  3. [SOLVED] Poor battery life on door sensor
21 Posts 5 Posters 4.0k Views 4 Watching
    martinb
    I’m running a door sensor on an Arduino Pro Mini 3.3v using a 3.2v 1,800 mAh LiFePo4 battery. I’ve removed the LED and voltage regulator and am using an interrupt driven sketch so that the sensor is asleep most of the time. I added some code to also report battery percentage using the Vcc library which uses the 1.1v internal reference of the MCU.
    Everything works great except that the battery life is Very poor. Each time the sensor is triggered I can see the battery percentage falling until the sensor stops responding after about 10 days, at which time the battery is fully discharged.
    Does anyone have any suggestions as to why the sensor is draining the battery so quickly?
    mfalkviddM zboblamontZ YveauxY 3 Replies Last reply
    • M martinb
      Welcome to the MySensors community @martinb !
      Do you have a multimeter? If so, use it to measure how much current the node is using when it is in sleep mode.
      A debug log from the node can be useful as well, to verify that the node is actually sleeping.
      If you share your sketch, we could see if there is something strange in it.
      M 2 Replies Last reply
      • M martinb
        zboblamontZ
        zboblamontZ
        zboblamont
        @martinb If the Node is indeed sleeping, perhaps check the reed circuit for leakage?
        The reeds I've used are fed from the junction of two resistors from Vcc to Int, with the reed closing to ground with a cap across.
          martinb
          @mfalkvidd
          The power usage is showing as around 6.5 mA all the time.
          This is the sketch I am using:
          #include <Vcc.h>
          #define SKETCH_MAJOR_VER "1"
          #define SKETCH_MINOR_VER "0"
          #define PRIMARY_CHILD_ID 3
          #define PRIMARY_BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
          const float VccMin   = 2.5;           // Minimum expected Vcc level, in Volts.
          const float VccMax   = 3.5;           // Maximum expected Vcc level, in Volts.
          Vcc vcc(VccCorrection);
            // Setup the buttons
            pinMode(PRIMARY_BUTTON_PIN, INPUT_PULLUP);
            uint8_t value;
            static uint8_t sentValue=2;
            sleep(5);
            if (value != sentValue) {
               send(msg.set(value==HIGH ? 1 : 0));
               sentValue = value;
            float p = vcc.Read_Perc(VccMin, VccMax);
            sendBatteryLevel(p);
            sleep(PRIMARY_BUTTON_PIN - 2, CHANGE, 0);
          • M martinb
            @martinb Did you build according to https://www.mysensors.org/build/binary ?
            Is the sensor normally-open, or normally-closed; does the door sensor conduct when the door is closed?
            • YveauxY Yveaux
              martinb
              @yveaux
              I did follow the build instructions in your link, with the reed switch on D3. When the door is closed, the reed switch is closed (conducting).
              • zboblamontZ zboblamont
                martinb
                @zboblamont
                The current draw is the same, whether the door is open or closed.
                  martinb
                  @mfalkvidd
                  It looks as if the node is going to sleep OK, as I get this from the nodes debug log:
                  7116 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                  "Sleep node, duration 0 ms, SmartSleep=0, Int1=1, Mode1=1, Int2=255, Mode2=255"
                  7122 TSF:TDI:TSL
                  "Set transport to sleep"
                  • M martinb
                    @mfalkvidd
                    7122 TSF:TDI:TSL
                    @martinb after those lines, there is no debug activity until you open/close the door?
                      martinb
                      @mfalkvidd
                      That's correct, no further log activity until the next change in state of the door
                      • M martinb
                        @yveaux
                        @martinb sorry for asking, but what pin is D3 on a promini?
                        Edit: is it the one opposite A2?
                        • M martinb
                          @zboblamont
                          @martinb is the current draw the same if you disconnect the reed switch?
                          The sketch looks good btw.
                            martinb
                            @mfalkvidd
                            It may be my terminology! It's using digital pin 3 (just marked "3" on the Arduino)
                              martinb
                              @mfalkvidd
                              The current draw is the same whether the reed switch is open or closed. There is a momentary increase after a change (which I assume is the radio drawing additional power to transmit?)
                                martinb
                                @mfalkvidd
                                Yes, I'm using pin 3 which is opposite A2
                                  martinb
                                  I'm beginning to wonder if it's the NRF24L01 that's the problem. I found this post which might explain my continuous power draw.
                                  • M martinb
                                    martinb
                                    @martinb
                                    I replaced the NRF24L01 and now the power consumption has dramatically reduced. Thanks for all the help, as I’m new to MySensors it helped to eliminate other potential issues.
                                    mfalkviddM F 2 Replies Last reply
                                    • M martinb
                                      @martinb
                                      @martinb nice work! Thanks for reporting back.
                                      F 1 Reply Last reply
                                        F
                                        F
                                        FrankVK
                                        wrote on last edited by FrankVK
                                        @mfalkvidd Interesting discussion!
                                        I've got the same issue with a lux sensor based upon BH1750; battery life is limited to 7-10 days (3V, 9900mAh)
                                        I gather that it's not possible to use the interrupt method in this case?
                                        Do you have any suggestions how I can improve battery life?
                                        • M martinb
                                          @martinb
                                          F
                                          F
                                          FrankVK
                                          @martinb Did you replace the NRF24L01 with another NRF24L01? iow was it a bad device?
                                          12.5k
