much time has passed already during the calculating? Subtract that from the intended interval time.
                        sleep (sleeptime);
                        isMeasuring = true;
                    // This function helps to avoid a problem with the latest Dallas temperature library.
                    int16_t millisToWaitForConversion(uint8_t bitResolution)
                      switch (bitResolution) {
                        case 9:
                          return 94;
                        case 10:
                          return 188;
                        case 11:
                          return 375;
                        default:
                          return 750;
                        digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
                    /*Last note : celsius/farenheit in dallatemperature lib is not handled by the metric variable. To get the conversion you need to use C or F functions as below. I've not checked how you handle this in sketch.
                        // returns temperature in degrees C
                        float getTempC(const uint8_t*);
                        // returns temperature in degrees F
                        float getTempF(const uint8_t*);
                        // Get temperature for device index (slow)
                        float getTempCByIndex(uint8_t);
                      float getTempFByIndex(uint8_t);
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      Have a look at at least 2 things in the sketch:
                      The for-loop(s) in presentation should be seperate ones for temp and relays.
                      Imo you try to send out temperature using a different ChildID than in presentation().
                      Additionally, -127 degrees indicates some wiring problems.
                      • rejoe2R rejoe2
                        @both:
                        dzjrD
                        dzjrD
                        dzjr
                        wrote on last edited by dzjr
                        @rejoe2 said in 2 dallas temp + 4 relays:
                        ost in the other on
                        thank you for your tip to adjust the sketch, I am now working with a node for the water meter (partly based on your example of GITHUB) and I think I understand now what you mean.
                        I will adjust the sketch of the example!
                        I still have a wait (3000); in "void before" to start just after the gateway, because I use an RS-485 network.
                        • rejoe2R rejoe2
                          dzjrD
                          dzjrD
                          dzjr
                          @rejoe2
                          To be honest I had to experiment a bit to get it working, but that is probably because I have little "experience" with Arduino code writing.
                          But fortunately here at MySensors we get a lot of help and tips at this forum.
                          • MGHaffM MGHaff
                            My debug is
                            | |/| | | | _
                            _/ __|
                            | || | / | | _ \ _ | | _
                            |_
                            __/ 2.3.1
                            26 MCO:BGN:BFR
                            120 TSM:INIT
                            121 TSF:WUR:MS=0
                            129 TSM:INIT:TSP OK
                            136 TSF:SID:OK,ID=8
                            138 TSM:FPAR
                            2181 TSM:FPAR:OK
                            2182 TSM:ID
                            2183 TSM:ID:OK
                            2185 TSM:UPL
                            2203 TSM:UPL:OK
                            2365 MCO:REG:REQ
                            2382 MCO:BGN:STP
                               DESCRIPTION
                            void before()
                                  Serial.print(i);
                                    } else {
                                sleep (sleeptime);
                                isMeasuring = true;
                                case 9:
                                  return 94;
                                case 10:
                                  return 188;
                                case 11:
                                  return 375;
                                default:
                                  return 750;
                            dzjrD
                            dzjrD
                            dzjr
                            @mghaff
                            in the Dallas temperature library there is also a test sketch, with that you can check of the Dallas sensors are working.
                            My experience with multiple dallas sensors (more than 4) is that de 4K7 resistor not the right choise is, beter to use a 2K2 resisitor.
                            maybe you can look at this forum post for that
                            MGHaffM 1 Reply Last reply
                            • dzjrD dzjr
                              ost in the other on
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @dzjr Good to hear your positive feedback, it's not always easy to decide whether to make some critical remarks or not.
                              Imo, the wait() in before() might only be needed because of the transport-wait-flag, this is not related to RS485 as transport layer.
                              I also use a 3.3kOhm resistor, the right value depends on some more variables than just the number of sensors.
                              • rejoe2R rejoe2
                                MGHaffM
                                MGHaffM
                                MGHaff
                                This post is deleted!
                                • dzjrD dzjr
                                  @mghaff
                                  MGHaffM
                                  MGHaffM
                                  MGHaff
                                  @dzjr If i use the mysensors dallas temp that i use for my pool the sensors work just fine. If i use the relay sketch it works fine Alone. Whenever i combine these two sketches is when i have problems. I have been trying sketches that are working for others with no progress myself. I have even rewired twice. I am no programmer i took 2 classes in college but they r not helping me either.
                                  • rejoe2R rejoe2
                                    MGHaffM
                                    MGHaffM
                                    MGHaff
                                    @rejoe2 When i tried the for loops separate they don't show up at all in my serial. That was the only way to get them to present. I'm trying another sketch that looks more promising for me to build from but it as well doesn't show my temp. I get presentation but no reading.
                                    BTW thanks for the help.
                                    • rejoe2R rejoe2
                                      dzjrD
                                      dzjrD
                                      dzjr
                                      @rejoe2
                                      I have again put a wait (500) in the loop, otherwise the sketch does not read any temperature .....
                                      between
                                          //Dallas temperature sensoren
                                          wait(500);
                                      • TheoLT
                                        TheoLT
                                        TheoL
                                        You calculate the conversion time, but you don't use it. So it makes sense that you won't get any readings without a wait, because the sensors don't get anytime to read. You should wait for the conversionTime before you read the sensors. Which is I'm guessing shorter than 500 ms, but I don't use Dallas temp sensors. So no expert on that.
                                        • TheoLT TheoL
                                          rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @theol said in 2 dallas temp + 4 relays:
                                          Absolutely right.
                                          Conversion time depends on resolution, max is 750ms according to data sheet.
                                          TheoLT 1 Reply Last reply
