  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • korttomaK korttoma
    @nca78 said in nRF5 Bluetooth action!:
    use the GPIOTE PORT event instead or the app_button libary.
    Thanks again for pointing out a possible solution but again I do not know how. I will just have to be patient and wait for someone to post an example of how to use one of the methods you mentioned.
    @korttoma said in nRF5 Bluetooth action!:
    I'm trying to implement it right now, not really useful for me as I will only have one beacon board for which I will need it, but it's a good occasion to learn. I'll post my results here, but probably next week as I'll have short holidays :)
    korttomaK 1 Reply Last reply
    • Nca78N Nca78
      korttomaK
      korttomaK
      korttoma
      @nca78 :+1: no hurry ;)
      • Tomas
        What interface do you guys suggest for programming the nrf52832?
        Toyman
        @gohan you mean programmer? Nothing beats DK with jlink.
        Other options: jlink EDU, DIY BlackMagicProbe or STLink
          ok, I bought 2 of the nrf52 at half the price, now what would be the cheap solution among the programmers? Jlink is on the pricy side.
          Nca78N 1 Reply Last reply
            @gohan said in nRF5 Bluetooth action!:
            Cheap jlink clones with 4 wires from AliExpress/Ebay seem to work. So does the ST-Link v2 which is probably the cheapest option.
              I got kind of lost with all those jlink clones with so many different versions. The ST-Link V2 I found it on digikey and similar sites for around 18/19€, is it the right one?
              O T 2 Replies Last reply
                O
                O
                Omemanti
                @gohan I use both the ST-LinkV2 (2 dollars from eBay) and the NRF52832-DK both work like a charm.
                  I'm seeing a special offer for this at 2€ with coupon https://www.aliexpress.com/item/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/32819293925.html
                  Should i go ahead?
                  O
                  O
                  Omemanti
                  @gohan LOL, i need to stop buying these things, got 12 just waiting to be used.. but at this price, its almost impossible to not buy them :)
                    Toyman
                    Don't do that. Either buy $2 clones or invest into DK or:
                    https://www.adafruit.com/product/3571
                      Is this one ok? https://www.ebay.it/itm/ST-Link-V2-Programming-Unit-mini-STM8-STM32-Emulator-Downloader-M89/122178354704?hash=item1c7265be10:g:xx4AAOSwm7pZ2Kb-
                      NRF52832-DK is kind of way over budget :D
                      O 1 Reply Last reply
                        O
                        O
                        Omemanti
                        @gohan sure, I bought some of those. Works great. One crashed so now I bought a couple, just to be sure.. :)
                        • Nca78N Nca78
                          @Mika what is your experience regarding battery consumption on these?
                          LINK
                          I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
                          I noticed that the chip sais:
                          N51822
                          QFABC0
                          1646UU
                          QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
                          @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
                          Is there something wrong with my sketch or is there just an old crappy chip on the device??
                          So I tried your code with a more recent version of the chip and I have a power consumption around 1mA.
                          This is not surprising because in fact issue 39 seems to not be completely fixed, if I believe this link:
                          https://devzone.nordicsemi.com/f/nordic-q-a/577/current-consumption-when-using-rtc-ppi-and-gpiote#post-id-18533
                          "The third revision hardware of the nRF51 has a solution for the GPIOTE OUT tasks, which has very low current consumption (<1uA). The third revision nRF51 hardware will be released in a few days. The third revision hardware still does not have a solution for the GPIOTE IN events, they still consume high current, so for low current applications, use the GPIOTE PORT event instead or the app_button libary."
                          From what I see it was never fixed.
                          Took time but after failure trying to make a version by myself I decided to include app_gpiote library from SDK in my script and it works, it's using around 1uA more than LPCOMP (I measure 5.5 uA with my multimeter) but it can use any pin and in theory any number of pins without increasing power consumption.
                          The behavior is similar to pin change interrupt on ATMega328, you have one interrupt for all the pins you are watching, so you have to check which pin generated the interrupt but app_gpiote is preparing the work for you.
                          I have this consumption with a similar script than @Neverdie for LPCOMP: using MySensors with MY_CORE_ONLY, preparing the interrupt then calling the sleep(ms) function from MySensors library, and it works as expected changing status of led immediately when I change status of pin, and waking up at the end of the interval if I don't.
                          I'll do more tests tomorrow including a full MySensors script, and post the info here. It needs a bunch of files from SDK and adding a (weak) attribute to GPIOTE_IRQHandler() in sandeepmistry's code so it can be overridden in the script.
                          • O Omemanti
                            @omemanti said in nRF5 Bluetooth action!:
                            Do you use them with windows?
                            I tried to get them to program an nrf52832, but openocd in Arduino ide under windows doesn't detect them...
                            Both stlinks work in Linux.
                            mfalkviddM O 2 Replies Last reply
                            • YveauxY Yveaux
                              @yveaux I have used a ST-Link v2 (clone) on Windows 7, didn't run into any problems.
                                @mfalkvidd from the arduino ide? Did you follow any guide or remember specific settings?
                                • YveauxY Yveaux
                                  @yveaux yes from the Arduino IDE. I just followed this guide.
                                  • mfalkviddM
                                    I did follow https://github.com/sandeepmistry/arduino-BLEPeripheral as well (for a non-MySensors use case). Not sure which one I did first.
                                      #1508
                                      @mfalkvidd hmmm... No specific mention of any st-link stuff to configure. Must be me then :scream:
                                      I just wanted to try some ST-links I ordered.
                                      Ah well, I'll give it another try and otherwise go back to my j-link, which works flawlessly.
                                      Thanks anyway!
                                      • YveauxY Yveaux
                                        O
                                        O
                                        Omemanti
                                        wrote on last edited by Omemanti
                                        #1509
                                        @yveaux jup, both work on Windows . I had to install the right drivers using zadig.
                                        I only use the Arduino IDE for uploading, just select the st-link and it works.
                                        YveauxY 2 Replies Last reply
                                        • O Omemanti
                                          @omemanti ok, thanks for the feedback. I'll give that a try then :+1:
