1.1k Posts 105 Posters 790.5k Views 98 Watching
  • pihomeP
    pihomeP
    pihome
    working on GPIO MySensors Gateway
    1_1575232762237_PiHome GPIO Gateway_v001.png 0_1575232762236_PiHome GPIO Gateway_v001 v3.png
    PiHome - Smart Heating Control
    pihomeP 1 Reply Last reply
    • berkseoB
      berkseoB
      berkseo
      #858
      An updated version of my temperature and humidity sensor with e-ink. Now on nRF52840. Now it is not a module but a device in the case.
      Replaced temperature sensor sht20 -- > > si7020
      Added accelerometer.
      In the near future the project will be posted updated on the website openhardware.io
      0_1575378314466_photo_2019-11-17_21-14-04.jpg 0_1575378328998_photo_2019-11-17_21-13-56.jpg
      1_1575378360290_photo_2019-11-17_21-14-30.jpg 0_1575378360290_photo_2019-11-17_21-14-15.jpg
      Video: https://youtu.be/T66y83lF-xg
      • franz-unixF
        franz-unixF
        franz-unix
        Amazing! 😃
        The case is 3d printable?
        berkseoB 1 Reply Last reply
        • franz-unixF franz-unix
          Amazing! 😃
          berkseoB
          berkseoB
          berkseo
          @franz-unix
          This is made on SLA printer, but should normally print on FDM
          Nca78N franz-unixF 2 Replies Last reply
          • pihomeP pihome
            pihomeP
            pihomeP
            pihome
            @pihome just realized one big blunder, The NSS, MOSI and SCK are not 5V tolerant on RFM69. hence need level converter :(
            i was wondering is there any one ic can can do instead i have to used BSS138 per pin.
            • berkseoB berkseo
              #862
              @berkseo I'm quite interested in a schematic view showing how the epaper gets wired up, because priced just by itself epaper seems like an affordable solution.
              aliexpress.com/item/32962453684.html?spm=a2g0o.productlist.0.0.3e97287fLkUbFb&algo_pvid=9af4e6cf-0e45-470a-925d-b0b1d62212d5&algo_expid=9af4e6cf-0e45-470a-925d-b0b1d62212d5-0&btsid=e444f3d1-9949-4c49-ada6-376ecc83a846&ws_ab_test=searchweb0_0,searchweb201602_8,searchweb201603_55
              or
              https://www.aliexpress.com/item/32810660608.html?spm=a2g0o.detail.1000013.1.10ee3442rep8pS&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=8e948464-a786-4cf4-96ff-86c51f67bf4c
              On the other hand, if one has to rely on adafruit or similar for an epaper breakout board to make use of it, the effective price jumps by around 5-6x or so.
              monteM 1 Reply Last reply
                or
                monteM
                monteM
                monte
                wrote on last edited by monte
                #863
                @neverdie you can use this and this as a reference. No need to buy ready breakout board, if you know how to trace your own.
                • bjacobseB
                  bjacobseB
                  bjacobse
                  https://github.com/dkjonas/Wavin-AHC-9000-mqtt
                  iron and toner transfer, then etched and soldered and finally acrylic spray on cobber so it won't corrode
                  • Nca78N
                    Hello, as it was getting seriously off topic, I moved the discussion related to SLA printing of enclosure to here :
                    https://forum.mysensors.org/topic/10815/printing-enclosures-with-sla-printers
                    Feel free to suggest a better title.
                    • nagelcN
                      nagelcN
                      nagelc
                      wrote on last edited by nagelc
                      #866
                      I've had surprisingly good luck buying cheap parts from Ali-express, but not this time. I bought an NRF52832 iBeacon that supposedly had an SHT30 temperature sensor and KX022 accelerometer. When the parts arrived, neither of those parts were populated. All the beacon has is a push button.
                      I was able to program it to work with MySensors, however. With only SWIO and SWCLK (no txt out), I took @scalz advice (in another topic) and used a J-Link EDU Mini so I could use the RTT app to get printf style debugging. That worked nicely and I learned a new tool.
                      Perhaps I can use the iBeacon button for a remote.
                      • berkseoB
                        berkseoB
                        berkseo
                        #867
                        Yesterday I finished my new project. This is motion sensor (S16-L201D) + light sensor (MAX44009) + temperature and humidity sensor (SI7020). Рowered by nRF52840.
                        4_1576062657237_photo_2019-12-11_00-53-37.jpg 3_1576062657236_photo_2019-12-11_00-44-25.jpg 2_1576062657236_photo_2019-12-11_00-44-25 (4).jpg 1_1576062657236_photo_2019-12-11_00-44-25 (3).jpg 0_1576062657235_photo_2019-12-11_00-44-25 (2).jpg
                        ..upd
                        video - https://youtu.be/cbJYam4jo2g
                        • karlheinz2000K
                          karlheinz2000K
                          karlheinz2000
                          Another 8x8 matrix based display...
                          This is not a real project, just a try to hide the LEDs for better WAF.
                          Print still needs some impovements, but from a little distance you can't see the details.
                          • berkseoB
                            berkseoB
                            berkseo
                            #869
                            My new project is finished today and put to the tests. This is a continuation of my other project - Wireless Module for Capacitive Soil Moisture Sensor v1.2.
                            2_1576668929422_photo_2019-12-16_23-36-50.jpg 1_1576668929421_photo_2019-12-16_23-36-50 (2).jpg 0_1576668929421_photo_2019-12-16_23-36-49.jpg
                            1_1576669149860_photo_2019-11-17_21-12-19.jpg 0_1576669149859_photo_2019-11-17_21-12-13.jpg
                            video: https://youtu.be/2HM0y-D7QNo
                            • alowhumA
                              alowhumA
                              alowhum
                              Wow. All these recent creations are so professional. Really nice!
                              • berkseoB
                                berkseoB
                                berkseo
                                Another project of mine, the second revision is finished today and put to the test. This is an encoder with accelerometer, powered by nRF52811 chip (datasheet).
                                4_1577038273150_photo_2019-12-22_20-39-47 (6).jpg 3_1577038273150_photo_2019-12-22_20-39-47 (5).jpg 2_1577038273150_photo_2019-12-22_20-39-47 (4).jpg 1_1577038273150_photo_2019-12-22_20-39-47 (3).jpg 0_1577038273149_photo_2019-12-22_20-39-47 (2).jpg
                                NeverDieN monteM 2 Replies Last reply
                                • berkseoB berkseo
                                  @berkseo Cool!
                                    @berkseo Cool!
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    @neverdie Thanks for rating. Especially pleased, so as nRF52 for me began with Your those on this forum.
                                    • berkseoB berkseo
                                      monteM
                                      monteM
                                      monte
                                      @berkseo nice piece! Do you mean accelerometer for an encoder, or a physical one? And if the latter, what for is it supposed to be used?
                                      • monteM monte
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        #875
                                        @monte said in What did you build today (Pictures) ?:
                                        I think the use cases quite a lot, I want to implement double tap. For example, there is a dimmable lamp with switching to cold and warm light. Here with the help of a double tap you can control the switch from cold to warm and back. In any case, I think this is a good extension of the functionality.
                                        • berkseoB berkseo
                                          #876
                                          @berkseo :smiley: I'm glad it was helpful. And now you're inspiring me back! That's a virtuous circle if ever there was one.
