  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.3k Views 38 Watching
  • GertSandersG GertSanders
    @RJ_Make
    That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
    In any case you can connect it via de exposed pins.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
    RJ_Make
    • RJ_MakeR RJ_Make
      GertSandersG
      GertSandersG
      GertSanders
      @RJ_Make
      Certainly possible, check the examples.
      • SaimenS
        SaimenS
        Saimen
        is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
        I had a little bit trouble last weekend, to get it run.
        I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
        But thanks for this Great Projekt, and this great Board Sensenbender Micro
        Saimen
        • tbowmoT
          tbowmoT
          tbowmo
          @Saimen
          External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
          This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
          • SaimenS
            SaimenS
            Saimen
            @tbowmo Thank you very much for your response and explaining.
            • fearoffishF
              fearoffishF
              fearoffish
              Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
              • phildeferP
                phildeferP
                phildefer
                @tbowmo
                I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                In the sketch (https://www.mysensors.org/hardware/micro) the line
                //#include <avr/power.h>
                is commented.
                Is it "normal" or is it a mistake ?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @phildefer
                  I think it's a leftover from a cleanup at some point in time. Not used anymore.. The MySensors core library is handling the sleep mechanism now.
                  • denisvdbD
                    denisvdbD
                    denisvdb
                    To reprogram the sketch in a sensbender micro, wich board must be selected in the arduino prg?
                    I have problem with inclusion in jeedom, the command are not loaded.
                    thx
                    • fearoffishF fearoffish
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      @fearoffish did you manage to get this working?
                      And, if so, what was the issue?
                      I am looking into changing to PlatformIO on Atom or even CLion...
                      Fulltime Servoy Developer
                      • loic13L
                        loic13L
                        loic13
                        Hi, I'm getting this error message when compiling the sketch with the 2.1.1 MySensors library:
                        SensebenderMicro:168: error: 'getConfig' was not declared in this scope
                        isMetric = getConfig().isMetric;
                        I just commented out the line as workaround, but not sure that its correct.
                          Hmm.. The api was recently changed to getControllerConfig().isMetric;
                          I'll update the example.
                          • loic13L
                            loic13L
                            loic13
                            Thank you.
                            • T
                              Toyman
                              How difficult is to replace 0402 components with 0603 or 0804 components in Eagle? I am too old for 0402 soldering :-)))
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Toyman
                                Not that hard, but you'll probably need to redesign the board, to get room for the larger components.
                                Another option is to order the board pre-assembled from our partner, itead studio
                                • martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  I've tested to upload a sketch to the Sensebender Micro using platformio.
                                  Put the following JSON into a json file in a folder named boards either in the MySensors library folder (your project in platformio), or somewhere else on the search path. Use the name of the json file in platformio.ini in the board setting. See for more info:
                                  http://docs.platformio.org/en/latest/platforms/creating_board.html
                                  • Create a folder named boards in MySensors project folder.
                                  • Create a file in boards named sensebendermicro8MHz.json.
                                    "build": {
                                      "core": "arduino",
                                      "extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_PRO",
                                      "f_cpu": "8000000L",
                                      "mcu": "atmega328p",
                                      "variant": "standard"
                                    "frameworks": [
                                      "arduino"
                                    "fuses": {
                                      "efuse": "0x06",
                                      "hfuse": "0xD2",
                                      "lfuse": "0xE2",
                                      "lock": "0x3F"
                                    "name": "Sensebender Micro (3.3V, 8 MHz)",
                                    "upload": {
                                      "maximum_ram_size": 2048,
                                      "maximum_size": 30720,
                                      "protocol": "arduino",
                                      "require_upload_port": true,
                                      "speed": 57600
                                    "url": "https://github.com/mysensors/SensebenderMicro",
                                    "vendor": "MySensors"
                                  • Add an env in platformio.ini.
                                  [env:sensebendermicro8MHz]
                                  platform = atmelavr
                                  framework = arduino
                                  board = sensebendermicro8MHz
                                  lib_deps = MySensors
                                  • Compile sketch.
                                  • Upload sketch.
                                  I think I've got the settings correct, but it was the first time I did this. But it's tested and works as far as I can see.
                                  Should we add a JSON file to one of the mysensors repos on github?
                                    https://www.mysensors.org/view/1/Sensebender-Micro
                                    marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    I have a bunch of W25X40CLSNIG-ND lying around.
                                    They have the same size and same layout as far as I can see.
                                    Is my thinking correct that I should be able to simply replace the AT25DF512C-SSHN-B, change the sketch and use it?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @marceltrapman
                                      If it's a jedec compatible flash, then you should be able to swap.. But what is the usecase of a larger flash? You can't execute code in the external flash.. So for OTA you still only have a bit under 32Kbyte usefull space..
                                      • tbowmoT tbowmo
                                        @marceltrapman
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        wrote on last edited by marceltrapman
                                        #32
                                        @tbowmo no case at all, just that I have them and otherwise probably won't use them..
                                        • Michiel van der WulpM
                                          To reprogram the sketch in a sensbender micro, wich processor frequency do I choose?
                                          After choosing Board "Sensebender Micro", the menu in Arduino 1.6.12 has choice Processor "Atmega328 8MHz" and "Atmega328 1MHz".
                                          My code seems to be executed equally fine with both settings.
                                          But the Arduino Serial Monitor not:
                                          If I choose the 1MHz version, the Serial monitor only produces garbage, whatever setting I choose for baud (in the sketch and in the serial monitor UI).
                                          If I choose the 8MHz version, the serial monitor works fine.
                                          I am confused. The Sensebender is a 1MHz device, isn't it? Is it able to run on 8MHz too?
