1.1k Posts 105 Posters 790.5k Views 98 Watching
  • pihomeP pihome
    working on GPIO MySensors Gateway
    1_1575232762237_PiHome GPIO Gateway_v001.png 0_1575232762236_PiHome GPIO Gateway_v001 v3.png
    pihomeP
    pihomeP
    pihome
    @pihome just realized one big blunder, The NSS, MOSI and SCK are not 5V tolerant on RFM69. hence need level converter :(
    i was wondering is there any one ic can can do instead i have to used BSS138 per pin.
    PiHome - Smart Heating Control
    • berkseoB berkseo
      An updated version of my temperature and humidity sensor with e-ink. Now on nRF52840. Now it is not a module but a device in the case.
      Replaced temperature sensor sht20 -- > > si7020
      Added accelerometer.
      In the near future the project will be posted updated on the website openhardware.io
      0_1575378314466_photo_2019-11-17_21-14-04.jpg 0_1575378328998_photo_2019-11-17_21-13-56.jpg
      1_1575378360290_photo_2019-11-17_21-14-30.jpg 0_1575378360290_photo_2019-11-17_21-14-15.jpg
      Video: https://youtu.be/T66y83lF-xg
      #862
      @berkseo I'm quite interested in a schematic view showing how the epaper gets wired up, because priced just by itself epaper seems like an affordable solution.
      aliexpress.com/item/32962453684.html?spm=a2g0o.productlist.0.0.3e97287fLkUbFb&algo_pvid=9af4e6cf-0e45-470a-925d-b0b1d62212d5&algo_expid=9af4e6cf-0e45-470a-925d-b0b1d62212d5-0&btsid=e444f3d1-9949-4c49-ada6-376ecc83a846&ws_ab_test=searchweb0_0,searchweb201602_8,searchweb201603_55
      or
      https://www.aliexpress.com/item/32810660608.html?spm=a2g0o.detail.1000013.1.10ee3442rep8pS&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=8e948464-a786-4cf4-96ff-86c51f67bf4c
      On the other hand, if one has to rely on adafruit or similar for an epaper breakout board to make use of it, the effective price jumps by around 5-6x or so.
      monteM 1 Reply Last reply
        or
        monteM
        monteM
        monte
        wrote on last edited by monte
        #863
        @neverdie you can use this and this as a reference. No need to buy ready breakout board, if you know how to trace your own.
        • bjacobseB
          bjacobseB
          bjacobse
          https://github.com/dkjonas/Wavin-AHC-9000-mqtt
          iron and toner transfer, then etched and soldered and finally acrylic spray on cobber so it won't corrode
          • Nca78N
            Hello, as it was getting seriously off topic, I moved the discussion related to SLA printing of enclosure to here :
            https://forum.mysensors.org/topic/10815/printing-enclosures-with-sla-printers
            Feel free to suggest a better title.
            • nagelcN
              nagelcN
              nagelc
              wrote on last edited by nagelc
              #866
              I've had surprisingly good luck buying cheap parts from Ali-express, but not this time. I bought an NRF52832 iBeacon that supposedly had an SHT30 temperature sensor and KX022 accelerometer. When the parts arrived, neither of those parts were populated. All the beacon has is a push button.
              I was able to program it to work with MySensors, however. With only SWIO and SWCLK (no txt out), I took @scalz advice (in another topic) and used a J-Link EDU Mini so I could use the RTT app to get printf style debugging. That worked nicely and I learned a new tool.
              Perhaps I can use the iBeacon button for a remote.
              • berkseoB
                berkseoB
                berkseo
                #867
                Yesterday I finished my new project. This is motion sensor (S16-L201D) + light sensor (MAX44009) + temperature and humidity sensor (SI7020). Рowered by nRF52840.
                4_1576062657237_photo_2019-12-11_00-53-37.jpg 3_1576062657236_photo_2019-12-11_00-44-25.jpg 2_1576062657236_photo_2019-12-11_00-44-25 (4).jpg 1_1576062657236_photo_2019-12-11_00-44-25 (3).jpg 0_1576062657235_photo_2019-12-11_00-44-25 (2).jpg
                ..upd
                video - https://youtu.be/cbJYam4jo2g
                • karlheinz2000K
                  karlheinz2000K
                  karlheinz2000
                  Another 8x8 matrix based display...
                  This is not a real project, just a try to hide the LEDs for better WAF.
                  Print still needs some impovements, but from a little distance you can't see the details.
                  • berkseoB
                    berkseoB
                    berkseo
                    #869
                    My new project is finished today and put to the tests. This is a continuation of my other project - Wireless Module for Capacitive Soil Moisture Sensor v1.2.
                    2_1576668929422_photo_2019-12-16_23-36-50.jpg 1_1576668929421_photo_2019-12-16_23-36-50 (2).jpg 0_1576668929421_photo_2019-12-16_23-36-49.jpg
                    1_1576669149860_photo_2019-11-17_21-12-19.jpg 0_1576669149859_photo_2019-11-17_21-12-13.jpg
                    video: https://youtu.be/2HM0y-D7QNo
                    • alowhumA
                      alowhumA
                      alowhum
                      Wow. All these recent creations are so professional. Really nice!
                      • berkseoB
                        berkseoB
                        berkseo
                        Another project of mine, the second revision is finished today and put to the test. This is an encoder with accelerometer, powered by nRF52811 chip (datasheet).
                        4_1577038273150_photo_2019-12-22_20-39-47 (6).jpg 3_1577038273150_photo_2019-12-22_20-39-47 (5).jpg 2_1577038273150_photo_2019-12-22_20-39-47 (4).jpg 1_1577038273150_photo_2019-12-22_20-39-47 (3).jpg 0_1577038273149_photo_2019-12-22_20-39-47 (2).jpg
                        NeverDieN monteM 2 Replies Last reply
                        • berkseoB berkseo
                          @berkseo Cool!
                          berkseoB 1 Reply Last reply
                            @berkseo Cool!
                            berkseoB
                            berkseoB
                            berkseo
                            @neverdie Thanks for rating. Especially pleased, so as nRF52 for me began with Your those on this forum.
                            • berkseoB berkseo
                              monteM
                              monteM
                              monte
                              @berkseo nice piece! Do you mean accelerometer for an encoder, or a physical one? And if the latter, what for is it supposed to be used?
                              • monteM monte
                                berkseoB
                                berkseoB
                                berkseo
                                #875
                                @monte said in What did you build today (Pictures) ?:
                                I think the use cases quite a lot, I want to implement double tap. For example, there is a dimmable lamp with switching to cold and warm light. Here with the help of a double tap you can control the switch from cold to warm and back. In any case, I think this is a good extension of the functionality.
                                • berkseoB berkseo
                                  #876
                                  @berkseo :smiley: I'm glad it was helpful. And now you're inspiring me back! That's a virtuous circle if ever there was one.
                                    Great idea @sundberg84
                                    This prompted me to finally get started on something that I've put off for far too long, especially considering how little work it was.
                                    I'm still using dupont wires to connect my radios, despite better solutions such as the easypcb being available. But this quick little trick makes it easier to switch the radio modules.
                                    https://youtu.be/Jeg0kS9AcgY
                                    You'll need:
                                    • Dupont female-female wires (I use 10cm), https://www.aliexpress.com/item/Free-Shipping-1lot-40pcs-lot-10cm-2-54mm-1pin-femal-to-femal-jumper-wire-Dupont-cable/32329983091.html
                                    • 4x2 jumper wire connector/header from a 620 pcs kit, https://www.aliexpress.com/item/620-Pcs-1-Set-Jumper-Wire-Cable-Pin-Header-Connector-Kit-Male-Crimp-Female-Pin-Terminal/32816829548.html
                                    • NRF24L01+ radio module, https://www.aliexpress.com/item/Free-shiping-best-prices-10pcs-lot-NRF24L01-NRF24L01-Wireless-Module-2-4G-Wireless-Communication-Module/674686536.html
                                    • Small screwdriver
                                    In the future, I plan to build the other end of the connector for Pro Mini and Rasbperry Pi.
                                    F
                                    F
                                    Fleurros
                                    Banned
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      Another one of my brand new device is ready, today I finished the case for this device. This is a motion sensor on the S16-L221D-2. Also added a temperature and humidity sensor, it can be sht20-21, si7020-21, hd 1080, perhaps something else, now there are many sensors in such cases. Powered by a "nuclear" battery 2/AA (14250) 3.6 V. Powered by a chip nRF52811. I added support for this chip to the sandeepmistry boards.
                                      Soon this sensor will be available at openhardware.io
                                      0_1577561983260_photo_2019-12-28_20-18-44 (4).jpg 0_1577561989372_photo_2019-12-28_20-18-44.jpg 0_1577562008909_photo_2019-12-28_20-18-44 (3).jpg 0_1577562012521_photo_2019-12-28_20-18-44 (2).jpg 0_1577562018864_photo_2019-12-28_20-18-44 (5).jpg 0_1577562042372_IMG_20191228_221152_2.jpg
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        Not hardware though, but I'm working on my dashboard solution for a wallmounted tablet.
                                        I kind of already have this working in angular, but lately I have switched to react (joined a new project at work where they use react for frontend development), so wanted to see how "easy" it would be to create a something similar to my angular dashboard, but in react instead.
                                        Made a small screencast of the dashboard, and are now playing around with "fully kiosk browser" on an old android tablet. Next step is to create a wooden frame, so it doesn't look like a tablet that is mounted on the wall (for WAF'ines).
                                        https://youtu.be/MmYAwbs_k-M
                                        All data, except weather forecast and channel lists, is from my mqtt broker, where I use mqtt over websockets.I have a bunch of python scripts, and a node-red instance, to wrap things up for the display, and also do a lot of magical stuff, like turning on TV and amplifiers automatically when casting youtube, and then turn the TV etc. off again, when I haven't streamed anything for a couple of minutes. (So the kids doesn't forget to turn off the TV when they're finished watching cartoons)
                                        • sundberg84S
                                          sundberg84S
                                          #880
                                          Today i fired up my controller after 6 months houserenovation. Upgraded to new 2.3 version and instantly some old nodes started reporting again 😀. Yes, there were some without battery but several temp and binary nodes survived 6 months without supervision. 0_1577797816208_1577797801960606374482477635708.jpg
