716 Posts 111 Posters 703.2k Views 93 Watching
    Matt
    Had further problems with intermittent sends. Sometimes on initial presentation it only sends the sketch name and not version number. Also sends are infrequent up to six hours apart. When it does send it often only sends one child_id when there are three to send.
    Previously I thought this was most likely an issue with a noisy boost converter. However I just tried replacing the 4.7uf cap on the radio with a 47uf one. Problem solved!
    Matt
    • M Matt
      Matt
      sundberg84S
      sundberg84S
      @Matt - Nice to hear problem solved! Its again the sensitive radio and the booster might be the cause since changing the cap worked.
      One trick is also to add a delay(10) between the presentations if possible. Sometimes the radio cant keep up or something...
      • EfflonE
        EfflonE
        Efflon
        Gah! I ordered through the https://www.openhardware.io/order/4/PCB10X link from Itead but got the rev8 boards. Thought the "I always update the gerber files for sale" meant it was safe to order...
        • EfflonE Efflon
          #262
          @Efflon did the order say version m5 when you ordered? Which date did you place the order?
          EfflonE 1 Reply Last reply
            EfflonE
            EfflonE
            Efflon
            @mfalkvidd I ordered January 2 and can't remember what version was stated. I'm quite sure I picked Itead because it had a higher version numer (and a slightly higher price), honestly don't remember. All I know is that I didn't read this thread but rather just browsed through the page and clicked order. Afterwards I realized it wasn't clear if it was the 5V or 3.3V version but the order said 5x5cm. I also missed to choose color but "grönt är skönt".
            Guess what confused me most was the statement "It may say another rev. at the orderpage but this is not EasyPCB rev but the rev for manufacturer." causing me to be trigger happy :smile:
            • EfflonE Efflon
              sundberg84S
              sundberg84S
              @Efflon - sorry to hear you got rev 8 if you wanted rev 9.
              I wrote this notice just because itead was so slow updating to the right revision! I also spoke to hek about this a month ago according to my chat log.
                Sorry to hear... Checked the log. The order was for manufacturer revision 4 (which is what @sundberg84 call rev 8 ).
                The system automatically increments the revision number each time an author makes a new release. Each manufacturer must set price on each revision(which in some cases may take a while if they do this manually). Until they've done that, any older revision where they've set a price is still available for purchase.
                The revision is stated below the big order-button.
                • AmputA
                  AmputA
                  Amput
                  wrote on last edited by Amput
                  #266
                  Could anyone explain me, why position (polarity) of condensers 4.7uF on REV 8(blue) and REV 9 (red) are different?
                  ferroF 1 Reply Last reply
                  • AmputA Amput
                    ferroF
                    ferroF
                    ferro
                    @Amput said in 💬 Easy/Newbie PCB for MySensors:
                    It's a bug in v8 fixed in v9, so v9 is correct, see link this post
                    AmputA 1 Reply Last reply
                    • martinsM
                      martinsM
                      martins
                      @SUNDBERG84 - Do you have a board/design for the RFM69 radio ?
                      Rergards,
                      Martin
                      ferroF sundberg84S 2 Replies Last reply
                      • martinsM martins
                        Rergards,
                        Martin
                        ferroF
                        ferroF
                        ferro
                        @martins - you can use NRF2RFM69 if you want to use RFM69 with Newbie PCB board. I'm using it too, works fine with 3.3V arduino. For 5V arduino you will need to add level logic converter too.
                        martinsM 1 Reply Last reply
                        • ferroF ferro
                          martinsM
                          martinsM
                          martins
                          @ferro
                          Pity because that would double the cost of the sensor board:
                          Order PCBs for Easy/Newbie PCB for MySensors : $15
                          Order PCBs for NRF2RFM69 : $15
                          Martin
                          • ferroF ferro
                            AmputA
                            AmputA
                            Amput
                            @ferro said in 💬 Easy/Newbie PCB for MySensors:
                            Thx for answer :-).
                            • martinsM martins
                              Rergards,
                              Martin
                              sundberg84S
                              sundberg84S
                              @martins - No, not at the moment. It has been asked before but I have never got my head around it.
                              As i told before, you are happy to develop it yourself. I have some other things in my list but in the future maybe :)
                              • meanmrgreenM
                                meanmrgreenM
                                meanmrgreen
                                wrote on last edited by meanmrgreen
                                #273
                                • meanmrgreenM
                                  meanmrgreenM
                                  meanmrgreen
                                  • N
                                    N
                                    N00phi
                                    Hi
                                    I've tried to order the capaciter and voltage regulator from our local electronics supplier. The choice is too big. Could anyone please help a "newbie" to select the right parts for a raw powered 5V version
                                    • 4.7uF capacitor
                                    • voltage regulator
                                    • 0.1 and 10uF cap
                                      http://www.distrelec.ch/ can't select the parts because of missing size and especially for the voltage regulator the exact type.
                                    • N N00phi
                                      Hi
                                      • 4.7uF capacitor
                                      • voltage regulator
                                      • 0.1 and 10uF cap
                                      sundberg84S
                                      sundberg84S
                                      @N00phi - I usually just select the ones at www.mysensors.org/store but if you have a specific site you wish to order from I can choose for you.
                                      N 1 Reply Last reply
                                      • sundberg84S sundberg84
                                        N
                                        N
                                        N00phi
                                        @sundberg84 It would be absolutely great if you could do so! I would order at http://www.distrelec.ch ...
                                        • N N00phi
                                          sundberg84S
                                          sundberg84S
                                          @N00phi for the capacitors: http://www.distrelec.ch/search?q=electrolytic+capacitor&filter_Rated+voltage~~VDC=50&filter_Diameter+housing~~mm=4&filter_Diameter+housing~~mm=5 (choose the axial types which is the one with two legs).
                                          As for the voltage regulator I use LE33ACZ 5V-3.3V which i cant find on that site.
                                          dbemowskD N 2 Replies Last reply
