  3. Multisensor node using Ceech board
64 Posts 8 Posters 39.6k Views 11 Watching
  • joaoabsJ
    joaoabsJ
    joaoabs
    Nice work indeed. Could you please share the code?
    I also have a ceech board, and this could be the use for it.
    Joao
      MikeF
      Here's the code I've used - it's based on Ceech's sketch for the board, with the addition of code for the BH1750:
       PROJECT: MySensors / LiON charger board
       PROGRAMMER: AWI
       DATE: 28 april 2015/ last update: 11 may 2015 / BH1750 added: 5 September 2015
       FILE: MS_Solar_2.ino
       LICENSE: Public domain
       Hardware: Ceech - ATmega328p board w/ ESP8266 and NRF24l01+ socket LTC4067 lithium battery charger
      	and MySensors 1.4
      	Temp & Humidity - HTU21
      	Barometer & Temp - BMP085
      	Light sensor - BH1750
      	On board EEPROM (I2C)
      	On board Li-On charger with multiple V/A measurements
      Special:
      	program with Arduino Pro 3.3V 8Mhz
      SUMMARY:
      	Reads on-board sensors and send to gateway /controller
       Remarks:
      	On board EEPROM and MOSFET not used in this sketch
      	Fixed node-id
      #include <Wire.h> 				// I2C
      #include <HTU21D.h>            	// temperature / humidity (i2c, HTU21D, SHT21)
      #include <Adafruit_BMP085.h>  	// barometer / temperature
      #include <BH1750.h>
      #define LTC4067_CHRG_PIN	A1		//analog input A1 on ATmega 328 is /CHRG signal from LTC4067
      #define batteryVoltage_PIN	A0		//analog input A0 on ATmega328 is battery voltage ( /2)
      #define solarVoltage_PIN	A2		//analog input A2 is solar cell voltage (/ 2)
      #define solarCurrent_PIN	A6		//analog input A6 is input current ( I=V/Rclprog x 1000 )
      #define batteryChargeCurrent_PIN	A7		//analog input A7 is battery charge current ( I=V/Rprog x 1000 )
      #define LTC4067_SUSPEND_PIN	9		//digital output D9 - drive it high to put LTC4067 in SUSPEND mode
      const float VccMin        = 1.0*3.5;  // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
      const float VccMax        = 1.0*4.2;  // Maximum expected Vcc level, in Volts.
      #define TEMPERATURE_CHILD_ID 2
      #define TEMP_CHILD_ID 3
      #define HUM_CHILD_ID 4
      #define BARO_CHILD_ID 5
      #define BATT_CHILD_ID 10
      #define SOLAR_CHILD_ID 11
      #define LIGHT_CHILD_ID 6
      HTU21D SHT21;						// Hum/Temp (SHT12)
      Adafruit_BMP085 bmp;    			// define baro/ temp meter
      BH1750 lightSensor;					// define light sensor
      MySensor gw(7,8); 					// Ceech board, 3.3v (pin default 9,10)
      unsigned long SLEEP_TIME = 60000;  	//  60 sec sleep time between reads (seconds * 1000 milliseconds)
      float lastTempSHT;			// SHT temp/hum
      float lastHumSHT;
      float lastTempBMP;
      float lastPresBMP;
      int altitude = 100; // 330 feet above sealevel
      float lastBattVoltage;
      float lastBattCurrent;
      float lastSolarVoltage;
      float lastSolarCurrent;
      int lastBattPct = 0;
      uint16_t lastLux;
      float VccReference = 3.3 ;				// voltage reference for measurement, definitive init in setup
      MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);			// SHT temp (deg C)
      MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);					// SHT hum (% rh)
      MyMessage pressureMsg(BARO_CHILD_ID, V_PRESSURE);			// BMP pressure (hPa)
      MyMessage batteryVoltageMsg(BATT_CHILD_ID, V_VOLTAGE);		// Battery voltage (V)
      MyMessage batteryCurrentMsg(BATT_CHILD_ID, V_CURRENT);		// Battery current (A)
      MyMessage solarVoltageMsg(SOLAR_CHILD_ID, V_VOLTAGE);		// Solar voltage (V)
      MyMessage solarCurrentMsg(SOLAR_CHILD_ID, V_CURRENT);		// Solar current (A)
      MyMessage luxMsg(LIGHT_CHILD_ID, V_LIGHT_LEVEL);			// Light sensor (lux)
      	gw.begin(NULL, 19);  // fixed node 19
      	gw.sendSketchInfo("AWI Dev THB/batt 19", "1.0");
      	gw.present(TEMP_CHILD_ID, S_TEMP);						// SHT temp
      	gw.present(HUM_CHILD_ID, S_HUM);						// SHT humidity
      	gw.present(BARO_CHILD_ID, S_BARO);						// BMP pressure (temp not used here)
      	gw.present(BATT_CHILD_ID, S_POWER);						// Battery parameters
      	gw.present(SOLAR_CHILD_ID, S_POWER);					// Solar parameters
      	gw.present(LIGHT_CHILD_ID, S_LIGHT_LEVEL);				// Light sensor
      	// use VCC (3.3V) reference
      	analogReference(DEFAULT);								// default external reference = 3.3v for Ceech board
      	VccReference = 3.323 ;									// measured Vcc input (on board LDO)
      	pinMode(LTC4067_SUSPEND_PIN, OUTPUT);					// suspend of Lion charger set
      	digitalWrite(LTC4067_SUSPEND_PIN,LOW);       			//  active (non suspend) at start
      	Wire.begin();											// init I2C
      	SHT21.begin();											// initialize temp/hum
      	bmp.begin();											// bmp085 temp/ baro
      	lightSensor.begin();									// light sensor
      	sendTempHum();
      	Serial.println();
      	sendTempBaro();
      	Serial.println();
      	sendVoltage();
      	Serial.println();
      	sendLight();
      	Serial.println();
      	gw.sleep(SLEEP_TIME);
      void sendTempHum(void)
          // SHT2x sensor
      	// Temperature and Humidity
      	float humidity = SHT21.readHumidity();
      	// send to MySensor network / only if change
      	if (humidity != lastHumSHT && humidity != 0.00) {
      		lastHumSHT = humidity;
      		gw.send(humidityMsg.set(humidity, 2));  // Send
      	float temperatureSHT = SHT21.readTemperature();
      	if (temperatureSHT != lastTempSHT && temperatureSHT != 0.00) {
      		lastTempSHT = temperatureSHT;
      		gw.send(temperatureMsg.set(temperatureSHT, 2));  // Send
      	Serial.print("SHT21 temp: ");
      	Serial.print(temperatureSHT);
      	Serial.print(" SHT21 hum: ");
      	Serial.print(humidity);
      void sendTempBaro(void)
      // Send temperature and barometer from baro sensor (temp1)
          float temperature = bmp.readTemperature();
         // send to MySensor network / only if change (not sent here)
      	if (temperature != lastTempBMP) {
      		lastTempBMP = temperature;
      		//gw.send(temperatureMsg.set(temperature, 1));  // Send
      	float pressure = (float)bmp.readSealevelPressure(altitude)/100;
      	if (pressure != lastPresBMP) {
      		lastPresBMP = pressure;
      		gw.send(pressureMsg.set(pressure, 1));  // Send
      	Serial.print("BMP180 temp: ");
      	Serial.print(temperature);
      	Serial.print(" BMP180 pressure: ");
      	Serial.print(pressure);
      void sendVoltage(void)
      // battery and charging values
      	// get Battery Voltage & charge current
      	float batteryVoltage = ((float)analogRead(batteryVoltage_PIN)* VccReference/1024) * 2;	// actual voltage is double
      	Serial.print("Batt: ");
      	Serial.print(batteryVoltage);
      	Serial.print("V ; ");
      	float batteryChargeCurrent = ((float)analogRead(batteryChargeCurrent_PIN) * VccReference/1024)/ 2.5 * 1000; // current(mA) = V/Rprog(kohm)
      	Serial.print(batteryChargeCurrent);
      	Serial.println("mA ");
      	// get Solar Voltage & charge current
      	float solarVoltage = ((float)analogRead(solarVoltage_PIN)/1024 * VccReference) * 2 ;		// actual voltage is double
      	Serial.print("Solar: ");
      	Serial.print(solarVoltage);
      	// get Solar Current
      	float solarCurrent = ((float)analogRead(solarCurrent_PIN)/1024 * VccReference)/ 2.5 * 1000;		// current(mA) = V/Rclprog(kohm)
      	Serial.print(solarCurrent);
      	Serial.print(" mA; charge: ");
      	Serial.println(digitalRead(LTC4067_CHRG_PIN)?"No":"Yes");
      	// send battery percentage for node
      	int battPct = 1 ;
      	if (batteryVoltage > VccMin){
      		battPct = 100.0*(batteryVoltage - VccMin)/(VccMax - VccMin);
      	Serial.print("BattPct: ");
      	Serial.print(battPct);
      	Serial.println("% ");
      	gw.send(batteryVoltageMsg.set(batteryVoltage, 3));  		// Send (V)
      	gw.send(batteryCurrentMsg.set(batteryChargeCurrent, 6));  	// Send (mA)
      	gw.send(solarVoltageMsg.set(solarVoltage, 3));  			// Send (V)
      	gw.send(solarCurrentMsg.set(solarCurrent, 6));  			// Send (mA)
      	gw.sendBatteryLevel(battPct);
      void sendLight(void)
      // Send light level - BH1750
      	uint16_t lux = lightSensor.readLightLevel();
        	if (lux != lastLux) {
            gw.send(luxMsg.set(lux)); // Send
            lastLux = lux;
          Serial.print("BH1750 lux: ");
      	Serial.print(lux);
      /* Ceech board specifics for reference:
      It provides power for the circuit and charges the backup single-cell lithium battery while greatly extends battery life. You can monitor the voltages and currents. It has suspend mode, which reduces current consumption to around 40μA. The power source is a small, 5V solar cell. Connections:
      analog input A1 on ATmega 328 is /CHRG signal from LTC4067 (indicates fully charged)
      All the voltages on analog inputs can be read with an analogRead() command in the Arduino IDE sketch. Those on inputs A0 an A2 represent direct values of the measured voltages divided by 2. The voltages on analog inputs A6 and A7 can be translated to currents. For example:
      Let us say that the voltage on A7 is 0.12V. And the trimmer pot on PROG pin is set to 2.5kOhm. This means that the current into the battery equals to 0.12V/2500ohm x 1000, which is 48mA.
      voltmeters on both battery and solar cell connections
      They are connected to analog inputs A0 and A2 on the ATmega328p. The voltage dividers resistors are equal, so the measured voltage is double the shown voltage.
      NRF24l01+ socket
      with CE and CSN pins connected to digital pins 7 and 8 ( you use RF24 radio(7, 8); in Arduino code). There is a 4.7uF capacitor connected across Vin and GND of the port
      • joaoabsJ
        joaoabsJ
        joaoabs
        Great stuff!
        I'll test it during the weekend!
        • joaoabsJ
          joaoabsJ
          joaoabs
          wrote on last edited by joaoabs
          It works great! Thanks!
          Did you tune the potentiometers, or left as they were?
          I'm using 2x 6v, 100mA solar panels in parallel and one 5000mAh Li-ion battery.
          EDIT:
          Now in a sunny day, it seems something is missing (probably some tuning in the potentiometers). Somehow the battery is not charging:
          Batt: 3.73V ; 1.30mA
          Solar: 6.64V ; 0.00 mA; charge: No
          BattPct: 33%
          send: 19-19-0-0 s=10,c=1,t=38,pt=7,l=5,st=ok:3.732
          send: 19-19-0-0 s=10,c=1,t=39,pt=7,l=5,st=ok:1.298047
          send: 19-19-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:6.640
          send: 19-19-0-0 s=11,c=1,t=39,pt=7,l=5,st=ok:0.000000
          send: 19-19-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:33
          Any idea/suggestion?
          Joao
            MikeF
            @joaoabs Glad you got it working.
            No, I didn't tune the pots.
            I had similar problems with solar panels: battery didn't seem to be charging. Also, you're getting a high solar voltage (6.64V) on a sunny day, as I did. I was concerned, as the absolute max Vin for the LTC4067 - from the datasheet, if I remember correctly - is 6.2V.
            I gave up using solar cells, and I'll just charge the battery from a USB charger when I need to.
            • joaoabsJ
              joaoabsJ
              joaoabs
              Thanks for the feedback.
              I think the key here is in the potentiomenters, so I looked around for some guidance:
              The two trimmer potentiometers are used to determine the current for both the input side - to better match the internal resistance of the solar cell - and for the battery charge current. At shipping they are both set to around half the value ( 2.5kOhm), which set both currents to about 75mA.
              I don't know how to measure the internal resistance of the solar cell (shouldn't be as simple as measuring it with a ohmmeter, right?), but I'm assuming that if 75mA is half the value, the maximum should be 150mA. Since my panels in parallel can supply (theoretically) up to 200mA, I'll rotate the potentiomenter to its maximum. Now, wich potentiomenter is it (not identified in the board), and what to tune in the other potentiometer (should be the same mA, what does it depend on)?
              @Ceech, Any guidance on how to overcome this not-charging problem?
              Joao
              C 1 Reply Last reply
              • joaoabsJ joaoabs
                Joao
                C
                C
                ceech
                @joaoabs Try lowering input voltage. The IC is in overvoltage mode and we don't want to damage it. Next, try with 5V input. See if you get the charge.
                The trimmer potentiometers:
                The left one is battery charge current limit. Turn it to the left in order to maximize charging current.
                And the right one is input current limit. Keep the input current below solar panel maximum current. Turn it left to increase current limit.
                This is a formula to calculate input current: Ilim = 200V/Rclprog , where Rclprog stands for trimmer resistance.
                And this is how you calculate charging current: Ich = 1000V/Rprog, where Rprog stands for trimmer resistance. It is also limited with input current.
                  MikeF
                  @ceech I'm using a more recent version of this board, with an LTC4079 charger (instead of the LTC4067).
                  Which Arduino pin is the ~CHRG signal brought out on? A2 appears to be Vin (solar cell), whereas if I do analogRead(A7) I get a value around 500 (regardless of whether Vin is connected or not)?
                  • C
                    C
                    ceech
                    ~CHRG is at ADC A7. It pulls low when the battery is getting charged. It's not always zero, sometimes is stuck around 10 or below. It works in conjunction with ADC A6, which is a battery current pin. Do you get any reports here?
                      MikeF
                      @ceech I've connected a 5V USB supply to the solar cell input, and I'm running your example sketch from your eBay web page for this board. I'm seeing a battery voltage of 3.59V (Li-ion), and charge current (monitoring A6) of 0.00mA - suggesting the battery isn't charging? As said before, A7 is showing values around 479.
                      Vcc = 3.30V
                      Charge current = 0.00mA
                      Solar cell voltage = 4.98V
                      Battery voltage = 3.59V
                      CHRG = 479
                      • C
                        C
                        ceech
                        Ah, yes. I think i know what the problem is. The LTC4079 has a built-in MPPT power tracking for solar panels and won't charge if the input voltage is below set point. This helps optimizing power extraction from solar panels. If you are using 5V input, then you should adjust the trimmer pot on the board. Like this
                        Turn the top round part of the trimmer to the left so that the wiper reaches 5V mark like on the above picture. In other words reduce trimmer resistance to minimum. The other way around is for 18V solar panels.
                          MikeF
                          @ceech That did it - thanks! :smile:
                          Currently charging at c. 90mA:
                          Vcc = 3.30V
                          Charge current = 89.93mA
                          Solar cell voltage = 4.95V
                          Battery voltage = 3.62V
                          CHRG = 0
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            @ceech I have the same problem with the LTC4079 board:
                            Running a simplified sketch gives the following:
                            Vcc = 3.39V
                            Charge current = 2.26mA
                            Solar cell voltage = 5.40V
                            Battery voltage = 4.11V
                            CHRG = 502
                            Vcc = 3.42V
                            Charge current = 0.25mA
                            Solar cell voltage = 5.41V
                            CHRG = 500
                            Vcc = 3.35V
                            Solar cell voltage = 5.24V
                            CHRG = 498
                            Vcc = 3.33V
                            Solar cell voltage = 5.19V
                            Battery voltage = 4.08V
                            CHRG = 496
                            CHRG is never goes to zero or close and the charging current is low or zero. Shall I try to adjust the same potentiometer as above?
                            • C
                              C
                              ceech
                              If the trimmer is in the same position as when new, then yes. Turn it anti-clockwise to reach its minimum value. Either that or raise the input voltage to 11V.
                              alexsh1A 1 Reply Last reply
                              • C ceech
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @ceech I cannot supply more than 6V as this is my solar panel maximum voltage.
                                How many turns or degrees shall turn it?
                                I did one and a half turn, but it still does not charge the battery. This is the current position.
                                • C
                                  C
                                  ceech
                                  wrote on last edited by ceech
                                  This is a one turn trimmer. Its minimum value is close to 5V mark on one of the above pictures. And its maximum value is next to 18V mark. Since you've turned it more than once, you have to first determine the current wiper position. If you look closely you can see that the turning top is not quite round. One side is a bit flattened. That is the opposite side of the wiper. Now if you take a look at your picture then I think your wiper position is at around 6 or 7V ( to use the same terminology). I would say 20 more degrees to the left and you'll reach 5V.
                                  You can also measure the trimmer's resistance. Like so
                                  Find the minimum value between marked points. That is your target resistance value.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #21
                                    @ceech - many thanks for above.
                                    I think I nailed it finally.
                                    Is the voltage below normal or can that be adjusted somehow?
                                    Vcc = 3.35V
                                    Charge current = 34.22mA
                                    Solar cell voltage = 4.55V
                                    Battery voltage = 3.80V
                                    CHRG = 446
                                    Vcc = 3.39V
                                    Charge current = 31.87mA
                                    Solar cell voltage = 4.72V
                                    Battery voltage = 3.78V
                                    CHRG = 451
                                    When does analogue A7 (CHRG) go down to zero or around zero?
                                    • C
                                      C
                                      ceech
                                      What voltage would you like to adjust?
                                      The current is a bit low. What is your panel's maximum available current?
                                      The charger is not operating at its full power. Either you are a bit high with the setting on the trimmer or the panel can't supply enough. Charging current should be around 90mA.
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #23
                                        @ceech The solar panal is 6V 4.5W, but right now it is used inside under my table lamp hence a lower voltage (4.7V). I'll to put it in the sun once the weather improves to test it.
                                        EDIT: I have not tested the solar panel before in the sun. Obviously, it provides ~4.8V inside and not sure if it will provide closer to 6v in the sun. I purchased it here http://www.ebay.co.uk/itm/281945297221
                                        Can I connect 5.5v power supply to the 'solar cell' contacts from a reliable PSU to test the trimmer settings ?
                                        • alexsh1A alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @ceech
                                          Ok, it looks like the trimmer is set to 5.5-6V
                                          I am feeding it from 5.5V PSU instead of the solar panal
                                          Charge current = 92.28mA
                                          Solar cell voltage = 5.54V
                                          Battery voltage = 3.82V
                                          CHRG = 467
