  3. Multiple mqtt gateways via nrlf24l01 secure/unsecure
5 Posts 3 Posters 753 Views 3 Watching
  • YoshuY
    YoshuY
    Yoshu
    Re: Multiple Gateways
    If possible what would be required to se up two separate mysensors gateways?
    I want to have two seperate networks
    • One using the full security and signing for some security crital equipment.
      -A second to be unsecure for non security critical components allowing quick easy setup of these nodes
      I will use the mqtt gateway or (ethernet gateway if the openhab binding become functional again ) and the nrlf24l01 radios on an arduino
    • electrikE
      electrikE
      electrik
      Yes it is possible, as long as you use different channels for the communication so the gateways won't be confused. I have two gateways running also (I am using static node IDs), one with nrf24 and the other one with rfm69.
      • YoshuY
        YoshuY
        Yoshu
        Hi Thanks for the reply!
        If I used only nrf24l01 radios, (as I have plenty laying around) if I defined a different channel (and node Id) for the second network. Would this prevent confusion between the two networks rather then using a different radio type (rfm69)?
        • @def MY_RF24_CHANNEL
        • @brief RF channel for the sensor net, 0-125.
        • Frequence: 2400 Mhz - 2525 Mhz Channels: 126
        • http://www.mysensors.org/radio/nRF24L01Plus.pdf
        • 0 => 2400 Mhz (RF24 channel 1)
        • 1 => 2401 Mhz (RF24 channel 2)
        • 76 => 2476 Mhz (RF24 channel 77)
        • 83 => 2483 Mhz (RF24 channel 84)
        • 124 => 2524 Mhz (RF24 channel 125)
        • 125 => 2525 Mhz (RF24 channel 126)
        • In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed
        • http://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2013_10_WLAN_2,4GHz_pdf.pdf
          #ifndef MY_RF24_CHANNEL
          #define MY_RF24_CHANNEL 76
        • YoshuY Yoshu
          @Yoshu yes, different channel is sufficient. Maybe a few channels away from the default/other network to avoid crosstalk.
          No need to use different nodeID.
          YoshuY 1 Reply Last reply
            YoshuY
            YoshuY
            Yoshu
            @mfalkvidd Cheers! This project will keep me occupied for my 2 week hotel isolation stay.
