  3. Multiple Servos
Multiple Servos
9 Posts 3 Posters 3.8k Views 4 Watching
  • numanxN Offline
    numanxN Offline
    numanx
    Hi there,
    Could someone help me with a sketch for running multiple servos.
    Like in the example for the Relay Actuator
    #define SERVO_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_SERVOS 1 // Total number of attached relays
    My current sketch is:
    // Debug
    // Partea cu Conexiunea la net
    #define MY_GATEWAY_ENC28J60
    #define MY_IP_ADDRESS 192,168,1,66
    #define MY_PORT 5003
    #include <UIPEthernet.h>
    // Sfarsit parte
    #include <Servo.h>
    #define SERVO_DIGITAL_OUT_PIN 4
    #define SERVO_MIN 0 // Fine tune your servos min. 0-180
    #define SERVO_MAX 180  // Fine tune your servos max. 0-180
    #define DETACH_DELAY 900 // Tune this to let your movement finish before detaching the servo
    #define CHILD_ID 10   // Id of the sensor child
    MyMessage msg(CHILD_ID, V_DIMMER);
    Servo myservo;  // create servo object to control a servo
                    // a maximum of eight servo objects can be created Sensor gw(9,10);
    unsigned long timeOfLastChange = 0;
    bool attachedServo = false;
    bool state;
      // Request last servo state at startup
      request(CHILD_ID, V_DIMMER);
    void presentation()  {
      sendSketchInfo("Servo", "1.0");
      present(CHILD_ID, S_DIMMER);
      if (attachedServo && millis() - timeOfLastChange > DETACH_DELAY) {
         myservo.detach();
      myservo.attach(SERVO_DIGITAL_OUT_PIN);
      attachedServo = true;
      if (message.type==V_DIMMER) { // This could be M_ACK_VARIABLE or M_SET_VARIABLE
         int val = message.getInt();
         myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * 1.8 * val); // sets the servo position 0-180
         Serial.print("Servo changed. new state: ");
         Serial.println(val);
       timeOfLastChange = millis();
    gohanG 1 Reply Last reply
    • numanxN numanx
      Hi there,
      // Debug
      // Sfarsit parte
      #include <Servo.h>
      bool state;
           myservo.detach();
      @numanx but do you want to control each servo individually or all together at the same time?
      • numanxN Offline
        numanxN Offline
        numanx
        Individually, thanks for your reply!
          You stripped a lot of code from the relay sketch, I think you need to put back all the FOR cycles it you want the code handle automatically the number of servos
          • numanxN Offline
            numanxN Offline
            numanx
            Ok so here is the sketch with the for cycles.
            But it still won't work. The servos are presented to the Controller but it won't make any move.
            I think the problem is with the void receive.
            I don't know how to change
            for the servo
            // Debug
            // Sfarsit parte
            #include <Servo.h>
            #define SERVO_1 4 // Arduino Digital I/O pin number for first servo (second on pin+1 etc)
            #define NUMBER_OF_SERVOS 2 // Total number of attached servos
            //#define CHILD_ID 10   // Id of the sensor child
            //MyMessage msg(CHILD_ID, V_DIMMER);
            bool state;
            void before()
                for (int servo=1, pin_S=SERVO_1; servo<=NUMBER_OF_SERVOS; servo++, pin_S++) {
                  myservo.attach(pin_S);
                  request(servo, V_DIMMER);
                  present(servo, S_DIMMER);
                 myservo.detach();
            • numanxN numanx
              for the servo
              // Debug
              // Sfarsit parte
              #include <Servo.h>
              bool state;
              void before()
                   myservo.detach();
              @numanx start adding some debug prints and see where data is not correct
              numanxN 1 Reply Last reply
                numanxN Offline
                numanxN Offline
                numanx
                @gohan
                Debug print when changing the dimmer slider to different values.
                0;255;3;0;9;Eth: 0;0;3;0;2;
                0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                0;255;3;0;9;Eth: 0;1;1;1;3;7
                Servo changed. new state: 7
                0;255;3;0;9;Eth: 0;0;3;0;18;PING
                0;255;3;0;9;Eth: 0;1;1;1;3;21
                Servo changed. new state: 21
                0;255;3;0;9;Eth: 0;1;1;1;3;36
                Servo changed. new state: 36
                • numanxN Offline
                  numanxN Offline
                  numanx
                  Found this on arduino.cc forum.
                  I think there should be a way for creating different servo objects for each servo but I don't know how to do that.
                  Any sugestion from @mfalkvidd ?
                  #include <Servo.h>
                   Servo myservo[6];
                  int pinAttch = 0;    // variable to store pin attachment
                  int servWrite = 0;    // variable to store servo writing
                    Serial.begin(9600);
                    for(pinAttch = 2; pinAttch < 7; pinAttch++)
                      myservo[pinAttch].attach(pinAttch);
                  for(servWrite = 2; servWrite < 7; servWrite++)
                    myservo[servWrite].write(80);
                    delay(2000);
                  exit(0);
                  • A Offline
                    A Offline
                    anno
                    12.2k
