  3. Small wall outlet sensor node
40 Posts 17 Posters 29.6k Views 12 Watching
  • axillentA axillent
    I've created this to have easiest way to establish environment monitoring across the house
    the idea is to have a wall outlet type plug with everything on board
    and I like to do small things
    The board is less than 50 x 50 mm
    It contains AC-DC power supply with resettable fuse, 3.3V LDO, arduino based on atmega328, radio, LED, and two slots, one for DS18B20 and the second one is for DHT11/DHT22
    The real consumption measured by RMS wattmeter is just 0.3W
    O
    O
    olaeke
    @axillent Very nice! How do you make the circuit board and the soldering of surface mounted components is quit advanced.
    axillentA 1 Reply Last reply
    • greglG gregl
      Really nice!
      I guess the DHT11/22 pin could also be used for PIR sensor or drive a relay/actuator.
      axillentA
      axillentA
      axillent
      @gregl thanks, yes, the same board can be used for any simple 1-2 inputs or 1-2 channel actuator
      I have a plan to create something similar for wall switch in 3-wire and 2-wire versions
      sense and drive
      RJ_MakeR 1 Reply Last reply
        Cool!
        @axillent, did you get a chance to test the MPL-03S-05E I sent you?
        axillentA
        axillentA
        axillent
        @hek thanks
        I read a datasheet and I doubt about where to use it
        it requires quite a big external filter
        the total size will be bigger than normal isolated AC-DC
        The supply based on none-isoleted schema is interested in some projects where you need lower footprint.
        If someone interested I will do a test
        sense and drive
        • axillentA
          axillentA
          axillent
          Here are a schematic and PCB prints
          MySensors.Sens.atmega328-wall.PDF
          sense and drive
          • O olaeke
            axillentA
            axillentA
            axillent
            @olaeke thanks!
            it is half-a-day project including a home-production of the PCB
            but it is a 2-year experience
            I also use a simplified approach for some PCBs, without drilling, using 0.5mm FR4 cut by office scissors and thermo-transfer technology. This one requires about 30-50 minutes for the production circle.depending on etching speed. For example this two side AC lamp off-timer:
            http://radiokot.ru/circuit/digital/automat/81/04.jpg
            http://radiokot.ru/circuit/digital/automat/81/05.jpg
            sense and drive
            • axillentA
              axillentA
              axillent
              Pictures bellow are virtual, under printing
              MySensors.Sens.atmega328-wall modelview-02.JPG MySensors.Sens.atmega328-wall modelview-01.JPG
              sense and drive
              • gaduG
                gaduG
                gadu
                It would be cool with a 90degree angled version as well :)
                • HeinzH
                  HeinzH
                  Heinz
                  Excellent!
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @axillent Your an evil genius! :-)
                    RJ_Make
                    • RJ_MakeR RJ_Make
                      axillentA
                      axillentA
                      axillent
                      @ServiceXp thanks)
                      all this is simple, just a patient work
                      Printed thing is a bit ugly comparing to the virtual one, but it's work is real
                      http://www.youtube.com/watch?v=JG7gutD1oo8
                      sense and drive
                      greglG bjornhallbergB 2 Replies Last reply
                        @ServiceXp thanks)
                        greglG
                        greglG
                        gregl
                        @axillent So very very cool!!
                        as @gadu commented, making one at 90 deg so its very low profile would be even better for places such as hallways where the sensor could be bumped....
                        Really nice!
                        • blaceyB
                          blaceyB
                          blacey
                          @axillent - well done! :+1:
                            @ServiceXp thanks)
                            bjornhallbergB
                            bjornhallbergB
                            bjornhallberg
                            @axillent Very impressive! What is the total cost of the components involved?
                              axillentA
                              axillentA
                              axillent
                              @bjornhallberg it is hard to say
                              the BOM is simple and short
                              but the cost of a single component is dramatically depends on how many your purchase in a single order
                              for example atmega328 purchased in 10pcs will be US1.2 pcs while a single pcs will costs US3-4
                              If it will be an interest I think in production this PCB can cost retail US8-12
                              sense and drive
                              gigiG 1 Reply Last reply
                                gigiG
                                gigiG
                                gigi
                                @axillent
                                very very cool!!
                                Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
                                • nutcrackerN
                                  nutcrackerN
                                  nutcracker
                                  Impressive!
                                  • axillentA
                                    axillentA
                                    axillent
                                    made two more with modified box - it is a bit wider to hold DHT sensor inside
                                    I made a new sketch as a combination of Dalas example and DHT. This new sketch able to detect automatically connected sensors and work according to detection.
                                    One problem I've got. I cannot get DHT working from AC plug. It is working fine been powered from DC and failed during startup been powered from AC :( The most probably the reason is high pulsation (up to 440mV) coming from the supply based on SR10 chip.
                                    Dalas is fine with this but not DHT. Probably some code inside the library holds.
                                    Had to mark each sensor with radio channel because they will work with different gateways
                                    sense and drive
                                      sharath krishna
                                      really cool :) what are u using to convert the AC-DC ? how u doing it ?
                                      axillentA J 2 Replies Last reply
                                      • S sharath krishna
                                        axillentA
                                        axillentA
                                        axillent
                                        @sharath-krishna thanks
                                        yearly in this thread you can find a schematics.
                                        I'm using here SR10. Many alternatives were discussed here http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino
                                        I've found a solution to my problem with DHT. I put delay(500) at the beginning of setup().
                                        This is needed to stabilize DC before initializing DHT.
                                        Alternatively a 4.7uF capacitor can be connected between RESET and GND
                                        sense and drive
                                        • axillentA
                                          axillentA
                                          axillent
                                          This is my combined sketch with automatic detection of connected many DS18B20 and DHT11/22
                                          #define RADIO_CHANNEL		76
                                          #define DS18B20_PIN			A0
                                          #define DS18B20_MAX_SENSORS	8
                                          #define DHT_PIN				A5
                                          #define LED_PIN				5
                                          #define SLEEP_TIME_SEC		60
                                          #include <avr/wdt.h>
                                          #include <avr/interrupt.h>
                                          #include <avr/sleep.h>
                                          #include <OneWire.h>
                                          // DS18B20
                                          OneWire oneWire(DS18B20_PIN);
                                          DallasTemperature	sensors(&oneWire);
                                          MyMessage msgHum(0, V_HUM);
                                          MyMessage msgTemp(0, V_TEMP);
                                          struct {
                                          	struct {
                                          		uint8_t	count;
                                          		float	lastTemperature[DS18B20_MAX_SENSORS];
                                          	} ds18b20;
                                          	struct {
                                          		DHT		sensor;
                                          		uint8_t	count;
                                          		float lastTemp;
                                          		float lastHum;
                                          	} dht;
                                          } var;
                                          ISR(WDT_vect) {
                                          	wdt_disable();
                                          	//delay(500);
                                          	pinMode(LED_PIN, OUTPUT);
                                          	digitalWrite(LED_PIN, HIGH);
                                          	// init mysensors
                                          	var.gw.begin(NULL, AUTO, false, AUTO, RF24_PA_LEVEL,RADIO_CHANNEL);
                                          	// init dalas
                                          	sensors.begin();
                                          	var.ds18b20.count = sensors.getDeviceCount();
                                          	if(var.ds18b20.count > DS18B20_MAX_SENSORS) var.ds18b20.count = DS18B20_MAX_SENSORS;
                                          	// init dht
                                          	digitalWrite(LED_PIN, LOW);
                                          	var.dht.sensor.setup(DHT_PIN);
                                          	float temperature = var.dht.sensor.getTemperature();
                                          	var.dht.count = (isnan(temperature))?0:1;
                                          	var.gw.sendSketchInfo("WallCombined", "1.0");
                                          	// present ds18b20
                                          	for (int i=0; i<var.ds18b20.count; i++) {
                                          		var.gw.present(i+2, S_TEMP);
                                          	if(var.dht.count) {
                                          		var.gw.present(0, S_HUM);
                                          		var.gw.present(1, S_TEMP);
                                          	var.gw.debugPrint(PSTR("Init of combined sensor: %d ds18b20 sensors, %d dht sensors\n"), var.ds18b20.count, var.dht.count);
                                          	for(int i=0; i < var.ds18b20.count + var.dht.count; i++) {
                                          		delay(500);
                                          		delay(1000);
                                          	// Process incoming messages (like config from server)
                                          	var.gw.process();
                                          	if(var.ds18b20.count) sensors.requestTemperatures();
                                          		float temperature = static_cast<float>(static_cast<int>((var.gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                          		if (var.ds18b20.lastTemperature[i] != temperature && temperature != -127.00) {
                                          			var.gw.send(msgTemp.setSensor(i+2).set(temperature,1));
                                          			var.ds18b20.lastTemperature[i]=temperature;
                                          	if(var.dht.count) {
                                          		boolean metric = var.gw.getConfig().isMetric;
                                          		if (isnan(temperature)) {
                                          			var.gw.debugPrint(PSTR("Failed reading temperature from DHT\n"));
                                          		} else if (temperature != var.dht.lastTemp) {
                                          			var.dht.lastTemp = temperature;
                                          			if (!metric) {
                                          				temperature = var.dht.sensor.toFahrenheit(temperature);
                                          			var.gw.send(msgTemp.setSensor(1).set(temperature, 1));
                                          		float humidity = var.dht.sensor.getHumidity();
                                          		if (isnan(humidity)) {
                                          			var.gw.debugPrint(PSTR("Failed reading humidity from DHT"));
                                          		} else if (humidity != var.dht.lastHum) {
                                          			var.dht.lastHum = humidity;
                                          			var.gw.send(msgHum.setSensor(0).set(humidity, 1));
                                          	delay(5000);
                                          	delay(500);
                                          	// sleep
                                          	Serial.flush();
                                          	var.gw.powerDown();
                                          	for(int wdt_count=SLEEP_TIME_SEC; wdt_count > 0; wdt_count--) {
                                          		wdt_enable(WDTO_1S);
                                          		WDTCSR |= (1 << WDIE);
                                          		set_sleep_mode(SLEEP_MODE_PWR_DOWN);
                                          		sleep_enable();
                                          		sei();
                                          		sleep_cpu();
                                          		sleep_disable();
                                          	wdt_disable();
                                          sense and drive
