  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • korttomaK korttoma
    @Mika what is your experience regarding battery consumption on these?
    LINK
    I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
    Sketch:
    // Define a static node address, remove if you want auto address assignment
    //#define MY_NODE_ID 26                                                          // Kök
    #define MY_NODE_ID 27                                                          // Test device
    #define MY_RADIO_NRF5_ESB
    #define SN "NRF5 Scene"
    #define SV "1.0"
    #define CHILD_ID_SCENE 1
    // PIN for the buttons
    byte buttonOne = 28;
    //Bounce debouncer[NUMBUTTONS];
    int buttonOneoldValue;
    // Pin definitions
    #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
    // Sensor messages
    MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
    // Global settings
    uint16_t SceneOne = 0;
    uint16_t SceneTwo = 1;
    void blinkityBlink(uint8_t repetitions) {
        wait(20);
        wait(100);
        wait(20);
        if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
          wait(500);
     * Setup code
      blinkityBlink(2);  //signify power-up and start of operations
      hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
        /// Make input & enable pull-up resistors on switch pins
      hwPinMode(buttonOne, INPUT_PULLUP);
      buttonOneoldValue = -1;
      sendBattLevel();
    void presentation()  {
      sendSketchInfo(SN, SV);
      //present the scene controller to gateway
      wait(10);
      present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
      wait(10);
     *  Main loop function
      // Check for button activity
      int value = digitalRead(buttonOne);
      if (value != buttonOneoldValue)
          // Send in the new value
          if (value == LOW)
            send(msgOn.set(SceneOne));
            wait(20);
            send(msgOn.set(SceneTwo));
            sendBattLevel();
          buttonOneoldValue = value;
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
     * Parameters
    void sendBattLevel()
        long vcc = hwCPUVoltage();
        // Calculate percentage
        vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
    I noticed that the chip sais:
    N51822
    QFABC0
    1646UU
    QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
    @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
    Is there something wrong with my sketch or is there just an old crappy chip on the device??
    @korttoma said in nRF5 Bluetooth action!:
    LINK
    N51822
    QFABC0
    1646UU
    So I tried your code with a more recent version of the chip and I have a power consumption around 1mA.
    This is not surprising because in fact issue 39 seems to not be completely fixed, if I believe this link:
    https://devzone.nordicsemi.com/f/nordic-q-a/577/current-consumption-when-using-rtc-ppi-and-gpiote#post-id-18533
    "The third revision hardware of the nRF51 has a solution for the GPIOTE OUT tasks, which has very low current consumption (<1uA). The third revision nRF51 hardware will be released in a few days. The third revision hardware still does not have a solution for the GPIOTE IN events, they still consume high current, so for low current applications, use the GPIOTE PORT event instead or the app_button libary."
    From what I see it was never fixed.
    korttomaK Nca78N 2 Replies Last reply
      I'm seeing a special offer for this at 2€ with coupon https://www.aliexpress.com/item/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/32819293925.html
      Should i go ahead?
      NeverDieN O 2 Replies Last reply
        Should i go ahead?
        @gohan Gee, I don't know. Can you really afford $2.55? ;)
          I don't know if it is a good one and I already have a bunch of stuff I bought still in the drawer :sweat_smile:
            @gohan For the price, it's good. I like Fanstel's better, but they have fewer exposed pins and cost more.
            • Nca78N Nca78
              LINK
              N51822
              QFABC0
              1646UU
              korttomaK
              korttomaK
              korttoma
              @nca78 said in nRF5 Bluetooth action!:
              Thanks again for pointing out a possible solution but again I do not know how. I will just have to be patient and wait for someone to post an example of how to use one of the methods you mentioned.
              • Tomas
              Nca78N 1 Reply Last reply
                smilvert
                I have started to test a NRF51822
                and I can upload to it with Arduino IDE but I want to use vim + platformio. And I think i'm quite close :)
                When I ran platformio upload --target upload
                GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-14:56)
                Licensed under GNU GPL v2
                For bug reports, read
                0x4000
                adapter speed: 1000 kHz
                Info : Unable to match requested speed 1000 kHz, using 950 kHz
                Info : clock speed 950 kHz
                Info : using stlink api v2
                Info : Target voltage: 3.225841
                Info : nrf51.cpu: hardware has 4 breakpoints, 2 watchpoints
                Info : Listening on port 3333 for gdb connections
                xPSR: 0xc1000000 pc: 0x000021a4 msp: 0x20004000
                ** Programming Started **
                auto erase enabled
                Warn : Unknown device (HWID 0x000000d1)
                Warn : using fast async flash loader. This is currently supported
                Warn : only with ST-Link and CMSIS-DAP. If you have issues, add
                Warn : "set WORKAREASIZE 0" before sourcing nrf51.cfg/nrf52.cfg to disable it
                target halted due to breakpoint, current mode: Thread
                xPSR: 0x61000000 pc: 0x2000001e msp: 0x20004000
                wrote 33792 bytes from file .pioenvs/nrf51_dk/firmware.hex in 1.594509s (20.696 KiB/s)
                ** Programming Finished **
                ** Verify Started **
                xPSR: 0x61000000 pc: 0x2000002e msp: 0x20004000
                verified 32960 bytes in 0.236646s (136.015 KiB/s)
                ** Verified OK **
                ** Resetting Target **
                shutdown command invoked
                and the output in Arduino IDE looks like:
                Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-09-12:07)
                debug_level: 0
                0x4000
                nrf51.cpu: target state: halted
                xPSR: 0xc1000000 pc: 0x0000251c msp: 0x20004000
                auto erase enabled
                wrote 31744 bytes from file /tmp/arduino_build_390477/Si7021_TemperatureNode_v007_voltage__version_7_board_.ino.hex in 1.500105s (20.665 KiB/s)
                verified 31580 bytes in 0.234860s (131.312 KiB/s)
                ** Verified OK **
                and my platfromio.ini looks like:
                [env:nrf51_dk]
                platform = nordicnrf51
                framework = arduino
                board = nrf51_dk
                upload_protocol = stlink
                Should I modify the nrf51_dk.cfg or can anyone see whats the problem is?
                  What interface do you guys suggest for programming the nrf52832?
                    I'm trying to implement it right now, not really useful for me as I will only have one beacon board for which I will need it, but it's a good occasion to learn. I'll post my results here, but probably next week as I'll have short holidays :)
                    korttomaK 1 Reply Last reply
                    • Nca78N Nca78
                      korttomaK
                      korttomaK
                      korttoma
                      @nca78 :+1: no hurry ;)
                      • Tomas
                        Toyman
                        @gohan you mean programmer? Nothing beats DK with jlink.
                        Other options: jlink EDU, DIY BlackMagicProbe or STLink
                          ok, I bought 2 of the nrf52 at half the price, now what would be the cheap solution among the programmers? Jlink is on the pricy side.
                            @gohan said in nRF5 Bluetooth action!:
                            Cheap jlink clones with 4 wires from AliExpress/Ebay seem to work. So does the ST-Link v2 which is probably the cheapest option.
                              I got kind of lost with all those jlink clones with so many different versions. The ST-Link V2 I found it on digikey and similar sites for around 18/19€, is it the right one?
                              O T 2 Replies Last reply
                                O
                                O
                                Omemanti
                                @gohan I use both the ST-LinkV2 (2 dollars from eBay) and the NRF52832-DK both work like a charm.
                                  Should i go ahead?
                                  O
                                  O
                                  Omemanti
                                  @gohan LOL, i need to stop buying these things, got 12 just waiting to be used.. but at this price, its almost impossible to not buy them :)
                                    Toyman
                                    Don't do that. Either buy $2 clones or invest into DK or:
                                    https://www.adafruit.com/product/3571
                                      Is this one ok? https://www.ebay.it/itm/ST-Link-V2-Programming-Unit-mini-STM8-STM32-Emulator-Downloader-M89/122178354704?hash=item1c7265be10:g:xx4AAOSwm7pZ2Kb-
                                      NRF52832-DK is kind of way over budget :D
                                      O 1 Reply Last reply
                                        O
                                        O
                                        Omemanti
                                        @gohan sure, I bought some of those. Works great. One crashed so now I bought a couple, just to be sure.. :)
                                        • Nca78N Nca78
                                          LINK
                                          N51822
                                          QFABC0
                                          1646UU
                                          Took time but after failure trying to make a version by myself I decided to include app_gpiote library from SDK in my script and it works, it's using around 1uA more than LPCOMP (I measure 5.5 uA with my multimeter) but it can use any pin and in theory any number of pins without increasing power consumption.
                                          The behavior is similar to pin change interrupt on ATMega328, you have one interrupt for all the pins you are watching, so you have to check which pin generated the interrupt but app_gpiote is preparing the work for you.
                                          I have this consumption with a similar script than @Neverdie for LPCOMP: using MySensors with MY_CORE_ONLY, preparing the interrupt then calling the sleep(ms) function from MySensors library, and it works as expected changing status of led immediately when I change status of pin, and waking up at the end of the interval if I don't.
                                          I'll do more tests tomorrow including a full MySensors script, and post the info here. It needs a bunch of files from SDK and adding a (weak) attribute to GPIOTE_IRQHandler() in sandeepmistry's code so it can be overridden in the script.
