  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 50.6k Views 38 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    Is it possible to add an ds18b20 to the Sensebender?
    RJ_Make
    • RJ_MakeR RJ_Make
      GertSandersG
      GertSandersG
      GertSanders
      @RJ_Make
      That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
      In any case you can connect it via de exposed pins.
      RJ_MakeR 1 Reply Last reply
      • GertSandersG GertSanders
        @RJ_Make
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
        RJ_Make
        • RJ_MakeR RJ_Make
          GertSandersG
          GertSandersG
          GertSanders
          @RJ_Make
          Certainly possible, check the examples.
          • SaimenS
            SaimenS
            Saimen
            is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
            I had a little bit trouble last weekend, to get it run.
            I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
            But thanks for this Great Projekt, and this great Board Sensenbender Micro
            Saimen
            • tbowmoT
              tbowmoT
              tbowmo
              @Saimen
              External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
              This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
              • SaimenS
                SaimenS
                Saimen
                @tbowmo Thank you very much for your response and explaining.
                • fearoffishF
                  fearoffishF
                  fearoffish
                  Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
                  • phildeferP
                    phildeferP
                    phildefer
                    @tbowmo
                    I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                    In the sketch (https://www.mysensors.org/hardware/micro) the line
                    //#include <avr/power.h>
                    is commented.
                    Is it "normal" or is it a mistake ?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @phildefer
                      I think it's a leftover from a cleanup at some point in time. Not used anymore.. The MySensors core library is handling the sleep mechanism now.
                      • denisvdbD
                        denisvdbD
                        denisvdb
                        To reprogram the sketch in a sensbender micro, wich board must be selected in the arduino prg?
                        I have problem with inclusion in jeedom, the command are not loaded.
                        thx
                        • fearoffishF fearoffish
                          marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          @fearoffish did you manage to get this working?
                          And, if so, what was the issue?
                          I am looking into changing to PlatformIO on Atom or even CLion...
                          Fulltime Servoy Developer
                          • loic13L
                            loic13L
                            loic13
                            Hi, I'm getting this error message when compiling the sketch with the 2.1.1 MySensors library:
                            SensebenderMicro:168: error: 'getConfig' was not declared in this scope
                            isMetric = getConfig().isMetric;
                            I just commented out the line as workaround, but not sure that its correct.
                              Hmm.. The api was recently changed to getControllerConfig().isMetric;
                              I'll update the example.
                              • loic13L
                                loic13L
                                loic13
                                Thank you.
                                • T
                                  Toyman
                                  How difficult is to replace 0402 components with 0603 or 0804 components in Eagle? I am too old for 0402 soldering :-)))
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Toyman
                                    Not that hard, but you'll probably need to redesign the board, to get room for the larger components.
                                    Another option is to order the board pre-assembled from our partner, itead studio
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      I've tested to upload a sketch to the Sensebender Micro using platformio.
                                      Put the following JSON into a json file in a folder named boards either in the MySensors library folder (your project in platformio), or somewhere else on the search path. Use the name of the json file in platformio.ini in the board setting. See for more info:
                                      http://docs.platformio.org/en/latest/platforms/creating_board.html
                                      • Create a folder named boards in MySensors project folder.
                                      • Create a file in boards named sensebendermicro8MHz.json.
                                        "build": {
                                          "core": "arduino",
                                          "extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_PRO",
                                          "f_cpu": "8000000L",
                                          "mcu": "atmega328p",
                                          "variant": "standard"
                                        "frameworks": [
                                          "arduino"
                                        "fuses": {
                                          "efuse": "0x06",
                                          "hfuse": "0xD2",
                                          "lfuse": "0xE2",
                                          "lock": "0x3F"
                                        "name": "Sensebender Micro (3.3V, 8 MHz)",
                                        "upload": {
                                          "maximum_ram_size": 2048,
                                          "maximum_size": 30720,
                                          "protocol": "arduino",
                                          "require_upload_port": true,
                                          "speed": 57600
                                        "url": "https://github.com/mysensors/SensebenderMicro",
                                        "vendor": "MySensors"
                                      • Add an env in platformio.ini.
                                      [env:sensebendermicro8MHz]
                                      platform = atmelavr
                                      framework = arduino
                                      board = sensebendermicro8MHz
                                      lib_deps = MySensors
                                      • Compile sketch.
                                      • Upload sketch.
                                      I think I've got the settings correct, but it was the first time I did this. But it's tested and works as far as I can see.
                                      Should we add a JSON file to one of the mysensors repos on github?
                                        https://www.mysensors.org/view/1/Sensebender-Micro
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        I have a bunch of W25X40CLSNIG-ND lying around.
                                        They have the same size and same layout as far as I can see.
                                        Is my thinking correct that I should be able to simply replace the AT25DF512C-SSHN-B, change the sketch and use it?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @marceltrapman
                                          If it's a jedec compatible flash, then you should be able to swap.. But what is the usecase of a larger flash? You can't execute code in the external flash.. So for OTA you still only have a bit under 32Kbyte usefull space..
