  3. Sensebender Gateway error uploading the sketch
7 Posts 2 Posters 1.9k Views 2 Watching
  • M Offline
    M Offline
    MoeAlmas
    I have a new Sensebender Gateway with a RF69HW , and I am trying to upload the first sketch , and I am getting an error "SAM-BA operation failed" .
    Arduino IDE 1.8.2
    Arduino SAMD Boards 1.6.16
    Mysensors SAMD 1.05
    I have already tried different configuration and always getting the same error , anyone can help me ?
    Sketch uses 34968 bytes (13%) of program storage space. Maximum is 262144 bytes.
    Atmel SMART device 0x10010000 found
    Device : ATSAMD21J18A
    Chip ID : 10010000
    Version : v2.0 [Arduino:XYZ] Jan 10 2017 21:13:45
    Address : 8192
    Pages : 3968
    Page Size : 64 bytes
    Total Size : 248KB
    Planes : 1
    Lock Regions : 16
    Locked : none
    Security : false
    Boot Flash : true
    BOD : true
    BOR : true
    Arduino : FAST_CHIP_ERASE
    Arduino : FAST_MULTI_PAGE_WRITE
    Arduino : CAN_CHECKSUM_MEMORY_BUFFER
    Erase flash
    done in 0.819 seconds
    Write 35308 bytes to flash (552 pages)
    [=== ] 11% (64/552 pages)
    [====== ] 23% (128/552 pages)
    [========== ] 34% (192/552 pages)
    [============= ] 46% (256/552 pages)
    [================= ] 57% (320/552 pages)
    [==================== ] 69% (384/552 pages)
    [======================== ] 81% (448/552 pages)
    [=========================== ] 92% (512/552 pages)
    [==============================] 100% (552/552 pages)
    done in 0.281 seconds
    Verify 35308 bytes of flash with checksum.
    Verify successful
    done in 0.044 seconds
    CPU reset.
    After this error the led D5 (orange) stays ON , and I have to make two reset to have the board available again .
    0_1503765783438_SensebenderGatewaySerial.ino
    • T Offline
      T Offline
      tbowmo
      Have you tried another USB cable?
      What about a simple sketch, blinking LED_BLUE (yes, there is defines for the 5 different LED colors available on the gateway :) )
        pinMode(LED_BLUE, OUTPUT);
        digitalWrite(LED_BLUE, HIGH);
        delay(500);
        digitalWrite(LED_BLUE, LOW);
        delay(500);
      • M Offline
        M Offline
        MoeAlmas
        Hi
        Your example gives the same error , but it loads the sketch , and the sketch runs without problems ... strange for me , this are the messages :
        Sketch uses 9784 bytes (3%) of program storage space. Maximum is 262144 bytes.
        Chip ID : 10010000
        Address : 8192
        Pages : 3968
        Total Size : 248KB
        Planes : 1
        Lock Regions : 16
        Locked : none
        Security : false
        Boot Flash : true
        BOD : true
        BOR : true
        Erase flash
        done in 0.821 seconds
        Write 10040 bytes to flash (157 pages)
        [============ ] 40% (64/157 pages)
        [======================== ] 81% (128/157 pages)
        [==============================] 100% (157/157 pages)
        done in 0.079 seconds
        Verify 10040 bytes of flash with checksum.
        Verify successful
        done in 0.015 seconds
        CPU reset.
        Then I add two simple lines :
        #define MY_GATEWAY_SERIAL
        And the sketch doesn´t load :
        Sketch uses 31152 bytes (11%) of program storage space. Maximum is 262144 bytes.
        Chip ID : 10010000
        Address : 8192
        Pages : 3968
        Total Size : 248KB
        Planes : 1
        Lock Regions : 16
        Locked : none
        Security : false
        Boot Flash : true
        BOD : true
        BOR : true
        Erase flash
        done in 0.822 seconds
        Write 31476 bytes to flash (492 pages)
        [=== ] 13% (64/492 pages)
        [======= ] 26% (128/492 pages)
        [=========== ] 39% (192/492 pages)
        [=============== ] 52% (256/492 pages)
        [=================== ] 65% (320/492 pages)
        [======================= ] 78% (384/492 pages)
        [=========================== ] 91% (448/492 pages)
        [==============================] 100% (492/492 pages)
        done in 0.235 seconds
        Verify 31476 bytes of flash with checksum.
        Verify successful
        done in 0.043 seconds
        CPU reset.
        • T Offline
          T Offline
          tbowmo
          Did you try another USB cable?
          • M Offline
            M Offline
            MoeAlmas
            Yes , 4 different . One doesn't work (the board is not recognized) , the other three give the same result / error .
            • T tbowmo
              M Offline
              M Offline
              MoeAlmas
              @tbowmo Any new idea?
              • M MoeAlmas
                T Offline
                T Offline
                tbowmo
                @MoeAlmas
                I'm out of ideas, other than looking for bad soldering etc.
