  3. MYSbootloader for Pro Mini 1Mhz
5 Posts 4 Posters 3.9k Views 1 Watching
  • AndurilA Offline
    AndurilA Offline
    Anduril
    Hey everyone,
    I managed to make MYSController work with my gw just today. Next project is the MYSbootloader. :-)
    First: I've never changed a bootloader or fuses upto now.
    I want to change the fuses to run the Pro Mini at 1Mhz (battery powered) and burn this bootloader.
    Do I need to burn the fuses before uploading the bootloader? I didn't found that option in Arduino IDE (I'm going to use an Nano as ArduinoISP).
    What do I have to change in the bootloader to change frequency and how do I have to compile the new hex file?
    Sorry for all these noob questions, but I didn't found helpfull topics with the search.
    Regards,
    Anduril
    • B Offline
      B Offline
      bjacobse
      Get yourself a USBtinyISP, can be bought cheap on ebay.
      then read the good stuff from Gammon http://www.gammon.com.au/power and then you can with avrdude program the fuses after you have programmed the sketch
      • AndurilA Offline
        AndurilA Offline
        Anduril
        Hi @bjacobse,
        I already read this article some time ago about the sleep modes. The reason I want to go for 1Mhz is to reduce BOD to 1.8V with my battery.
        As far as I know I don't need an USBtinyISP, because i can use ArduinoISP for the same purpose, right?
        The thing most important to me (which I didn't found in tutorials online) is how to modify the MYSbootloader with the right settings.
        Concerning the order: I think I have to do first the fuses, second a new bootload with correct Mhz (for timings during boot) and then a new sketch. Can someone confirm this?
        • AndurilA Anduril
          Hi @bjacobse,
          T Offline
          T Offline
          tekka
          wrote on last edited by tekka
          @Anduril MYSBootloader was tested for 1Mhz (actually the bootloader works unmodified down to 125KHz with 1Mhz & prescaler 8 ). Therefore, burn the correct fuse settings (remember: MYSBootloader is 2kb, therefore BOOTSZ = 1024 Words = 2048 Bytes) and verify if OTA updates are working.
          • M Offline
            M Offline
            MarkV
            How did you get it to work??
            Could you write a noob tutorial on how it works with bootloaders and how to upload them?
            I've downloaded the mysensors1.5 zip file, but what are the next steps, how do i get it to show up in arduino sketch and after that what must i change and how do i upload it in my arduino??
            12.2k
