  3. 💬 NModule
💬 NModule
mysensorsnmoduletemperaturedoorlightpirhumidityrelaymilighttouchaccelerometer
89 Posts 12 Posters 29.9k Views 10 Watching
  • X Ximper
    I have used Seeed PCB service a few times in the past. They are not quite the cheapest but still excellent value, and for that little bit extra they do a better job than most.
    @Ximper well at US$4.90 for 10 boards up to 10*10cm they are the cheapest now ;)
    X 1 Reply Last reply
    • Nca78N Nca78
      X
      X
      Ximper
      @Nca78 Oh yes, it's $4.9 now. My last order was in March this year, it was $9.9 at at time, thank you for the correction :+1:
        #28
        Wow. $4.90 sounds great. What's their total turnaround time, including delivery? Actual delivery time, not just advertised delivery time, I mean.
        Nca78N 1 Reply Last reply
          @NeverDie they take 5 opening days to make the boards.
          Than the shipping depends on what option you choose, but cheapest shipping is US$11 with HK Post (no tracking), it seems to take around 2 weeks to arrive in the US.
          • D
            dakipro
            for best battery life it is advisable to burn bootloader mentioned in the text.
            How much would a battery lifetime be, for example one single temp sensor reading every 5min?
            When using custom bootloader, then over the air updates cannot be used? Or could the MYSBootloader be configured to take most of the cr2025 battery?
            • D dakipro
              Hello @dakipro,
              what is necessary is to remove the default BOD limit, it is set at 2.7V and that is too high :
              • even if CRxxxx cells were running like alkaline cells, this would waste a big share of the capacity, around 30% I think
              • CRxxxx are not like alkaline cells, they have a high internal resistance and can supply only a limited amount of current, else the voltage drops. Meaning that in fact you will reach this 2.7V much faster if you have several RX/TX in a row
              That is the main limit. I also advise to change the frequency to 1MHz and use internal oscillator if you have no calculation to do: door sensor, all basic I2C sensors etc etc because at 1MHz the power consumption is significantly lower. With NRF24 and I2C sensors it will not slow the "on" time much, data sent to/from radio and sensors takes very little time to transfer and main time is for waiting for radio reply or data from sensor: not affected by frequency so better have consumption as little as possible.
              For battery lifetime if you remove leds and regulators with si7021 it will be way over 1 year. I have not tested those sensors for long enough, but I've had some round "puck" sensors with si7021 running for a few months on chinese CR2032 and I have not seen any voltage drop. Interval time is set to 1mn, it's not sending 5x more than 5mn interval (because often in one minute temp/hum don't change) but probably 2-3 times more, and with that I have no doubt the batteries will last way over a year.
              My entrance door sensors is my oldest sensor, also running on pro mini (and still have it's TX led) and chinese CR2032, it uses the normally opened + normally closed reed swich and after 14-15 months of use is still at 85% of battery.
              You can check that on battery life calculators anyway :
              • with WDT disabled (= when you are not waking up periodically) consumption of board is below 2uA
              • with WDT enabled and si7021 I measured it below 6uA
              • when on with radio enabled for transmit/receive, at 1MHz power consumption is around 15mA when battery is new, a bit lower
              This is a worse case scenario with battery capacity lowered to account for chinese battery (brand name is 220), and long wake up time with radio considered always on, sending data every 5 mns.
              In reality radio is switched on only when data must be sent so time for reading voltage and sensor value is done consuming around 1mA at 1MHz.
              • D
                dakipro
                thanks for detailed explanation, I was always a bit skeptical towards those small batteries, but your module (and documentation) clears all doubts :)
                Do you have any experience with OTA updates? I understand that it also needs custom boot-loader (sorry still not having enough understanding about all the things that are involved in making one node, a lot of new terms for me :) )
                • D dakipro
                  @dakipro no sorry I'm not (yet) using OTA.
                  But yes you need a specific bootloader that will download the new code from the controller and update flash memory of the atmega. There are 2 solutions for this (sorry forgot the names of bootloaders but check the documentation):
                  • a bootloader that needs an external flash chip to store the downloaded code. It's a constraint, but it allows the sensor to continue running during download and it will be "offline" only for a short time during memory copy & reboot
                  • a bootloader that will copy directly the new code to the flash memory. It means as soon as the sketch started to download your node is offline until all the sketch is downloaded. And if update fails, your old sketch is still gone
                  OTA also need some specific code to check for the updates.
                  • D
                    dakipro
                    Then I guess all that is left is to motivate you to start OTA and improve it (finetune) it to nmodule :)
                    I used it for regular modules and it is really practical, but I never had much luck with optimizing modules for battery performance. I would get a half year/year with 2 AA batteries, which is not that good comparing with your tweaks for CR battery.
                    Keep us updated on other modules, people are waiting for your tests to start ordering :)
                    Nca78N 2 Replies Last reply
                    • D dakipro
                      @dakipro for OTA I don't think there's much to do with batteries & OTA' Either the batteries allow continuous load (CR123, AAA, li-ion etc) or you just can't do it.
                      For battery life it's pretty simple but people keep choosing the wrong options and end up with poor battery life/instability etc etc. That's the reason I created the NModule: cheap and sure way to get a good battery life. Then I got a bit wild with the "shields" but that's another story :D
                      For other shields I'm making (slow) progress but I hope to take NModule, TH, Light/SSR, dual touch button, MiLight bridge and PWM boards out of the "work in progress" status during the next 2 weeks.
                      • D
                        dakipro
                        Hey @Nca78 I received the boards and components (yay!)
                        But... I connected three modules, and none of them works :(
                        They all have transport (radio?) fail like
                        32 TSM:INIT
                        49 TSF:WUR:MS=0
                        81 !TSM:INIT:TSP FAIL
                        98 TSM:FAIL:CNT=1
                        114 TSM:FAIL:PDT
                        I tried connecting radios from two different batches, I tried connecting only the radio and arduino, I tried powering it from separate powersupply and only debug via serial. I tried provided sketch and also tried dummy sketch from the examples. I tried using the CR battery, node works fine except that the radio doesn't start communicating.
                        I do measure 3V on the radio pins. I tried with and without radio cap.
                        I am using chinese silicon mat to solder components on, I read somewhere that you use something similar *(not that I am spying on you :) ) but could it be that I am frying all the radios with static electricity?
                        I have used the mat before and it works fine with regular radios, nothing fried so far, but there is something preventing nodes from working :(
                        Do you have any suggestions on how I can debug them and see what seems to be the problem?
                        Nca78N NeverDieN 2 Replies Last reply
                        • D dakipro
                          32 TSM:INIT
                          49 TSF:WUR:MS=0
                          98 TSM:FAIL:CNT=1
                          114 TSM:FAIL:PDT
                          Hello, @dakipro, can you show a picture of one of the board ?
                          Did you short the jumpers (JPOWER and JRDIO) if you're not using any regulators ?
                          Yes I use a cheap silicon mat because it's so convenient, and I never had any problems with it all my radio worked.
                          • D dakipro
                            32 TSM:INIT
                            49 TSF:WUR:MS=0
                            98 TSM:FAIL:CNT=1
                            114 TSM:FAIL:PDT
                            @dakipro
                            I get the impression that not all radio modules use the same pinouts. You may want to confirm that yours are the same as @Nca78's in that regard.
                              @dakipro
                              @NeverDie is right. Some modules like those from CDEByte are different from the classic SMD modules from AliExpress and must be soldered on the "pa/lna" pinout (the one closest to the edge of the board).
                                Looks as though the PA/LNA part of the silkscreen warning got largely obliterated by the solder pads.
                                • D
                                  dakipro
                                  Must I have a radio cap?
                                  I connected the jumpers now quickly for a test (missed the part that I need them), but still same error
                                  49 TSF:WUR:MS=0
                                  98 TSM:FAIL:CNT=1
                                  114 TSM:FAIL:PDT
                                  10158 TSM:FAIL:RE-INIT
                                  10174 TSM:INIT
                                  10207 !TSM:INIT:TSP FAIL
                                  10240 TSM:FAIL:CNT=2
                                  10256 TSM:FAIL:PDT
                                  Here is the photo of the board (a bit blurry, I can take it again if it helps)
                                  I am missing the radio cap as I was testing lest night without them, but I can solder them in a few hours and test again if you think it will help.
                                  I connect power to the vcc pin of the "connection pins" right?
                                  Radio is the one linked in the BOM from aliexpress
                                  • D
                                    dakipro
                                    I put the radio cap back (4.7uf the largest I have in smd), but still same error :(
                                    • D dakipro
                                      49 TSF:WUR:MS=0
                                      98 TSM:FAIL:CNT=1
                                      114 TSM:FAIL:PDT
                                      10174 TSM:INIT
                                      10256 TSM:FAIL:PDT
                                      #43
                                      @dakipro
                                      Your photo seems to show some hair-like filaments. Don't know if they're conductive, but, if so, maybe they're bridging some of your solder pads? Have you checked with a continuity meter?
                                      • D
                                        dakipro
                                        checked between the pins, no radio pins are touching each other. Those hairs er most likely from the cat, got them cleaned after the photo.
                                        I will try to make one more module in a few days and test.
                                        But to confirm, for the simplest module I need >4.7uF cap, pro mini and the radio, two jumpers (jpower and jrdio) and some mock sketch, and it should all work?
                                        Have I missed some other jumper or resistor or some other component maybe?
                                        • D dakipro
                                          @dakipro no you're not missing anything now.
                                          Cap is not even necessary at the moment don't worry about it.
                                          Problem is connection with radio so you have to make sure :
                                          • VCC and GND pins of radio are correctly connected (seems it's done)
                                          • SPI pins are correctly connected to the radio, check the "connecting the radio" page for the pinout on the pro mini, and radio module pinout. Then check continuity from radio connector to matching pin on radio side, you might have a soldering problem.
