  3. Battery powered PIR
Battery powered PIR
18 Posts 11 Posters 24.6k Views 14 Watching
  • D darazs
    @therik Yeah, now that I've read through your "Efficiency of Voltage Boosters" topic, I understand things a little better, and I really have no clue why removing the caps made the PIR more stable. BUT your topic helped me solve my packet loss/acks not arriving problem by adding a bigger capacitor to my radio, so what I want to say is that you're awesome, thanks! :)
    Mrlynx
    @m26872 I am looking at xc6206 and tc2117 that have a low quiescent current and a dropout of 50-100 mV at low currents.
    http://www.sa2avr.se
    • M Mrlynx
      @therik I recently observed the same behaviour with a step-up regulator based on a 2108A.
      The strange thing is that the sensor behaves erratic when powered from 2 fresh AA alkaline batteries (approx. 3.2V input to the regulator) but works just fine when powered by some older AA alkaline batteries (approx. 2.6V input).
      I quickly inspected the output of the regulator with a scope, but saw no clear differences between the two. Maybe the output was less stable at 3.2V input.
      Next I'll try using a diode to lower the voltage a little, either before or after the regulator.
      • riaan003R
        riaan003R
        riaan003
        I am trying to figure out if running this modification from 3 AAs at 4.5V will work (it is for a setup with a attiny85 that I want to run from 4.5 down to 3.3v - it currently works well from 5 down to 4.5 with exactly the erratic behaviour explained above from about 4.4v and down). When looking at the datasheet for the BIS0001 then it seems like it will fine? What am I missing? :)
        • T
          therik
          A couple of questions.
          1. Did you remove the voltage regulator from the PIR?
            a. if not, I would suspect that the voltage regulator on the PIR drops out and cannot supply the voltage for the PIR IC below 4V5.
          2. Where do you derive the power for the PIR?
            a. If it is from the µC, the µC may be adding noise on the voltage supply to the PIR and with the PIR voltage regulator removed the supply voltage may be too noisy.
          • riaan003R
            riaan003R
            riaan003
            The regulator was not removed yet, no, the behaviour was with my unmodified sensor. I have actually now started looking at an alternative power setup so that i can use this mod at 3.3v and drop the requiment for it to run from 4.5v (which was based on running it upregulated from 3 AAs with an attiny85 woken up from sleep mode - which worked well and consumed ~0.1mA overall). Back to the drawing board :)
            • Igor KatkovI
              Igor KatkovI
              Igor Katkov
              How did you produce that nice ripple charts? Oscilloscope connected to a computer? What is the model?
              • HaakonH
                HaakonH
                Haakon
                Thanks for sharing, @therik. Where can I get the high-ripple-rejection-ratio regulator you are describing? I cannot find an FT531IA on Ebay. (Or if therik is no longer following the topic: Anyone else know a specific regulator I gan get from Ebay?)
                Thanks in advance.
                • L
                  L
                  LastSamurai
                  It's still on aliexpress. Could a AMS1117 work too though? It's ripple rejection isn't bad for what I have read. Although I don't get the part of the specs.. if you use a fixed version do you still need a capacitor on the GND (adj) pin for the ripple rejection?
                  HaakonH 1 Reply Last reply
                  • L LastSamurai
                    HaakonH
                    HaakonH
                    Haakon
                    Thanks, @LastSamurai! I have ordered a few to try them out. (Not sure about the question about AMS1117, hopefully there are someone here who are.)
                    • n1ck1355N
                      n1ck1355N
                      n1ck1355
                      Hi :)
                      does anyone know where i actually find the FT531IA? on aliexpress there are only FT531EA with output of 2.5V :(
