  3. Newbie Question
Newbie Question
11 Posts 2 Posters 3.5k Views 2 Watching
  • M martim
    HI,
    I am brand-new to this forum and sorry if I ask stupid questions. I have a Wemos D1 mini without radio. I would like show the sensor data (DS 18B20) on a website served by the Wemos. Or connect it with Homey (mysensors app).
    Would that be possible? When I use the code and I would like to comment out the radio part, it won't compile. Is this not possible or do I need to do something else?
    Does somebody has maybe an example?
    Marcel
    Hi @martim, big welcome to the MySensors community!
    Yes, it can be done. You will configure the wemos d1 as a gateway with a local sensor. The gateway can then be added to any controller.
    Start with building the plain gateway, by following the instructions at https://www.mysensors.org/build/esp8266_gateway
    Verify that it works and add it to your controller. Doing this first small step will save you a lot of time. Trying to do both gateway+sensor in one step is harder.
    When the gateway is working, add the temperature example to the gateway sketch and you should be good to go.
      martim
      Hi @mfalkvidd,
      Thank you. I have installed the software, can connect to internet. But in the output of serial window I see:
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;!TSM:RADIO:FAIL
      0;255;3;0;9;!TSM:FAILURE
      0;255;3;0;9;TSM:PDT
      I can also not access http://<ip>:5003 (not sure if this is possible).
      So, without additional code I can try to add it to homey (my controller)?
      • M martim
        Hi @mfalkvidd,
        0;255;3;0;9;TSM:PDT
        @martim sorry, I should have mentioned that you need to remove/comment out this line:
        Do that and upload the sketch again.
        With the nrf24 code activated, but no radio connected, the gateway won't start properly.
        Accessing it through http://<ip>:5003 won't work though, because it is not a web server. I think you could connect to it using telnet though.
          martim
          wrote on last edited by martim
          That seems to work :). Would it be possible to simulate a sensor? (To start easy :)) Ooh, and could you also tell me where I can find the documentation of the MySensors library (which function I can use)?
          • M martim
            @martim the documentation is available at the "Download & API" link at the top right of this page :)
            The build examples (including the temperature I linked to earlier) are also good, I like to learn by looking at examples.
            Simulating a sensor is a good idea. I don't think we have a "dummy" example though. Maybe we should add one.
              martim
              Ok. Thanks for all your help. I need to solder the pins first before I can attach my sensor. A dummy would be indeed helpful. But I will attach the sensor tomorrow after I have solder the header pins.
              • M martim
                @martim your question got my brain churning and today a similar question was posted so here is a dummy sensor: https://forum.mysensors.org/topic/5119/how-to-create-a-fake-local-sensor-on-ethernet-gateway/2
                  martim
                  Thanks! I will try this!
                  By the way the documentation in the zip file is more or less empty?
                  • M martim
                    @martim could you clarify which zip file?
                      martim
                      @mfalkvidd, when you download the library 2.0 and you extract this. There is a folder documentation which is almost empty. But in the meantime I found also a link api on the download location with more info.
                      The sketch did work! Great! Based on this example I can going forward.
