  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • Nca78N Nca78
    @omemanti said in nRF5 Bluetooth action!:
    @neverdie said in nRF5 Bluetooth action!:
    , that makes sense. That's why on my PCB's I have the antenna portion of the module hanging over the edge of the PCB into e
    yeah, next one will be a big hole in the middle, lets see how that will work out..
    Interesting board !
    But module in the middle is a bad idea, even with a big hole below the antenna it will affect performance to still have some PCB around
    For example here is an extract of the Fanstel BT832 module datasheet. It's not the same antenna design but it show having the antenna sticking out is the best solution, else you should but as close as possible to the edge and of course keep ground plane and traces as far as possible.
    O
    O
    Omemanti
    wrote on last edited by Omemanti
    #1594
    @nca78 I'm trying to create a node that fits inside a standard wallsocket. (I'll post it when it's done) it got a motion and moisture sensor.
    For the next version I'm moving the module more to the outside but I need to take the screwholes into account.
    The groundplane I used filled the entire PCB, next one will have less ground around the antenna or even holes.
    It's designed to hold 3 AA batteries to have a couple years of service.
    But cutting away that spot around the antenna gave me reception throughout the entire house
    • alowhumA alowhum
      @Nca78 Thanks, but it didn't work either :-(
      Some notes from my adventures with the eByte module:
      I've been playing with OpenOCD and the ST-Link v2. The ST-Link V2 that I turned into a Black Magic Probe doesn't see the modules.
      I went into the Arduino's folder that has OpenOCD, created .cfg file, and then:
      ./openocd -d2 -f nrf52832.cfg
      This started the OpenOCD server. Then I opened another terminal window and did
      telnet localhost 4444
      Now I could manually issue some OpenOCD commands. The goal was to do a manual mass erase.
      Some OpenOCD commands and their output:
      flash probe 0        c Unknown device (HWID 0x00000000)
      > flash banks
      #0 : nrf52.flash (nrf51) at 0x00000000, size 0x00000000, buswidth 1, chipwidth 1
      #1 : nrf52.uicr (nrf51) at 0x10001000, size 0x00000000, buswidth 1, chipwidth 1
      > flash probe 1
      flash 'nrf51' found at 0x10001000
      > nrf51 mass_erase 0
      Target not halted
      This command actually resulted in OpenOCD ballooning to 8Gb in ram. Then after 5 minutes of seemingly being busy, I got the 'target not halted' command.
      > flash info 1
      #1 : nrf51 at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
      	#  0: 0x00000000 (0x100 0kB) not protected
      Target not halted
      error retrieving flash info
      Here is says "target not protected".
      > nrf52.cpu curstate
      reset
      Weird: the processor says it is in reset state? Could it be that it is not so much protected, but that it is constantly being reset? But then why is this with all the chips?
      Once the OpenOCD server is running I also tried getting into the chip with
      telnet localhost 3333
      But then I get "Error: attempted 'gdb' connection rejected"
      The OpenOCD documentation mentions the chip protection:
      Flash Driver: nrf5
      All members of the nRF51 microcontroller families from Nordic Semiconductor include internal flash and use ARM Cortex-M0 core. Also, the nRF52832 microcontroller from Nordic Semiconductor, which include internal flash and use an ARM Cortex-M4F core.
      flash bank $_FLASHNAME nrf5 0 0x00000000 0 0 $_TARGETNAME
      Some nrf5-specific commands are defined:
      Command: nrf5 mass_erase
      Erases the contents of the code memory and user information configuration registers as well. It must be noted that this command works only for chips that do not have factory pre-programmed region 0 code.
      http://www.openocd.org/doc/html/Flash-Commands.html
      I also got out my voltmeter. Pin 21 and pin 25 have 3v on them, the rest don't.
      maciekczwa
      wrote on last edited by maciekczwa
      #1595
      @alowhum
      Hi I managed to clear the access protection.
      I connected ebyte module directly to raspberry pi.
      I used this guide http://hivetool.org/w/index.php?title=BMD301 with little modifications
      Compiled openocd - current version - 7b94ae9e520877e7f2341b48b3bd0c0d1ca8a14b
      Added chip definition - I don't know if it is needed, I can check that - I have more modules to unlock
      diff --git a/src/flash/nor/nrf5.c b/src/flash/nor/nrf5.c
      index 31dd5aae..e01d7ddf 100644
      --- a/src/flash/nor/nrf5.c
      +++ b/src/flash/nor/nrf5.c
      @@ -204,6 +204,7 @@ static const struct nrf5_device_spec nrf5_known_devices_table[] = {
       	/* nRF52832 Devices */
       	NRF5_DEVICE_DEF(0x00C7, "52832", "QFAA", "B0",    512),
      +	NRF5_DEVICE_DEF(0x00C7, "52832", "QFN48", "B00",    512),
       static int nrf5_bank_is_probed(struct flash_bank *bank)
      Started openocd:
      openocd -f interface/raspberrypi-native.cfg -c "transport select swd; set WORKAREASIZE 0" -f target/nrf52.cfg
      Connected with telnet to port 4444
      Commands:
      nrf52.dap apreg 1 0x0c
      nrf52.dap apreg 1 0x04 0x01
      reset
      I tried also with st-link but I think it doesn't support dap commands? Can anyone confirm that?
      After clearing access protection I am able to successfully flash chip with st-link.
      Now it shows in logs:
      Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
      Before it was:
      Good luck with unlocking your modules:)
      • alowhumA
        alowhumA
        alowhum
        @maciekczwa said in nRF5 Bluetooth action!:
        Thanks for the tip! Unfortunately ST-Link V2 gives:
        invalid command name "nrf52.dap"
        (same with just "dap", which I had tried earlier).
        • O Omemanti
          @omemanti That PIR sensor lens sure has a small footprint. I'll be interested to hear how well it performs and whether you like it or not.
          O 1 Reply Last reply
            O
            O
            Omemanti
            #1598
            @neverdie it's the AM612, and in the little tests I did so far, it did great.
            • alowhumA
              alowhumA
              alowhum
              @maciekczwa If you could share a guide to unlocking these devices, I would be very grateful. I'm have a bit of trouble still. I create an JLink device form an STM32. But even that gives the same general error on all my modules.
              nrfjprog --recover
              ERROR: JLinkARM DLL reported an error. Try again. If error condition
              ERROR: persists, run the same command again with argument --log, contact Nordic
              ERROR: Semiconductor and provide the generated log.log file to them.
              I tried lots of DLL versions, and a new version of nrfjprog.. no luck.
              nrfjprog --recover --log
              nrfjprog verion 9.7.0
              FUNCTION: open_dll.
              FUNCTION: open_dll.
              FUNCTION: enum_emu_snr.
              FUNCTION: connect_to_emu_with_snr.
              FUNCTION: connect_to_emu_without_snr.
              Device "NRF52832_XXAA" selected.
              FUNCTION: read_connected_emu_snr.
              FUNCTION: read_device_family.
              JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1.
              JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
              FUNCTION: close_dll.
              • T Toyman
                @alowhum I intentionally asked you because I know the problem exists.
                You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
                Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
                Mars WarriorM
                Mars WarriorM
                Mars Warrior
                @alowhum, you seem to need Jlink Commander:
                @toyman said in nRF5 Bluetooth action!:
                Furthermore, It would be nice to have a small step-by-step guide to unlock and then program the ebyte module.
                @Omemanti and @NeverDie are using these modules, so should be able to write something up that works for other ppl ;-)
                (My ebyte modules are still on their way)
                O NeverDieN 2 Replies Last reply
                • Mars WarriorM Mars Warrior
                  O
                  O
                  Omemanti
                  #1601
                  @mars-warrior @alowhum
                  For uploading code onto the Ebyte modules I use an ST-Link V2 (2 dollar USB modules).
                  • Install the USB-Driver using Zadig
                  • Connect the DIO, CLK VCC, and GND.
                    For testing purposes, I soldered just the tips of some Dupont cables to the Ebyte module and put the female parts on the ST-link.
                  • The first time I want to upload code, I first "burn the bootloader" (Tools => burn Bootloader) (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/386)
                    This will give an error.
                    After that, you should be able to upload sketches.
                  Nca78N 1 Reply Last reply
                  • O Omemanti
                    That's what I suggested earlier but it seems it didn't work. But I don't remember if it was with an stlink.
                    • O
                      O
                      Omemanti
                      #1603
                      @alowhum
                      maybe a very stupid question, but did you check all the wires and after that if your computer uses the right drivers.
                      I took me quite a while to figure this out myself. Especially the driver part messes things up. Errors everywhere that referred to different problems, but after I used Zadig they all disappeared.
                        #1604
                        @mars-warrior said in nRF5 Bluetooth action!:
                        As I've said many times previoiusly, I use the nRF52 DK to program external modules, and it's what I recommend for noobs because it's relatively hassle free. If you're able to use the $2 st-link v2 programmer then great, my hat's off to you. If not, I recommend the nRF52 DK rather than get frustrated and give up.
                        alowhumA 1 Reply Last reply
                          alowhumA
                          alowhumA
                          alowhum
                          nRF52 DK
                          Which hardware programmer do you use with that?
                          I find many of these software packages, like Segger's JLink stuff, are made for Windows (I'm on a mac).
                          gohanG O 2 Replies Last reply
                          • alowhumA alowhum
                            nRF52 DK
                            @alowhum you can still install windows on it :sweat_smile:
                            • alowhumA alowhum
                              nRF52 DK
                              O
                              O
                              Omemanti
                              @alowhum by programmer you mean in something like the Arduino ide? That's what I use ( I both use the nrf52dk =>j-link aswell the st-link v2 => st-link)
                              • alowhumA
                                alowhumA
                                alowhum
                                #1608
                                @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
                                On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
                                • alowhumA alowhum
                                  O
                                  O
                                  Omemanti
                                  @alowhum said in nRF5 Bluetooth action!:
                                  The nrf52 dev kit= > NRF52 Dev kit
                                  To connect the DK to a module :
                                  DK Ebyte module
                                  GND(detect) => GND
                                  SWDIO => SWDIO
                                  SWDCLK => SWCLK
                                  VTG => 3,3V
                                  3,3V => 3,3V
                                  GND =>GND
                                  select J-link and there you go.
                                  I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
                                  the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
                                  Indeed!
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    JLinkExe gives me this:
                                    WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
                                    I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
                                    • alowhumA alowhum
                                      O
                                      O
                                      Omemanti
                                      #1611
                                      @alowhum
                                      Hey, sorry, I'm not familiar with your error messages.
                                      Can you please sum everything up what you did so far and what your setup looks like (pic)
                                      • Drivers
                                      • Libraries
                                      • what software you use
                                      • Number of modules you tested
                                      • etc
                                      just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
                                      • Nca78N
                                        wrote on last edited by Nca78
                                        #1612
                                        For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
                                        https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
                                        [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
                                        https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                                          #1613
                                          Looks as though there is also a new DK for the nRF52840 as well:
                                          https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                                          just not in stock.
                                          Looks like HolyIOT is ahead of the curve on this chip.
                                          JokgiJ 1 Reply Last reply
