Porting MySensors to work with the RadioHead library
  • Code Contributor
    @hek said:
    I wondoer if it would it be possible to implement a mySensors class similar to RHMesh which actually works like MySensors do today using a star-topology and direct-addressed messages?
    @Kolaf said:
    @hek Maybe we should just use reliable datagram. The ms header could contain just "source, destination, and last", and rhreliabledatagram deals with hop by hop ack and addressing.
    @Yveaux said:
    I would prefer to use the RadioHead library also for routing, but maybe the current implementation can be made more efficient, in terms of header length and also code space.
    Currently I can barely fit in a simple sensor example and Ethernet gateway also gives warning about ram usage...
    Just a thought (I did NOT review the entire RH code) - from the RH documentation it sounds like we could use the RH Drivers without using any of the RH Managers - keeping routing etc. within MySensors responsibility.
    Just checking as it appears that @kolaf and @Yveaux have spent significant time reviewing the code and I would want to understand if that's an option or a totally stupid idea 🙂
    @ToSa It is definitely not a stupid idea, it is a variation of what I suggested previously which you quoted in your post (using the reliable datagram manager instead). It is a question of the abstraction level we want to use. Personally I prefer to use a library where everything is built in and that has widespread use. This gives us much more features for "free", and depending on the user base also a lot more testing. However, it turns out that not everything is perfect. The header is too big, and the library is perhaps not as efficient as it could be.
    This boils down to whether we should do things more efficiently ourselves, or try to fix the library, either officially or unofficially. It looks like the maintainer of the project is very open to suggestions. In fact, I just saw a post where he said he had implemented a generic powerdown mode for all the drivers that I suggested a few days ago. My guess is that if we work with him we could get a lean and mean radio library which could benefit both the MySensors project and the Arduino community as a whole. There appears to be people here with quite good radio knowledge, so think this could be a very powerful combination. Still, it is a question of time, effort, and priorities...
    @kolaf I totally agree with you.
    The MySensors library currently has a solid nrf24 implementation and routing works fine (though not fully mesh) so there's no direct need to switch driver and routing layer.
    This is a roadmap item on which we should continue working, IMO together with the RadioHead development. The RadioHead library has only recently been developed (few months old or so) and is already very mature looking. This is very promising for the future and there's no use in developing/maintaining 2 nearly identical libraries.
    I think the current flaws (e.g. code & message size) can be improved with our help making it a solid base for MySensors.
  • Code Contributor
    Thanks @kolaf @Yveaux.
    makes sense - I thought "just" using the drivers at least as an interim step could give us a head-start but it appears that the majority of the "issues" with RH need to be fixed on the driver level anyways so we would still need to work these first with the RH team...
    @Yveaux said:
    Ok, read a bit through the docs. Apparently this is what is sent:
    RHDatagram:  ff:7e:01:00     (TO:FROM:ID:FLAGS)
    RHRouter:    ff:7e:00:52:00  (DEST:SOURCE:HOPS:ID:FLAGS)
    RHMesh:      01:01:00        (ROUTE_DISCOVERY_REQUEST:<RESERVED>:DEST)
    Therefore the destination and source address are sent TWICE (destination even 3 times with nRF24, as the destination address is part of the nRF24 header). An ID byte (incremented with each message sent) is also present in RHDatagram & RHRouter.
    After the route is known, sending through RHMesh still requires 1 byte to indicate application payload is transmitted.
    For short, Every message will require 10 bytes header, at least, to which the MySensors payload is added (including its own header of currently 4 bytes) giving at least 14 bytes overhead of 32 bytes total.
    To me this feels like too much....
    I think the addressing is not that bad: the TO/FROM is actually the next/last used in MySensors - only for a single-hop communication these are the same as SOURCE/DEST. With that FROM/SOURCE/DEST in RH == last/sender/destination in MySensors. The TO (next) is the one that is unnecessary because it's part of the nRF24 header - as this is not the case for all radios, this should be adjusted in the NRF24 specific code in RH and shouldn't be that hard to do.
    The ID fields are used to determine if a packet is a duplicate (once for the hop and once end-to-end). I'm wondering how this is done in MySensors today. For the single hop that's probably part of the nRF24 internals (auto-acknowledge / auto-resend) and maybe it could be avoided on the driver level in RH but probably needs some tweaking of ReliableDatagram as well. For e2e I don't think there is an equivalent in MySensors today and it might actually be a valuable add rather than a waste of a byte 🙂 what could happen without it: a node receives a packet and sends an ack - the ack does not make it to the sender and therefore the sender submits the same packet again - the node receives the package once again and thinks it's a new packet... think about a command that toggles a light - woulc toggle twice and go off->on->off instead of off->on.
    The FLAGS bytes appear to be a total waste of space.
    • Looking at the first FLAGS byte it's actually defined on the driver level already but not used in Driver or Datagram but only in ReliableDatagram and the only flag set is RH_FLAGS_ACK - a full byte for a single bit worth of information... The two options would be to either remove that byte and mark ACK packets differently or to just make use of the remaining 7 bits for other purposes. I would prefer using the 7 bits - protocol version (3 bits) is definitely a good fit - command (3 bits) might be the other. Using the lower four bits of FLAGS for application layer purposes is even foreseen in RH (and could be easily changed to use 6 bits for app layer in RHGenericDriver.h)
    • The benefit of the second FLAGS byte (from the Router) is totally unclear to me. It seems like the neither RHMesh nor RHRouter code uses it at all even if it's defined on that level so nothing else should use it either... worth a discussion with the RH team - and either remove it completely or use it again for app layer specific stuff (MySensors type?). I'm surprised that they don't use these FLAGS instead of the first byte of RHMesh messages to determine route discovery vs. app date vs. ...
    Assuming that we can get rid of the "TO" and the "driver level ID" and make use of the FLAGS fields as mentioned above the header would be:
    • RHDatagram: FROM:FLAGS (covering MyMessage last / ack / version / command)
    • RHRouter: DEST:SOURCE:HOPS:ID:FLAGS (covering MyMessage destination / sender / type)
    • RHMesh: one byte to determine "application data" - tbc if this can be moved to the FLAGS instead consuming less than a full byte. at least the MyMessage "payload type" can be included in that byte
    • MyMessage header: none (would need to talk to @hek but I think MyMessage::sensor should actually not be part of the header anymore but part of specific message types only).
    This would leave us with 2+5+1=8 bytes instead of the current 7 bytes for the header (to be fair 8 instead of 6 due to the removed sensor field). That's not as bad as 14!
    Yes, that makes sense.
    Reply from Mike:
    Some of your contributors have the wrong idea about the headers.
    There are 4 header bytes used by drivers, RHDatagram and RHReliableDatagram
    TO
    FROM
    ID
    FLAGS
    These are the hop-to-hop headers. In fact they are present in the payload (but
    effectively unused) even if you use the drivers directly.
    RHRouter and RHMesh (if you use them) add
    DEST
    SOURCE
    HOPS
    ID
    FLAGS
    these are end-to-end headers and are not necessarily the same as the hop-to-
    hop headers. In the general case they will be different values.
    In my view all these header are all necessary.
    BTW, new version 1.33 supports sleep mode for RH_RF69, RH_RF22, RH_NRF24,
    RH_RF24, RH_RF95 drivers.
    Cheers.
  • Code Contributor
    @hek said:
    Reply from Mike:
    yep 🙂
    Well, debatable at least for the FLAGS (or the size of the FLAGS).
    Three questions (@Mike, if you are reading here, just reply directly, otherwise I'll contact you via the RH channels...):
    • is the RH library itself using the end-to-end FLAGS? I couldn't find any reference other than setting it to 0 (when using RHMesh).
    • is the RH library itself using the hop FLAGS for anything other than identifying ACK packets (RH_FLAGS_ACK / RH_FLAGS_NONE)?
    • for the hop ID and TO - if the specific RF chip supports this internally (as part of the preamble/header the chip adds to the on-air packet), why duplicating this wasting valuable payload size - the driver for the specific RF chip could handle it internally and make it look the same for the outside world using the RHGenericDriver interface without changes... I'll give it a try and let you know.
    @hek Thanks for getting Mike 'on board'! Good move!
    Great work guys. I'm glad to see some enthusiasm for this as it will allow me to utilise the platform and not have to reinvent the wheel 🙂
  • Code Contributor
    Test compilation comparing code size with current MySensors 1.4 radio library and with radiohead. The radiohead integration to MySensors is not optimized (pushing full MySensors header through even if the radiohead header has the same content etc.) and the radiohead library provides some benefits (not just a 1:1 replacament) - so it's expected to be larger. Based on the two examples below it's right now about 4-5k flash and ~800 ram for global variables.
    => let's see how far we can get that down reducing the duplication of header data etc.
    **SerialGateway with MySensors: **
    Sketch uses 17,566 bytes (57%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 688 bytes (33%) of dynamic memory, leaving 1,360 bytes for local variables. Maximum is 2,048 bytes.
    SerialGateway with RadioHead:
    Sketch uses 22,242 bytes (72%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,455 bytes (71%) of dynamic memory, leaving 593 bytes for local variables. Maximum is 2,048 bytes.
    **DallasTemp with MySensors: **
    Sketch uses 20,288 bytes (66%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 551 bytes (26%) of dynamic memory, leaving 1,497 bytes for local variables. Maximum is 2,048 bytes.
    DallasTemp with RadioHead:
    Sketch uses 24,592 bytes (80%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,319 bytes (64%) of dynamic memory, leaving 729 bytes for local variables. Maximum is 2,048 bytes.
  • Code Contributor
    @ToSa Wonder what the runtime values are...
    What radio/Arduino IDE did you compile for?
    For Serial Gateway, nrf24, Arduino 1.5.7 I get:
    Sketch uses 20.962 bytes (64%) of program storage space. Maximum is 32.256 bytes.
    Global variables use 1.471 bytes (71%) of dynamic memory, leaving 577 bytes for local variables. Maximum is 2.048 bytes.
    @Damme
    Currently MySensor::setRadio creates an instance of RHMesh at runtime, so RAM usage is even worse...
  • Code Contributor
  • Code Contributor
    nRF24 / 1.5.6-r2
    DEBUG turned on - your values appear to be with DEBUG turned off
    I did a few changes starting to reduce the header so I can't rerun with DEBUG off and compare right now...
    A small digression from the main topic here, but I just tested the mesh functionality of the library. I took a laptop with a serial gateway outside of the range of my sensor and observed that it stopped working. I then went back a few metres and powered up a battery powered sensor which basically just sent hello every second and processed messages. I was able to significantly extend my range, experiencing only a few seconds of interrupt in the ping flow.
    Moving back and powering down the intermediate node, the direct route was reestablished within a new couple of seconds and everything was working correctly again 🙂 I think I will have much fun playing with this.
    @kolaf said:
    I was unable to significantly extend my range, experiencing only a few seconds of interrupt in the ping flow.
    Shouldn't that be "I was able"?
    I want to be happy with you, but not sure now 😉
    You are most certainly correct, I have edited my original post. I'm suffering a bit from tendinitis, so I'm using speech recognition when I write. Sometimes it recognises almost exactly what I say 😉
    What are the differences between the MySensors protocol and RH in terms of mesh dynamics?
    I'm guessing that RH is more dynamicly configured, but I'd like to understand more.
    @kolaf ah, great to see your results then!
    I read some mixed results on the Radiohead mailing list regarding mesh, so good to see it's working for you.
    BTW I'm in the progress of writing wireshark directors for Radiohead which can be used with the nrf24 sniffer. It'll give us better insight on Radiohead's performance and functioning.
    It makes sense to migrate the MySensors last,sender and destination bytes to RH from,source,dest.
    I do not think it makes sense to move type (V_code) or command into the RH FLAGs. Typically when such space is reserved for the protocol in the header but not yet fully used, it's subject to change as the protocal evolves. If part of the goal is to take advantage of the maintenance and ongoing development of RH, we don't want to set up a conflict - because other users are not going to use those FLAGs our way anyway.
    Basically, Radio Head should be concerned with delivering a payload (set of bytes) to a node. Everything specific to just the MySensors application should be in the payload (as seen by RH). That includes:
    • child id ("sensor")
    • command
    • V_code ("type")
    • version (if needed)
    • ack - is this still needed??
    If we want to remain compatible with other RH users (ie: their development), rather than re-allocating bytes or bits in the RH header to our own purposes, we would be putting our MySensors' header in the RH payload, but omitting from our header the redundant fields which are handled by RH:
    • last,
    • sender,
    • destination
    The RH payload would include the reduced MySensors header plus the MySensors payload.
  • Code Contributor
    From the RH documentation / the source code:
    • for Datagram FLAGS:
      A bitmask of flags. The most significant 4 bits are reserved for use by RadioHead. The least significant 4 bits are reserved for applications.
    • for Router/Mesh FLAGS:
      Optional flags for use by subclasses or application layer
    Not setting up a conflict with the RH code will be the biggest issue: the two benefits of RH are the multi radio support and the more advanced Mesh topology - which would be worth a couple of additional bytes in flash and ram - but the other reason for the big overhead is that several advanced features of the nRF24 chip are not used because they are not available in all supported chips.
    Two examples:
    • the multi-pipe capability of nRF24 would allow to filter traffic to only current address and broadcast and avoid that any other traffic ever reaches the MCU (only slightly less code but wondering if that helps with battery powered nodes).
    • the ReliableDiagram processing in code essentially duplicates capabilities that are build into the chipset as well (auto-acknowledge / autoresubmit)
    I know you are interested in getting RF69 supported but the question is how much negative impact for all the other users (with current nRF24 setup) is acceptable. That's like using the RF69 and implementing an AES encryption in code rather than using the build-in capabilities of the chip...
  • Code Contributor
    Didn't want to sound too negative yesterday...
    • I'm still looking at the RH library but changes will be major and will not necessarily be in line with the RH purpose so Mike might not want to merge them into the main codebase: mainly defining what driver is used at compile time of the library (similar to MyConfig) which would then allow to e.g. "bypass" the majority of ReliableDatagram etc.
    • what we should definitely do is splitting application layer and network layer: no longer inherit MySensor from RF24 but create an RF24 instance at runtime / leave application layer message handling in MySensors / move network layer message handling to a separate class (the "driver" for RF24). This will make it way easier to switch radios in the future.
    Is it not sufficient that we define the radio at compile time in the sensors and the gateway as we have done now?
  • Code Contributor
    I'm talking about changing how the library is compiled and essentially having a separate ReliableDiagram class that bypasses manual handling of ACKs etc. and instead leaves reliable delivery to the radio itself. Mesh and Router are derived from the ReliableDatagram class - therefore we would need to define which radio to use prior to library compilation - not just prior to sketch compilation.
    Could someone summarize the differences between the current MySensors mesh and the RadioHead mesh, and why the latter is preferable for us?
    @Zeph
    RH is a true mesh where every node can communicate with any other directly (if in range). All nodes acts as repeaters.
    MySensors forms nodes forms a star network where every node has a parent and potentially a few child sensors. The gateway node is the "center". Every node always tries to find the closest (least number of hops) route to gateway.
             GW
            A   D
          B   C
    If B want to communicate with C messages has to pass A in the MySensors case. In RH C and B will communicate directly if the can hear each other.
    RH does not use the nifty features NRF24L01 offers which offloads mcu (pipes/addresses) nor auto ack (impossible in RH setup). So nodes in range has to process every message it can "hear". And this can potentially be a lot.
    @hek
    Thanks, that was very helpful, and a good explanation.
    That helps explain the overhead in the RH library mesh. It sounds cool for some purposes, but it also sounds like possible overkill for the wireless sensor network. Allowing B and C to communicate directly is not a primary use case. The MySensors is purpose-built for the sensor network with central gateway use case, and is pretty lean thereby. As I see it, even allowing B to send to C via A is not a primary use case, but sort of falls out "for free" given the routing approach that allows repeating nodes.
    Aside - can B send a message to itself via A?
    In my case, I'm mainly focusing on multi-sensor nodes, so RAM or Flash could be in short supply with a larger radio library. Worse still, I want to be able to incorporate MySensors functionality into nodes which also have non MySensors functions (eg: xmas light control also usng nRF24L01+), so space is even more at a premium.
    So while the RH option is interesting, and a lighter weight RH derivative may pan out, I hope the MySensor WSN radio layer will continue to provide a "lean and mean" alternative into the future.
    So MySensors can use both individual node addresses as well a broadcast, while RH uses only broadcast (at the radio level)? I understand why RH needs to do this, and I wonder if the receive FIFO ever overruns with unneeded packets.
    I wonder if MySensors gets much savings from using the auto-ack of ESB. If you already have network ack code anyway, how much code & ram is saved by sometimes using ESB (one hop away) and sometimes not? (I do get that a star network with no repeater nodes could use only ESB autoack and save some code).
    Yes.
    I think end-to-end ack is very important. The inter-node ack is only used as a trigger re-routing today (if communication fails 3 times to parent node .. the node tries to find another parent).
    Could someone please explain to me how the direct messaging of the NRF24 works? In my mind every radio network is a broadcast network on the physical layer, and it is up to the receiving radio to determine whether the packet is relevant or not. How is this different from your radios? Is it perhaps that your radios have a hardware address so that the filtering is done on the hardware level, while Radiohead uses a software address, so each packet has to be explicitly processed? I have no idea, I'm just guessing here...
    @kolaf
    Yes,
    NRF chip offer 6 reading "pipes". In practice it acts as a hw filter for addresses between 0-255.
    I use this to have one broadcast address (255) which all repeating nodes and gateway listens to and each sensor also listen to its own address.
    Looking at the documentation for the RF69 (page 41) it talks about sync word recognition. This is a programmable word that apparently can be used as the node's hardware address, similarly to the NRF24. Perhaps it is possible to expand the Radiohead drivers to utilise this functionality where it is available for filtering incoming packets?
    As for the dynamic mesh, this is a feature I find especially useful for one of my dream applications. We have horses, and it would be really fun to place a radio module with a accelerometer, and maybe GPS receiver, on each horse to track their movements. This could also be combined with a breakable wire in the harness which would let us know if the radio had been ripped off of the horse. Having a dynamic mesh will greatly increase the range of flexibility of such a monitoring network. I know that this is somewhat outside of the normal use case, but how fun wouldn't it be to build this? :-).
    Personally I'm also a bit interested in direct sensor to sensor configurations to allow for tightly coupled control systems without the need for a central controller in the loop (all the time). I know, we have resource limits so that I can probably not have everything, but one can dream...
    Nevermind the sink word recognition, this appears to function as some kind of network ID has to be the same for both the sender and receiver. However, there is also an optional address byte which is considered by the radio before the packet enters the FIFO queue. Page 55 of http://www.hoperf.com/upload/rfchip/RF69-V1.2.pdf
    The trouble is you have to distinguish between broadcasts and direct messages, so you need to listen at 2 addresses at a time, so to say.
    Yep, both pros and cons. 🙂
    A nice feature you can do with MySensors is to set a static parent (when calling gw.begin()). This could be useful for a presence sensor e.g. mounted on a car set statically to contact a repeater node mounted near the garage. The car sensor won't try to find or contact any other node than the garage one.
    Just brainstorming, but what if we consider adding the concept of a roving node to the MySensors network, without the overhead of a full mesh? Your use case doesn't require that all nodes be meshed with each other, just that a class of leaf nodes be able to move around.
    If I understand, a gateway or repeater node will forward a packet from anybody, if it recognizes the destination (as a node id in its routing table). Suppose you had coverage of your corral (or whatever) via gateway and various repeaters. In theory (perhaps naive theory) the roving node could report to the gateway by broadcasting a message picked up by whatever repeater is nearest; being addressed to node 0, the repeater knows what to do with it.
    There would be no network ack and no way for the gateway to send to the roving node as described so far. That is, unless this special "rover packet" caused each relay to rewrite that entry of its routing table as it was passed to the gateway, to enable an updated path back to the roving node. If your horses run around among many nodes often, EEPROM wear could be a concern, unless there was a small "routing override table" in RAM to handle roving nodes.
    One part I'm not clear about is how to avoid two or more nearby repeaters both forwarding this broadcast packet from the roving node. That might be tricky if it often causes OTA collisions. It could also complicate the back route logic, IF that was implemented. If we could avoid or gracefully recover from collisions, the gateway and controller may be able to deal with multiple copies of the same packet (not unlike the MQTT level 1 "deliver at least once").
    And - it might be technically infeasible to enhance MySensors networking to support roving nodes. But in that case I'm sure I'll learn something from the manner in which it's shot down 🙂
    There is a separate optional broadcast address byte. I'm not sure how this is used, but I'm guessing that the radio checks against both addresses before deciding what to do with the message. That should solve the broadcast problem.
    @Zeph @kolaf
    The rovering node will be able to send its message (after a few failed attempts) in the current solution.
    If even faster parent-search is required you can change the #define SEARCH_FAILURES in MySensor.h.
    @hek Just to be clear, I'm not dependent on the mesh functionality. I think I could be very happy with the current MySensors functionality with the added part of supporting my radio 🙂
    That's good!
    Aha, I see that on page 57 now.
    I think that would handle it! (I see no need for 6 address-filtered pipes, two addresses will do).
    Yes, it would be nice if the RH library could take advantage of address filtering for those radios which support it. I'm not so sure auto-ack is important tho.
    So, anyone still developing on RadioHead integration, or did all of you just give up? 😉
    I spend some time on writing Wireshark dissectors for RadioHead and integration of MySensors, to be used with the sniffer (http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors)
    Code is almost final (still have to test dessection of routing tables).
    Just as a preview, here's a screenshot to hopefully get you enthusiastic again!
    upload-2e15da80-1b44-4113-a6ac-e0077160d77b
    @Yveaux
    Looks good @Yveaux!
    I'm still a bit in doubt how sleeping nodes fit in when using RadioHead.
    It has no notion of sleeping nodes and just expects all nodes to be available anytime.
    When a route is e.g. discovered which uses a node that is about to go to sleep, routing will fail, but probably the route will then be rediscovered and finally settle using a node that is continuously powered.
    How long this will take and the likelyhood of such scenarios (depends ofcourse on the amount of nodes and how often/when they are awake) is still unclear to me.
    Hopefully I can analyze some real-world behavior using the sniffer.
  • Code Contributor
    no progress on my end - but that's rather related to the fact that this was my first week back in the office after vacation...
    I think we should do one thing first: decouple the "network layer" from the "application layer" in MySensors:
    • not having MySensors derived from RF24
    • have a "generic" interface between MySensors and the radio
    That way it would be rather easy to make use of other radios and other network topologies - could be RH or something else. I've taken a shot at that (a lot of this based on what Kolaf and Yveaux did adjusting MySensors to RH) and will provide a link once it compiles and is tested and I hope I can keep the overhead small enough to be acceptable for the gained flexibility.
    It is great to see that something is still happening. I wonder if I can build a packet sniffer for the RF69 radios? I guess it shouldn't be that difficult since they receive everything that is sent...
    The reason for my lack of progress late the has several reasons.
    1. I have a version of the library networks for my simplifications. This means that I can start building small sensors instead of spending all my time on the library 🙂
    2. My kids think I spent way too much time on this project already 😞
    3. I'm waiting for some kind of consensus to emerge.
    My hope has been to get this new radio library thing to a point where the community would adopt it so that I would not have to do any specific maintenance to keep my copy up to date with the official version. Based on this very long discussion thread there seems to be interest among you guys to achieve this, so I hope we will be able to get there at some point. However, we need to agree on how it is to be done, how much of the Radiohead library we want to use (or maybe even use a different library?). This obviously depends mostly on resource constraints considerations, and I'm not the best to judge this since I have not used MySensors extensively.
    It is great to see effort being spent on trying to reduce the footprint, and as an experiment it makes sense to do this. Once we have seen how small it is possible to make it, then we can perhaps agree on what features we want (everything, or just the device interface, maybe with RHDatagram manager class (without acknowledgements)).
    I'm holding back on developing any more this until we have reached some kind of consensus since I do not really have time to play around too much without being a relatively sure that the results will be useful.
  • Code Contributor
    Initial version - tested with a simple DallasTemperatureSensor setup successfully here
    Note that this fork/branch does not include the "1.4 update 1" changes for nodeID / CRLF.
    Overhead is limited (~150b flash / ~20b ram):
    Sketch uses 20,426 bytes (66%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 575 bytes (28%) of dynamic memory, leaving 1,473 bytes for local variables. Maximum is 2,048 bytes.
    Care to share any details on which parts you took from where? Is it basically the Radiohead drivers with the MySensors network layer? Or did you make more effort on trying to split everything up to a larger extent
  • Code Contributor
    @kolaf it's only splitting the MySensor application layer form the underlying network layer. Still using the MySensor tree network topology and the RF24 driver. It's adding the framework to allow others to easily integrate other topologies (e.g. mesh) and other radio modules (e.g. RF69). The interface expects a reliable submission - no matter if that's achieved by software (like radiohead) or hardware (nRF24).
    The MyDriver header file includes a short description of the routines and it should be fairly easy to attach it to radiohead. The main benefit is that the original MySensor tree setup still works as before if wished.
    Looks good @ToSa!
    @ToSa Could you give me the link to your repository?
  • Code Contributor
    @ToSa Got it. My apologies for being slow, it was getting late ;).
    Itlooks like this should be quite easy to work with. For the RF69 driver, maybe I could even use the unreliable datagram service from Radiohead And Configure the Driver to Use Hardware Acknowledgements (I Believe They Exist).
    I will make an effort in this direction during the next few days, I hope. I'm curious to see how much space this requires compared to the NRF24 solution
    @ToSa I was trying to fork your repository in order to build the driver for the RF69 based on Radiohead. It does not seem to work, maybe because I already have a fork of the main mysensors repository?
    Maybe I can just check out your code, add the necessary files and be allowed to push it back to you?
  • Code Contributor
    yes - Git doesn't allow two forks with the same base name (Arduino) for one user. We are about to move the changes into the mysensors/development branch. That way you can pick it up from there...
    @ToSa Great, I will add my changes when you have done this.
    It has been implemented, but I won't bother testing it until your changes have been merged with development, I don't want to mess up my existing development environment. My biggest uncertainty is whether this set up will allow the Radiohead library to be installed as a regular library in the "libraries" folder or if it has to be put directly into the MySensors folder.
    Is there any progress of merging into the development branch? I'm currently holding off of building anything definitive for in-house deployment until we have settled on a relatively stable base for the code.
    On a side note, I'm currently deploying Z wave actuators for all the lights in my house (we're refurbishing the entire electric system, anyway), and I must say that I am not very happy with the closed nature of the Z wave network management. I have gotten to the point where I believe that if I were to replace all the Z wave components with MySensors components I would get a much more stable system. Unfortunately I will get in trouble with the authorities if I try this 😞
  • @hek It looks to me that all the activity that happen on getting the RFM69 integrated as part of the Mysensor ecosystem is dying. Can we not see if we can talk to Felix from Lowpower (https://lowpowerlab.com/) to see if he is not willing to get his Moteino integters as part of the MySensor ecosystem. Here is the tread on his forum where I asked him about this. https://lowpowerlab.com/forum/index.php/topic,542.0.html
    The integration has not stopped. It is just a bit slow as we all have lots on our plate 😉
    Felix has actually sent me a couple of Moteinos that arrived a few days ago.
    But the first step is to separate radio code from the rest of the library. @ToSa has begun this work and is nearly finished. Guess he is swamped with work as I haven't heard from him the last couple of weeks.
    https://github.com/mysensors/Arduino/pull/36
    Then we can create a new driver for the RFM69.
    I am waiting for the new radio separation code to be merged into the development branch. I have a working implementation (I think) of the RadioHead RFM69 library using his new code. I don't mind the wait, though, because I have lots of other things to do in the meantime and I can still build sensors using my own version of the library 🙂
    Super @kolaf! Can't seem to get in contact with @ToSa. Maybe time to take it in (even if the config thing is unresolved) to get some progress.
    @kolaf
    The driver refactoring has now been merged into development. Ready for RFM69! 😄
    Working on it, fighting git about a rolled back rebase...
    I managed to resolve my git problem, but I'm now back to a problem we have discussed before.
    The problem is with how I should include the driver in order to use it without having to modify the header of every driver file. Can't seem to find what we landed on last time...
    You mean every sketch file?
    Guess you'll have to do like we did with rf24 and add it to the utility folder. Or maybe I misunderstand the question.
    I mean that I have to place the RadioHead library inside the main my sensors folder for everything to work. If I were to place it in the "utility" folder, I would have to change every include inside the library to use" instead of brackets.
    Anyway, I have gotten it to compile, and there is some radio communication going on. Trouble is that there seems to be some issues with the buffer sizes (I guess?).
    Here was what the sensor is sending:
    find parent
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,st=bc:
    And this is what the Gateway is receiving (with an additional debug message from me):
    0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1:0
    0;0;3;0;9;version: 0
    0;0;3;0;9;version mismatch
    Obviously something is getting mangled along the way...
    Good that something is transmitted.
    But should you really use RadioHead? That seems a bit redundant.
    Felix over at LowPowerLab directed me to: https://github.com/LowPowerLab/RFM69/
    I got something working with a new library. Requesting node ID, and sending all initialisation stuff seems to work correctly. I was not able to place the libraries in the correct place this time either, but perhaps you can move them and re-factor the code?
    I created a pulled request so that you can look at it.
    This is happening in the gateway with the new code:
    0;0;3;0;9;read: 1-1-255 s=255,c=3,t=7,pt=0,l=0:
    0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,st=ok:0
    0;0;3;0;9;read: 0-1-1 s=255,c=3,t=8,pt=1,l=1:0
    0;0;3;0;9;send: 0-0-0-1 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1:0
    1;255;3;0;6;0
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=13:Wave switch 3
    1;255;3;0;11;Wave switch 3
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3:1.1
    1;255;3;0;12;1.1
    0;0;3;0;9;read: 1-1-0 s=1,c=0,t=3,pt=0,l=3:1.4
    1;1;0;0;3;1.4
    0;0;3;0;9;read: 1-1-0 s=3,c=0,t=6,pt=0,l=3:1.4
    1;3;0;0;6;1.4
    0;0;3;0;9;read: 1-1-0 s=2,c=2,t=2,pt=0,l=3:1.4
    1;2;2;0;2;1.4
    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=2,pt=2,l=2:0
    1;1;1;0;2;0
    0;0;3;0;9;read: 1-1-0 s=3,c=1,t=0,pt=7,l=5:23.2
    1;3;1;0;0;23.2
    0;0;3;0;9;read: 1-1-0 s=3,c=1,t=0,pt=7,l=5:23.3
    1;3;1;0;0;23.3
    Great @kolaf. I'll take a look.
    Ok merged! Seems to compile fine with the library in utility after some minimal changes. Thanks @kolaf.
    Excellent. I took a quick look at the changes you did to move the library, I'm a bit ashamed that I didn't manage to do that myself...
    I'm very happy to have a solution in the development branch that allows the radios I bought to be brought along into the future of MySensors 🙂
  • Since I have four moteino , I wanted to test your code. Unfortunately, I have made ​​a mistake , because the compiler return this error :
    In file included from My_Sensor.ino:2:
    C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:32:1: warning: "debug" redefined
    In file included from C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:16,
    C:\Program Files (x86)\Arduino\libraries\MySensors/MyDriver.h:9:1: warning: this is the location of the previous definition
    In file included from C:\Program Files (x86)\Arduino\libraries\MySensors/MyConfig.h:27,
    from C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:17,
    C:\Program Files (x86)\Arduino\libraries\MySensors/MyDriverRF69.h:40: error: ISO C++ forbids initialization of member 'radio'
    C:\Program Files (x86)\Arduino\libraries\MySensors/MyDriverRF69.h:40: error: making 'radio' static
    C:\Program Files (x86)\Arduino\libraries\MySensors/MyDriverRF69.h:40: error: invalid in-class initialization of static data member of non-integral type 'RFM69*'
    @bbbio24
    IDE version?
  • Hi I now have my first MySensor RFM69 node up and running in PiDome 🙂 👍 This is great as with the NFR24L01 I battle to get coverage in my House. I put the RFm69 node in the farthest point in my house any it just work. To get the NFR24L01+ to work at the same location I have to use an repeater node. The other thing I like about the RFM69 solution like Moteino (https://lowpowerlab.com) or Anarduino (http://www.anarduino.com/miniwireless) is the size you don't have to use any wires to connected the radio and it comes fitted to the arduino board. So if you look for a small sensor I think that this is the way to go for automation.
    @Francois Cool! Is this compatible with RF24, as in, you can have RF24 based GW and other sensors, and "plug in" a RFM69 unit? With its better RF properties it sounds like an excellent candidate for use as repeater node as well.
    Or is it required to set up a separate GW?
    You cannot mix radios in one network.
    @hek ok, så it is a different carrier frequency, or modulation, and not protocol-compatible on the "physical" layer? Pity.
  • @hek IDE Version : 1.0.5 r2
    I tried with version 1.0.6 without success.
  • Code Contributor
    @kolaf
    I've been busy with other stuff for some time but looking at the driver separation now once again. With nRF24 working (even bootloader adjusted to pick the right header files etc.) and two Moteinos at hand (Moteino RFM69W 868/915), I compiled and flashed a serial gateway and a simple temperature sensor node. Both appear to work fine looking at the debug messages except the fact that they don't listen to eachother. Both are sending but none is receiving anything (2m distance).
    I did not touch or even closely look at the RFM69 driver code yet but will try to do so over the weekend. Do you have any hint where to check first?
  • Code Contributor
    I have the RFM69 setup working now with a couple of additional tweaks mainly for code optimization. Working fine for some time but stops after a few hours - I'll have a closer look the next couple of days.
    Felix added three bytes to the payload (source address / destination address / control byte) to manage the acknowledge etc. in the lowpowerlab library. For our specific needs this is redundant as the current message format in development already includes this data. The three additional bytes are not that bad though and I'd propose to leave it like that for now and reconsider when we get to the revised message format :).
  • Code Contributor
    RFM69 is stable now for >48h.
    The OTA bootloader version for RFM69 is in progress. I'm stuck right now where the node debug messages show that it's sending a packet but the gateway doesn't receive anything... I moved the full initialization code back in that I thought would be ok to skip but still the same behavior. Only difference to the full blown driver at this point is that I don't attach the interrupt but that should not be relevant for tx as I'm polling the interrupt register for status (ready to send / send complete etc.).
  • Code Contributor
    I had some time today to look at the bootloader code for RFM69 modules. Got the bootloader code to a point where it appears to be working fine - but the instability of the full MySensors RFM69 code is back - the serial gateway stops receiving packets after some time and it appears that the attempt to download a firmware by the bootloader just makes this problem more obvious due to the high volume of packets...
    My prime suspect at the moment is the interrupt driven RFM69 library using a single packet buffer. As long is it's used sequentially everything should be fine but with e.g. submission or retrieval of ack messages it opens up the transceiver while the last packet was not fully processed yet potentially causing this... I'll go ahead and replace the routines in the library with the non-interrupt-driven version I coded for the bootloader just to see if this is the right place to dig deeper...
  • @bbbio24 Hi
    I am running into the same " ISO C++ forbids initialization of member 'radio'" error. Did you manage to solve this issue? am using IDE version 1.0.6. What version should I use?
    Update: I managed to get past this error.
    By the way I am woring with the latest develpment branch that I downloaded from here https://github.com/mysensors/Arduino/archive/development.zip.
    To get past this problem I changed in MyDriverRF69.h the lne 40 to
    RFM69 *radio;// = NULL;
    This resolved the problem in the arduino IDE 1.0.6. Admittedly I am very new to this whole thing and am not sure what I potentially broe by changing the line bt at least I can explore further. 😉
  • I used the Mysensors 1.4.1 library and managed to get a UNO with Ethernet shield and NRF24L01+PA+LNA working as an MQTT gateway.
    I then changed the library to the latest development library (downloaded on 01.12.2014) and uploaded the MQTT gateway setch to the same hardware -> Also worked fine.
    I then changed MyConfig.h to use the RF69 radio instead of NRF24 and just tried to compile. I got a lot of errors:
    MQTT_Gateway_Compile_errors.txt
    I am using Arduino IDE 1.5.8
    I am happy to help with testing, but I am afraid my programming skills are not good enough to assist with that.
  • @ToSa do you see the RFM69 only work on the serial gateway or will it also work on the MQTT gateway?
    @TOSA I just popped back into the forum to report on my experiences with instabilities using the current version of the RFM69 code only to find that you have already had the same experience. This makes me quite happy since it means that at least someone else have had a chance to think a bit about it. On a side note, I really wish this forum had some functionality to subscribe to topics, it is not a forum I visit regularly enough to catch everything that's happening.
    I do not have any good information regarding why the microcontrollers stop responding, but I see it quite regularly in both the Gateway and in the sensors. For instance, I have a power measuring sensor that counts the blinks on my power meter and toggles a LED each time the power meter blinks. I have to reset this about every two days (sometimes more often) when I see that the LED no longer blinks. All my current sensors are running the first version of the code based on your rewritten radio obstructions.
    Please let me know if there's anything I can do to help out with debugging this. The instability is starting to get quite frustrating, and I was actually considering to go back to my earlier prototype implementation based on the radiohead library. I did not experience any such instabilities using this library, so at least we know it is not a hardware problem. As such it shouldn't be too difficult to figure out. Maybe it is possible to discuss this with the lowpowerlabs guy who developed the library?
    Unfortunately my experience with debugging microcontrollers is limited, but I will help out where I can.
  • @ToSa I am running this version and I don't have any problems with it so far. I only have one node up and running with a humility sensor. I order 5 more Anarduino units and hope to get them in Jan so will do more testing then. The humility node is up and running now for more than 3 weeks with out any resets.
    @ToSa How did you make the RF69 stable?
  • @CARSTEN I got the same compile errors. It turns out Arduino IDE 1.5.7 and above have a new compiler which requires PROGMEM data to be const.
    See this discussion: http://forum.arduino.cc/index.php?topic=277173.0
    I was able to resolve the compile errors by adding const where flagged by the compiler:
    In MyMQTT.h:
    const char V_0[] PROGMEM = "TEMP"; //V_TEMP
    etc . ..
    Then:
    const char * const vType[] PROGMEM = {
    V_0, V_1, . . . .
    You also need to change the getType function in MQTTGateway.ino to account for the change in type of vType[]
    char *getType(char *b, const char * const *index) { . . . .
    Compiled with no errors for RFM69 on Arduino 1.5.8 after these changes.
    I have not had a chance to upload and test on my Motineo's.
  • Hi all,
    Happy new year
    I've just have the same idea, I'm new to arduino since chrismas 🙂
    and I want to test mysensor with nrf905, It seem to be compatible with RH librairies.
    Could you just say me what i have to do ?
    I'll have to include the kolaf librairies ?
    Just, If you have a link to the repository in order to work on it with you
    Thanks for all
  • So, I'm working on it with the developpement branch of mysensor.
    I've find some nrf905 librairies arround the web, but the RadioHead seem to be more powerfull and complete.
    I'll give you news soon,
    First of all, i probably need help to diagnose because i've had only one raspberry, one arduino and two atmega328p chipset more
  • Did anyone ever solve the this compile error?
    In file included from /home/andrew/sketchbook/libraries/MySensors/MyConfig.h:27,
    from /home/andrew/sketchbook/libraries/MySensors/MySensor.h:17,
    from SerialGateway.ino:27:
    /home/andrew/sketchbook/libraries/MySensors/MyDriverRF69.h:40: error: ISO C++ forbids initialization of member ‘radio’
    /home/andrew/sketchbook/libraries/MySensors/MyDriverRF69.h:40: error: making ‘radio’ static
    /home/andrew/sketchbook/libraries/MySensors/MyDriverRF69.h:40: error: invalid in-class initialization of static data member of non-integral type ‘RFM69*’
    I have tried with IDEs 1.04, 1.05 and 1.06
  • @andrewm844
    I'm working on 905, so I don't have to check the 69, but I've the same compile error
    I just replace
    // RFM69 *radio = NULL;
    RFM69 *radio;
    in the MyDriverRF69.h file
  • Hi everyone,
    i am new to MySensors. I already made sime Arduino pro mini running with a NRF24L01.
    But i also bought some Anarduino with the RF69 installed. Can anybody tell me how i can tell the library to use the RF69 instead of the NRF24L01?
    I used the Developement version of the MySensor library. I tried to find the point in MyConfig.h but i could only find the NRF24L01 Driver Defaults part.
    Maybe someone could help me.
    Thanks in advance.
    Benjamin
  • I'm interested in the progress of getting RadioHead working with MySensor....
    what the current status??
    where is the current code for this effort?
    @lafleur
    In the development branch on github we have support for RF69. We have not incorporated the full RadioHead library.
