  3. 💬 The Harvester: ultimate power supply for the Raybeacon DK
raytrailssolarmpptusbchargerpower supplyteg
219 Posts 4 Posters 59.1k Views 4 Watching
    Here's another one: https://patents.google.com/patent/US20170133938
    He claims the startup power is just 100nW. For contrast, TI says their BQ255xx chip requires 15 uW. i.e. an entire order of magnitude more. Sounds too good to be true, doesn't it? Which leads me to wonder: just how well are patents vetted before they're granted? Might it still be granted even if the author never made a a circuit that performed anywhere near as well as the patent claims? Is anyone even checking?
    By the way, on a different topic, this might interest you: https://www.mouser.com/ProductDetail/426-DFR0579 It's a $12.90, 30mmx30mm, fully assembled breakout for the SPV1050, configured as a boost converter.
    Mishka
    wrote on last edited by Mishka
    #138
    @NeverDie said in 💬 The Harvester: ultimate power supply for the Raybeacon DK:
    What's interesting about the circuit is that it uses the self-resonant converter together with a MOSFET (HEMT is recommended) which is closed at low voltage. There, the 1:1 transformer is used to bump the gate voltage and thus fully open the MOSFET when it reaches the threshold value Vth (the paper notices it at 120 mV, but for the a-Si cell it might be at 2.6V). The more it opened - the more voltage at the gate. This results in discharge of the input capacitor to the load until the gate capacitor voltage + the second inductor voltage won't drop below Vth. The input capacitor cut-off voltage could be configured to 1.8V so it will charge faster on the next cycle.
    The patent mentions 0.1V x 1µA = 1nW startup power. Upon charge of the input capacitor, the leakage current will be at about tens on nanoamps. Perhaps rest of the harvester circuit consumes something too. Obviously, when it's going to discharge the inductors will cut some efficiency, but it's worth it anyway.
    Looks interesting!
    Well, a patent is just an exclusive right to the invention, and AFAIK there is no practical consideration neither verification of the patent subject. All that's checked is the invention wasn't patented before.
    Yeah, it's nice! Thanks for the link! I think we here will be able to offer something interesting too: both boost & buck-boost combo board with USB and LDO, 25 mm diameter. Now in trendy corona-shaped profile from the OSHPark :-)
    Unfortunately, can't assemble them due to the quarantine :-(
    • M Mishka
      Looks interesting!
      #139
      @Mishka said in 💬 The Harvester: ultimate power supply for the Raybeacon DK:
      Wait. He reccommended a PHEMT for part 315 and an E-PHEMT for part 445:
      The self-starting oscillator 445 utilizes a transistor. In one embodiment, the transistor is an E-PHEMT (Enhancement Mode Pseudomorphic High Electron Mobility Transistor) transistor, as the switching device to form a resonant step-up oscillator using a coupled inductor (the left and right inductors, ratio 1:1, 1 mH) and a resistor and capacitor in parallel at transistor's gate. The self-starting oscillator 445 is in series with the inductors. The transistor is normally off at zero gate voltage which would be the case with the two solar cells in complete darkness. The transistor's threshold voltage is very low and has a value greater than 110 millivolts.
      [0065]
      The E-PHEMT transistor 445 can be described as having the combined characteristics of a FET (Field Effect Transistor) and BJT (Bipolar Junction Transistor) and is used primarily for high-speed RF amplifiers in cell phones or other communication gear, but it is also an excellent candidate for low voltage self-starting oscillators like the oscillator 445.
      I'm confused. Aren't 315 and 445 simply different aliases for the same physical component? 315 at a higher abstraction layer and 445 at the detailed layer? Except... isn't an E-PHEMT different from a PHEMT? So, they aren't aliases for the same part after all? Or, maybe they are the same, but 315 refers to a different potential embodiment than 445? Or... do HEMT, PHEMT, and E-PHEMT all mean the same thing?
      By the way, I mispoke in my earlier post. 100nW is actually two orders of magnitude lower than TI's 15uW cold start minimum for TI's flagship energy harvester. If the patented circuit now under discussion here really does perform as well as it claims, then that makes it all the more impressive.
      If it needs 100nw of continuous power, then it's of little use to me. If, instead, it can draw the needed power from harvested energy stored on a capacitor--and then collapse after the cap power runs out--then, cool! That I could use.
      If only there were a proper LTSpice simulation of the circuit already available....
      Unfortunately, can't assemble them due to the quarantine 😞
      You mean their automated assembly is off-line, or that you can't source all the parts you need due to the quarantine, and so you can't DIY the soldering even if you wanted to?
      BTW, I like your PCB homage to the caronavirus. Subtle, yet amusing!
        [0065]
        Mishka
        I see the components are numbered through all the figures in the form XYY where X is the figure number, and YY is the component number. Such, 115, 315, and 415 are referring to the energy harvesting circuit. The circuit contains x20 resonant DC-DC converter, and x45 do reference the transistor or crystal oscillator.
        An enhancement mode transistor (N-channel MOSFET or an E-HEMT) is required because it has to be closed at zero bias.
        Oh, my, it's 100 times different, rght. I'm still not used to the numbers and feel that if we take a couple more steps, we will go to the quantum level :laughing:
        :hole: :walking:
        Just can't get to the soldering station, it's closed in the office with some other components until May.
        All credits go to OSHPark which didn't bother to remove the panel tabs :-D
        • M Mishka
          :hole: :walking:
          #141
          LOL. In that case, strap yourself in Dorothy, because Kansas is about to go bye-bye: here's a voltage detector which claims to have a quiescent current of less than 6 pico-amps!
          ! https://www.bristol.ac.uk/media-library/sites/engineering/research/eem-group/zero-standby/UB20M_Datasheet_Rev.1.5.pdf
          The only thing which appears to tarnish that claim is that it has a leakage current of 100 pico-amps. Even so, though, I'm not aware of anything else that even comes close to that. If it does what it claims to do, then I'm imagining we could harvest energy from even a very dark environment and yet still be net positive on harvested energy (without the control hardware consuming all of it and then some). :-)
          Unfortunately, their UB20X chip doesn't seem to be stocked anywhere. I sent an email to the company yesterday to inquire about how to buy it, but so far I haven't heard anything back yet. I hope they're still in business.
            Mishka
            @NeverDie Well :-)
            What can I say? Only that the PDF is here. They seem achieved this ridiculous leakage with careful transistor selection. Very nice!
            • M Mishka
              @NeverDie Well :-)
              #143
              @Mishka Thank you very much for that link. Gosh, it sure would have been awesome to have such an ultra low power wake-on radio such as that described there. Unfortunately, I'm still getting no reply to even my second email attempt at contacting the company. Maybe they'll reply later, but for now I'm going to assume they are closed for business during the Caronavirus attack.
              Fortunately, Figure 5 in the paper you linked shows an equivalent transistor layout for the voltage detector. It lacks a BOM with part numbers, but I'll nonetheless take a quick run at trying to simulate it in LTSpice--maybe I'll get lucky. If you were in my shoes, exactly which simulated transistors/mosfets would you be trying?
              As for alternatives to the UB20M, the nearest I could find is this:
              https://www.ablic.com/en/doc/datasheet/photo_ic/S5470_E.pdf
              which, admittedly, isn't as nice because it is an ultra low current detector rather than a low voltage detector. Its quiescent current is higher than the UB20m, but it appears to be still quite low in absolute terms. What the S5470 does have that the UB20M lacks though is that the s5470 is well stocked at Digikey and similar places. :)
              Have you run across any other parts that might fit the UB20M role?
              Edit: I put Figure 5 into LTSpice. I could get it to generate the ~100mv reference voltage, but it doesn't appear to switch anything nor "detect" and then switch anything either. So, maybe there is more to the circuit that what they are showing. Given the circumstances of not being able to acquire their UB20M, it's a bit of a let down. :(
              M 2 Replies Last reply
                #144
                The last option I can think of would be to try these special mosfets from Advanced Linear Devices:
                https://www.aldinc.com/pdf/ALD110802.pdf
                The gate leakage and drain source leakage combined is typically just 13pa. They can switch at around 0.2v, which, I suppose (?), could be viewed as a kind of voltage detector. Maybe in that sense, then, it even outperforms Bristol's UB20M? Also, unlike the UB20M, they seem to be relatively available through digikey, mouser, etc.
                  Mishka
                  #145
                  That's true. The components selection is the hard part. I din't find anything, but the MOSFET arrays by ALD, and I see you've found them already.
                  It seems the most of discrete elements are tied to nanoamps and only few are diving to picoamps area. For example, the Nexperia settled it to 25 nA, as well as the TI does. But for some selected integrated circuits there are the picoamps, and some opamps may draw only femtoamps which is impressive. There is also the nice article on possible design issues - quite surprising - when building such a uber-low-power circuit - https://www.edn.com/design-femtoampere-circuits-with-low-leakage-part-one/
                  Yeah, that's it. And the cool part is that the ALD offers 2V*200nA=400nW energy harvesters which work very similar to those we're trying to design here - http://www.aldinc.com/pdf/EH300.pdf
                  Unfortunately, still not sufficient to run your a-Si 80nA solar panel.
                  It has to switch the VOUT on as soon as the VINL will be high enough to close the MN5 and pull down the VREF thus resetting the triggers and causing them to produce the VOUT.
                  I've put it into KiCad and immediately failed with component selection. In addition to issues with the search of a low-current MOSFETs, the ngspice has incomplete support for the modern PSPICE models. And create own models is a cumbersome task :-(
                  After trial and errors I've ended up switching to ngspice internal models. After some trivial tuning the circuit started to work. I've just added input (storage) capacitor and have attached a simple load (switched with an additional N-MOS) to get the simple harvester work.
                  On VinL≥2V input capacitor is discharged to load R2 until VinL will drop below 1V. Both voltages are configured via MOSFET gate thresholds.
                  For details please take a look to the eeschema file - https://drive.google.com/file/d/1O8aVj7ZzjG1TNdTJOce4i2P65X-aRLgB/view?usp=sharing.
                  Voltages:
                  Input current I (via R1) in dependency of input voltage. I(R1) = 3V/100M = 33nA to simulate the a-Si cell.
                  I don't know how much current the circuit will draw in real life, but taking in account low voltage source (please note, datasheets mention 25nA as upper threshold) perhaps there are some chances to fit into the a-Si cell current budged.
                    Mishka
                    The UB20M is hard to beat. But there's another sub-nanoamp option: https://www.vishay.com/docs/66597/sip32431.pdf
                    • M Mishka
                      ...But there's another sub-nanoamp option: https://www.vishay.com/docs/66597/sip32431.pdf
                      How would the vishay fit into it? Are you thinking you would switch it on-off using an ALD mosfet, or ...?
                      • M Mishka
                        Voltages:
                        @Mishka Nice work getting it to switch. If I'm reading your graphs right, though, it look as though we're back to the land of 10+ nanoamps as opposed to the ~106 picoamps or so of the UB20M voltage detector, even though you're using the same transistor circuit as they are?
                          Mishka
                          #149
                          @NeverDie I've finally managed to make a readable image of the circuit. For our convenience, here it is:
                          The circuit self consumption is comprised of MOSFETs leakage current, and current required to charge the C1 capacitor. Regarding C1 the startup current may be arbitrary low, but sufficient to charge it eventually. After that it won't require too much to sustain the circuit. For this particular ngspce model (where MOSFETs leakage is really low) those are picoamps indeed:
                          Those 30nA you've mentioned in my previous post are due to charging the C2 storage capacitor and is actually limited by R1=100MOhm resistor installed solely to emulate the weak a-Si panel. I.e. for one gigohm resistor it will not go higher than 3nA.
                          Of course, the model itself is far from being optimal and could be improved.
                            Mishka
                            I have no idea. Bipolar based opamps have similar characteristics, as well as the UB20M which seems build using FETs only.
                            :man-shrugging:
                            • M Mishka
                              #151
                              @Mishka Fantastic!
                              I tried replicating it in LTSpice, but no joy as of yet using just the generic LTSpice parts. The magic must be in those ".model" statements, which I haven't yet entered.
                              What value are you using for your input voltage? It seems that a lot of it is getting dropped across the 100meg resistor, leaving not much left over for most of the circuit.
                              • M Mishka
                                @Mishka First attempt with the ltspice directives yields just a flatline of about 1 volt at the output:
                                Perhaps I need to switch to the same spice as what you are using....
                                  @Mishka Fantastic!
                                  Mishka
                                  #153
                                  @NeverDie Oh, right. For the voltage source there is the 3V pulse defined as follows:
                                  PULSE (0 3 20m 1u 1u 60 0)
                                  Reads like "start pulse from 0V to 3V, after 20ms timeout, 1us raise time, 1us down, keep it on for 60 seconds". This helped to examine how the circuit starts. But the circuit has to start with flat 3V input anyway.
                                  All MOSFETs are defined with MOS level 3 model, zero-bias threshold (vto) set to ±2 V, transconductance (kp) to 50 mA/V^2 to minimally reproduce a real transistor. Both drain and source has 1 Ohm resistance. Please note, the controlled NFET has lower voltage threshold at 1 V - this defines lowest VinL voltage. The rest of parameters can be derived from the ngspice manual, section 11.2.
                                  I expect that the ngspice and the LTSPICE may have different directives to setup the circuit :-(
                                  Also, you may want to drop the C3, M8 and R2 thus leaving the circuit very similar to that one in the paper. The R1 still be used to limit input current, and the C2 will help to model raising voltage.
                                  Also, does the .tran 10k means 10k milliseconds?
                                  • M Mishka
                                    #154
                                    Actually 10,000 seconds. :astonished: That was just me throwing in a high enough number such that if there were ever to be observed an effect, I figure it would have shown up within 10,000 seconds. :blush:
                                    I was playing around with an alternative to the original model, the better to understand how the original model worked, and I came up with something not as great, but maybe (someday, somewhere) it might be useful anyway if used as a trigger for one of the the ALD 20mv mosfets:
                                    This is a voltage sweep simulation to show what happens at different input voltages. As you can see from the chart, the voltage on the output (the green line) stays pretty close to 0v up until it reaches around 22mv, at which point it it jumps up about 22mv in value. At that time about 6na of current is being conducted through R1 (the blue line in the graph), and so that is the total amount of current being consumed by the circuit.
                                    20mv is the minimum that the LTC3108 can startup and function at, so that is why I'm focused at such a low value.
                                    It's quite an easily adjustable voltage "detector": using smaller values for R2 leads to higher trigger voltages, as well as higher voltages on the output. Of course, they also lead to higher currents, so maybe not so relevant to the matter at hand. However, if you ever need a voltage trigger that you can set to any value in some other context where current draw is not such a pressing concern, this might be an option.
                                    Also, about 2/3 the current is being consumed by R2. If there were some other way to get a similar effect, but utilizing even less current, then that would be an improvement. Perhaps that's what the Bristol circuit manages to do. Perhaps choking off the current by using a high value for R1 (as in Mishka's simulation) and using a semiconductor of some kind in place of R2 would do the business.
                                    Edit: And just now noticing that by increasing the value of R1, the threshold for the detection voltage can be raised while keeping the current consumed in the single nanoamp digits:
                                    In this case, with the higher threshhold, it might well be a useful complement to a 20mv ALD mosfet.
                                    Edit2: Breaking out the resistance still further yields even more useful results: a larger transition voltage and even fewer nanoamperes.
                                    These are just a few random attempts. A more methodical push would probably yield something better. I suppose trying it next with specific simulated components rather than whatever the simulator's generic components are would better inform whether a real world circuit could be built.
                                      #155
                                      Answering my own question, I designed a circuit using "real" mosfets from the generic LTSpice library and got a nice snap transition on a "voltage detector", all while drawing less than 300picoamps:
                                      So, that's a simulated proof of concept. Now I just need to pull the trigger voltage down to a lower number, and I suspect that may involve using mosfets that aren't in the generic LTSpice catalog.
                                      Edit1: Ignore this particular circuit diagram. It turns out to be reducible to a much simpler circuit that draws even less current. I'm leaving it posted as a reference point for my own project tracking, but if not for that I would delete it.
                                      Edit2: Lately LTSpice has, more often than not, failed to converge now that I have it simulating "real" mosfets. As a result I've started to look into TI's Tina circuit simulator, which AFAIK is also built on a SPICE platform. Although it's too soon to draw completely fair apples-to-apples comparisons, my initial impression is that TI Tina is much, much faster than LTSpice and also much better at converging. I'll update if that opinion changes.
                                      Edit3: I've upgraded to using NTJS3151P and NTJS3157N as the simulation mosfets because they have lower threshold voltages and mouser has SPICE models for them that are free to download. I'm not yet endorsing them though, because it's just too early to say. They are just my first attempt, and there may be (probably are) better choices to be found. I'm finding it quite easy to import SPICE component models into TINA TI. I notice that some manufacturers, like Diodes Inc., actually rank their SPICE models as to how realistic they are.
                                      @Mishka Which mosfets are you simulating? Head's up: I'd encourage you to find some real world simulated mosfets (you'll have to eventually anyway), because I'm found that, at least in LTSpice, the generic mosfets behave much, much differently than the apparently real-world simulated mosfets. Not sure why that would be so, but maybe their idealized nature are a little too idealized to be realistic in these types of circuits.
                                      TINA TI lacks the convenience of a voltage sweep like LTSpice has, so I'm using a very low frequency triangle wave to approximate it.
                                      Edit4: I'm starting to make progress with TI Tina towards simulating the original (Figure 5) circuit:
                                      After crossing the input threshold voltage, I can either get a steady high signal, as shown here, or by decreasing the value of R1 and increasing the value of C1, I can either make the output do a single sudden transition to zero volts, which then steadily rises afterward with increasing input voltage:
                                      or I can make the output go into a rapid oscillation:
                                      Tina TI has a preview mode, which is how I was able to spot the oscillation when the simulation progress had otherwise slowed to a crawl. Not sure, but maybe either the oscillation or else (more likely) VF1's sudden transition to zero at the voltage threshold on the prior plot might be useful for driving a charge pump or something?
                                      Oh, and if it isn't already clear, the green line is the VG1 triangle input voltage (which I'm using to approximate a "voltage sweep") and the brownish-red line is the voltage measured at the VF1 probing point.
                                      Salient Observation: The "regulated" voltage produced in this simulated circuit is around 700mv, not the ~100mv reported in the Bristol paper. I presume this has to do with the particular mosfets I happened to choose. Perhaps if I can find some mosfets that will produce the 100mv target reported in the Bristol paper, then the rest of the results will fall into place as well. I wish there existed a circuit simulator that could do a "component sweep" to automatically try out a bunch of different mosfets and see what their effects would be. It would gratly accelerate the process of identifying the most desirable component parts that could be used. Seems like it should be an "obvious" feature to have, and yet I'm not aware of any circuit simulators offering it.
                                      Since 100mv is far below even the Vgs(th) of all the enhancement mosfets in both the digikey and mouser parts catalogs, this seems like yet another clue pointing toward the use of specialty mosfets, such as those by manufactured by ALD. Either that, or fets of a different type are being used.
                                      Anyway, now that I have a circuit simulator up and working and producing results fairly quickly (unlike LTSpice), it's time to move forward. Hopefully ALD has SPICE models for their parts (yup, for a few of them anyway: http://www.aldinc.com/view-pdf.php). If so, then plugging those in to the simulator to check the effect would seem to be the next step. I'd wager it's either that, or else maybe there are subthreshold effects that the spice simulators aren't modelling accurately.... I discount the later possibility because, well, it's 2020, and surely by now EE simulation tools are pretty well evolved to account for subthreshold effects?
                                      Edit5: FFS, their POS spice models (last updated in year 2004) won't load into TINA. :angry: Do they load into NGSpice?
                                      Edit6: Well, using this: https://e2e.ti.com/support/tools/sim-hw-system-design/f/234/t/515230, I was able to fix ALD's stone-age spice file. And now it loads into TINA without complaint. But why the heck does it default to VTN=-0.037. I thought VTN was the threshold voltage for an n-channel mosfet, in which case shouldn't it be a positive number?
                                      Edit7: Well, no answer to that question, but I can confirm that VTN is the threshold voltage.
                                      Edit 8: Taking another look at the UB20M datasheet (https://www.bristol.ac.uk/media-library/sites/engineering/research/eem-group/zero-standby/UB20M_Datasheet_Rev.1.5.pdf), I'd have to say that the very low pico-amps static current number that's advertised is a bit misleading without the context provided by Figure 2,
                                      which appears to show that the input must be capable of generating a couple of nanoamps at the threshold voltage in order for the voltage to be detected. So if, hypothetically, under particular lighting conditions a small solar panel could produce at most 1na of short-circuit current, it still wouldn't have enough to get detected no matter how large it's open circuit voltage. That said, UB20M still does appear to be the best of breed, if only it were available.
                                        Mishka
                                        @NeverDie Nice reduce!
                                        AFAIU, the C1+M2 N-MOS will keep the trigger M6+M10 input low, and the output will turn high as soon as input voltage will reach the Vth threshold for the M10. Please note, the output will be limited by the R3=10g, so the circuit is kind of a voltage detector only.
                                        Have you tried it yet? How about making it oscillating? Also, could you explain please, what the M1 does?
                                        Please also note, for some reason the original network has the C1 protected with diode built into the MP3 P-FET. This probably should to be simulated with a diode rather FET. How do you think, why they need it?
                                        • M Mishka
                                          #157
                                          @Mishka I'm rethinking the global strategy to emphasize minimizing leakage currents above all else, even if it means accepting higher threshold voltages. It's tough, though, because none of the parametric search engines (like Digikey or Mouser) appear to allow mosfet searches based on leakage currents. It's in the datasheets, but not searchable as far as I can tell. And with tens of thousands of mosfets to choose from, there are far too many to methodically review manually. So far leakage currents of 100na to 1ua seem common, and I need to find some mosfets which are much, much less than that or else this project will be academic. Maybe there's a way to leverage that Vishay load switch you identified (https://www.vishay.com/docs/66597/sip32431.pdf). Not sure how to proceed at the moment until some suitable real-world low-leakage mosfets can be identified.
                                          A FemtoFET would be at least some improvement over what's comon (http://www.ti.com/lit/ds/symlink/csd15380f3.pdf), but it still lists fairly large MAX leakage amounts with no indication as to what typical leakage might be.
                                          Nexperia lists some low leakage mosfets: https://assets.nexperia.cn/documents/application-note/AN90009.pdf
                                          but I'd like to find lower leakage than even those, if possible.
                                          Ideally low leakage and low threshold would go hand in hand, as lower voltages generally imply lower leakages also, at least for any given mosfet.
