1.1k Posts 105 Posters 834.8k Views 98 Watching
  • zboblamontZ
    zboblamontZ
    zboblamont
    First of the winter projects done, just the programming to finish and replacement temperature chips to get (broke the legs off both DS18B20s through clumsiness).
    With mains/battery backup and RTC, it will record boiler start/stop and run times as well as feed/return temperatures, and as an aside the inevitable power cuts which plague this part of the world.
    The MCU plugs into a socketed backplane hot-glued to the back of the box should removal prove necessary, but quite pleased it is sturdy and all fitted into a slim 25mm deep standard (cheap) box.
    • berkseoB
      berkseoB
      berkseo
      #855
      My brand new device on nRF52840. It is a light and shock(vibration) sensor.
      Two sensors are used, max44009 light sensor (1 ua) and lis2dw accelerometer (1 ua).
      The light sensor measures in Lux.
      The shock sensor has five levels of sensitivity.
      Two modes of operation: main (working) mode and command reception mode.
      The sensor accepts settings: the interval of sending data from the light sensor (in minutes), sending recalculated light data from Lux to watts per meter squared(on/off), the sensitivity level of the shock sensor(5 levels, 1 to 5)
      Depending on which sensors are installed on the PCB, it can be used only as a light sensor, only as a shock sensor or both.
      In the near future the project will be posted on openhardware.io
      video (inside view of the sensor, an example of working with a smart home, an example of setting): - https://youtu.be/I2ywIxp-RsE
      • berkseoB berkseo
        #856
        @berkseo this would also be good for monitoring when the trash cans get picked up by the garbage truck. If it has enough range that is. Of course that wouldn't apply to high rise dwellers, but for people in houses it would be a nice perk.
        • pihomeP
          pihomeP
          pihome
          working on GPIO MySensors Gateway
          1_1575232762237_PiHome GPIO Gateway_v001.png 0_1575232762236_PiHome GPIO Gateway_v001 v3.png
          PiHome - Smart Heating Control
          pihomeP 1 Reply Last reply
          • berkseoB
            berkseoB
            berkseo
            #858
            An updated version of my temperature and humidity sensor with e-ink. Now on nRF52840. Now it is not a module but a device in the case.
            Replaced temperature sensor sht20 -- > > si7020
            Added accelerometer.
            In the near future the project will be posted updated on the website openhardware.io
            0_1575378314466_photo_2019-11-17_21-14-04.jpg 0_1575378328998_photo_2019-11-17_21-13-56.jpg
            1_1575378360290_photo_2019-11-17_21-14-30.jpg 0_1575378360290_photo_2019-11-17_21-14-15.jpg
            Video: https://youtu.be/T66y83lF-xg
            • franz-unixF
              franz-unixF
              franz-unix
              Amazing! 😃
              The case is 3d printable?
              berkseoB 1 Reply Last reply
              • franz-unixF franz-unix
                Amazing! 😃
                berkseoB
                berkseoB
                berkseo
                @franz-unix
                This is made on SLA printer, but should normally print on FDM
                Nca78N franz-unixF 2 Replies Last reply
                • pihomeP pihome
                  pihomeP
                  pihomeP
                  pihome
                  @pihome just realized one big blunder, The NSS, MOSI and SCK are not 5V tolerant on RFM69. hence need level converter :(
                  i was wondering is there any one ic can can do instead i have to used BSS138 per pin.
                  • berkseoB berkseo
                    #862
                    @berkseo I'm quite interested in a schematic view showing how the epaper gets wired up, because priced just by itself epaper seems like an affordable solution.
                    aliexpress.com/item/32962453684.html?spm=a2g0o.productlist.0.0.3e97287fLkUbFb&algo_pvid=9af4e6cf-0e45-470a-925d-b0b1d62212d5&algo_expid=9af4e6cf-0e45-470a-925d-b0b1d62212d5-0&btsid=e444f3d1-9949-4c49-ada6-376ecc83a846&ws_ab_test=searchweb0_0,searchweb201602_8,searchweb201603_55
                    or
                    https://www.aliexpress.com/item/32810660608.html?spm=a2g0o.detail.1000013.1.10ee3442rep8pS&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=8e948464-a786-4cf4-96ff-86c51f67bf4c
                    On the other hand, if one has to rely on adafruit or similar for an epaper breakout board to make use of it, the effective price jumps by around 5-6x or so.
                    monteM 1 Reply Last reply
                      or
                      monteM
                      monteM
                      monte
                      wrote on last edited by monte
                      #863
                      @neverdie you can use this and this as a reference. No need to buy ready breakout board, if you know how to trace your own.
                      • bjacobseB
                        bjacobseB
                        bjacobse
                        https://github.com/dkjonas/Wavin-AHC-9000-mqtt
                        iron and toner transfer, then etched and soldered and finally acrylic spray on cobber so it won't corrode
                        • Nca78N
                          Hello, as it was getting seriously off topic, I moved the discussion related to SLA printing of enclosure to here :
                          https://forum.mysensors.org/topic/10815/printing-enclosures-with-sla-printers
                          Feel free to suggest a better title.
                          • nagelcN
                            nagelcN
                            nagelc
                            wrote on last edited by nagelc
                            #866
                            I've had surprisingly good luck buying cheap parts from Ali-express, but not this time. I bought an NRF52832 iBeacon that supposedly had an SHT30 temperature sensor and KX022 accelerometer. When the parts arrived, neither of those parts were populated. All the beacon has is a push button.
                            I was able to program it to work with MySensors, however. With only SWIO and SWCLK (no txt out), I took @scalz advice (in another topic) and used a J-Link EDU Mini so I could use the RTT app to get printf style debugging. That worked nicely and I learned a new tool.
                            Perhaps I can use the iBeacon button for a remote.
                            • berkseoB
                              berkseoB
                              berkseo
                              #867
                              Yesterday I finished my new project. This is motion sensor (S16-L201D) + light sensor (MAX44009) + temperature and humidity sensor (SI7020). Рowered by nRF52840.
                              4_1576062657237_photo_2019-12-11_00-53-37.jpg 3_1576062657236_photo_2019-12-11_00-44-25.jpg 2_1576062657236_photo_2019-12-11_00-44-25 (4).jpg 1_1576062657236_photo_2019-12-11_00-44-25 (3).jpg 0_1576062657235_photo_2019-12-11_00-44-25 (2).jpg
                              ..upd
                              video - https://youtu.be/cbJYam4jo2g
                              • karlheinz2000K
                                karlheinz2000K
                                karlheinz2000
                                Another 8x8 matrix based display...
                                This is not a real project, just a try to hide the LEDs for better WAF.
                                Print still needs some impovements, but from a little distance you can't see the details.
                                • berkseoB
                                  berkseoB
                                  berkseo
                                  #869
                                  My new project is finished today and put to the tests. This is a continuation of my other project - Wireless Module for Capacitive Soil Moisture Sensor v1.2.
                                  2_1576668929422_photo_2019-12-16_23-36-50.jpg 1_1576668929421_photo_2019-12-16_23-36-50 (2).jpg 0_1576668929421_photo_2019-12-16_23-36-49.jpg
                                  1_1576669149860_photo_2019-11-17_21-12-19.jpg 0_1576669149859_photo_2019-11-17_21-12-13.jpg
                                  video: https://youtu.be/2HM0y-D7QNo
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Wow. All these recent creations are so professional. Really nice!
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      Another project of mine, the second revision is finished today and put to the test. This is an encoder with accelerometer, powered by nRF52811 chip (datasheet).
                                      4_1577038273150_photo_2019-12-22_20-39-47 (6).jpg 3_1577038273150_photo_2019-12-22_20-39-47 (5).jpg 2_1577038273150_photo_2019-12-22_20-39-47 (4).jpg 1_1577038273150_photo_2019-12-22_20-39-47 (3).jpg 0_1577038273149_photo_2019-12-22_20-39-47 (2).jpg
                                      NeverDieN monteM 2 Replies Last reply
                                      • berkseoB berkseo
                                        @berkseo Cool!
                                          @berkseo Cool!
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @neverdie Thanks for rating. Especially pleased, so as nRF52 for me began with Your those on this forum.
                                          12.5k
