  3. compiling the code for sensebender micro
11 Posts 2 Posters 2.9k Views 2 Watching
  • mhkoM Offline
    mhkoM Offline
    mhko
    hi
    I am getting no were with this sensebender micro.
    i get this message all the time, i have read and searched all i can find, but I do not get the clue i need to get the issue solved.
    I get that it has to do with the upgrade to 2.x.x, but i do not get how to solve the issue.
    can somebody tell me the missing links?
    thanks in advance
    • mhkoM mhko
      hi
      thanks in advance
      T Offline
      T Offline
      tbowmo
      @mhko
      You need to install the driver library for Si7021, it is located in the MySensorsArduinoExamples repository
      • mhkoM Offline
        mhkoM Offline
        mhko
        thank you.
        it maybe me that is a bit thick, but how do i do that?
        • T Offline
          T Offline
          tbowmo
          @mhko
          Copy the folder with Si7021 from the above link, into your library folder under Arduino.
          • mhkoM Offline
            mhkoM Offline
            mhko
            is that the same folder as in the picture?
            because i have tried only the si7021.h file, a folder with everything from you link, and i stile come with the same error.
            • T Offline
              T Offline
              tbowmo
              copy the directories from the library folder in the above link, into libraries on your local machine
              so that the folder structure will be:
              <user-or-wherever-things-are-located-on-your-computer-system>\Arduino\libraries\Si7021\Si7021.h/cpp
              • mhkoM Offline
                mhkoM Offline
                mhko
                thanks a lot.
                i could just not see that link.
                now it is compiling, but missing several other things on it way.
                but now i know the routine.
                • mhkoM Offline
                  mhkoM Offline
                  mhko
                  today i get this error list:
                  Arduino: 1.8.3 (Windows 7), Board: "Sensebender Micro, Atmega328 8Mhz"
                  In file included from C:\Users\mko\Documents\Arduino - sketch\Sensebender 1.4\SensebenderMicro-master\SensebenderMicro-master\Arduino\SensebenderMicro\SensebenderMicro.ino:61:0:
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:23:3: error: stray '\302' in program
                  <title>MySensorsArduinoExamples/SI7021.h at master · mysensors/MySensorsArduinoExamples · GitHub</title>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:23:3: error: stray '\267' in program
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:133:3: error: missing terminating ' character
                  <!-- '"` --><!-- </textarea></xmp> --></option></form><form accept-charset="UTF-8" action="/mysensors/MySensorsArduinoExamples/search" class="js-site-search-form" data-scoped-search-url="/mysensors/MySensorsArduinoExamples/search" data-unscoped-search-url="/search" method="get"><div style="margin:0;padding:0;display:inline"><input name="utf8" type="hidden" value="✓" /></div>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:480:69: error: stray '#' in program
                       <td id="LC6" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">ifndef</span> si7021_h</td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:484:69: error: stray '#' in program
                       <td id="LC7" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">define</span> <span class="pl-en">si7021_h</span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:493:69: error: stray '#' in program
                       <td id="LC9" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">if</span> (ARDUINO &gt;= 100)</td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:497:71: error: stray '#' in program
                       <td id="LC10" class="blob-code blob-code-inner js-file-line"> #<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds">&quot;</span>Arduino.h<span class="pl-pds">&quot;</span></span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:501:70: error: stray '#' in program
                       <td id="LC11" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">else</span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:505:71: error: stray '#' in program
                       <td id="LC12" class="blob-code blob-code-inner js-file-line"> #<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds">&quot;</span>WProgram.h<span class="pl-pds">&quot;</span></span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:509:70: error: stray '#' in program
                       <td id="LC13" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">endif</span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:518:70: error: stray '#' in program
                       <td id="LC15" class="blob-code blob-code-inner js-file-line">#<span class="pl-k">ifdef</span> __AVR_ATtiny85__</td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:522:71: error: stray '#' in program
                       <td id="LC16" class="blob-code blob-code-inner js-file-line"> #<span class="pl-k">include</span> <span class="pl-s"><span class="pl-pds">&quot;</span>TinyWireM.h<span class="pl-pds">&quot;</span></span></td>
                  C:\Users\mko\Documents\libraries\SI7021/SI7021.h:526:71: error: stray '#' in program
                       <td id="LC17" class="blob-code blob-code-inner js-file-line"> #<span class="pl-k">define</span> <span class="pl-en">Wire</span> TinyWireM</td>
                  it goes on and on.
                  any one knows why?
                  • T Offline
                    T Offline
                    tbowmo
                    looks like you put a html document in there, instead of just the plain text file?
                    • mhkoM Offline
                      mhkoM Offline
                      mhko
                      i was because i saved the files from you link via my browser.
                      now it is fixed.
                      thanks again for your time and help.
                      • mhkoM mhko
                        now it is fixed.
                        T Offline
                        T Offline
                        tbowmo
                        @mhko
                        No problem, glad to be of assistance :)
                        12.2k
