  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    @omemanti That PIR sensor lens sure has a small footprint. I'll be interested to hear how well it performs and whether you like it or not.
    O
    O
    Omemanti
    wrote on last edited by Omemanti
    #1598
    @neverdie it's the AM612, and in the little tests I did so far, it did great.
    • alowhumA
      alowhumA
      alowhum
      @maciekczwa If you could share a guide to unlocking these devices, I would be very grateful. I'm have a bit of trouble still. I create an JLink device form an STM32. But even that gives the same general error on all my modules.
      nrfjprog --recover
      ERROR: JLinkARM DLL reported an error. Try again. If error condition
      ERROR: persists, run the same command again with argument --log, contact Nordic
      ERROR: Semiconductor and provide the generated log.log file to them.
      I tried lots of DLL versions, and a new version of nrfjprog.. no luck.
      nrfjprog --recover --log
      nrfjprog verion 9.7.0
      FUNCTION: open_dll.
      FUNCTION: open_dll.
      FUNCTION: enum_emu_snr.
      FUNCTION: connect_to_emu_with_snr.
      FUNCTION: connect_to_emu_without_snr.
      Device "NRF52832_XXAA" selected.
      FUNCTION: read_connected_emu_snr.
      FUNCTION: read_device_family.
      JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1.
      JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
      FUNCTION: close_dll.
      • T Toyman
        @alowhum I intentionally asked you because I know the problem exists.
        You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
        Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
        Mars WarriorM
        Mars WarriorM
        Mars Warrior
        @alowhum, you seem to need Jlink Commander:
        @toyman said in nRF5 Bluetooth action!:
        Furthermore, It would be nice to have a small step-by-step guide to unlock and then program the ebyte module.
        @Omemanti and @NeverDie are using these modules, so should be able to write something up that works for other ppl ;-)
        (My ebyte modules are still on their way)
        O NeverDieN 2 Replies Last reply
        • Mars WarriorM Mars Warrior
          O
          O
          Omemanti
          #1601
          @mars-warrior @alowhum
          For uploading code onto the Ebyte modules I use an ST-Link V2 (2 dollar USB modules).
          • Install the USB-Driver using Zadig
          • Connect the DIO, CLK VCC, and GND.
            For testing purposes, I soldered just the tips of some Dupont cables to the Ebyte module and put the female parts on the ST-link.
          • The first time I want to upload code, I first "burn the bootloader" (Tools => burn Bootloader) (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/386)
            This will give an error.
            After that, you should be able to upload sketches.
          Nca78N 1 Reply Last reply
          • O Omemanti
            @omemanti said in nRF5 Bluetooth action!:
            That's what I suggested earlier but it seems it didn't work. But I don't remember if it was with an stlink.
            • O
              O
              Omemanti
              #1603
              @alowhum
              maybe a very stupid question, but did you check all the wires and after that if your computer uses the right drivers.
              I took me quite a while to figure this out myself. Especially the driver part messes things up. Errors everywhere that referred to different problems, but after I used Zadig they all disappeared.
                #1604
                @mars-warrior said in nRF5 Bluetooth action!:
                As I've said many times previoiusly, I use the nRF52 DK to program external modules, and it's what I recommend for noobs because it's relatively hassle free. If you're able to use the $2 st-link v2 programmer then great, my hat's off to you. If not, I recommend the nRF52 DK rather than get frustrated and give up.
                alowhumA 1 Reply Last reply
                  alowhumA
                  alowhumA
                  alowhum
                  @neverdie said in nRF5 Bluetooth action!:
                  nRF52 DK
                  Which hardware programmer do you use with that?
                  I find many of these software packages, like Segger's JLink stuff, are made for Windows (I'm on a mac).
                  gohanG O 2 Replies Last reply
                  • alowhumA alowhum
                    nRF52 DK
                    @alowhum you can still install windows on it :sweat_smile:
                    • alowhumA alowhum
                      nRF52 DK
                      O
                      O
                      Omemanti
                      @alowhum by programmer you mean in something like the Arduino ide? That's what I use ( I both use the nrf52dk =>j-link aswell the st-link v2 => st-link)
                      • alowhumA
                        alowhumA
                        alowhum
                        #1608
                        @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
                        On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
                        O 1 Reply Last reply
                        • alowhumA alowhum
                          O
                          O
                          Omemanti
                          @alowhum said in nRF5 Bluetooth action!:
                          The nrf52 dev kit= > NRF52 Dev kit
                          To connect the DK to a module :
                          DK Ebyte module
                          GND(detect) => GND
                          SWDIO => SWDIO
                          SWDCLK => SWCLK
                          VTG => 3,3V
                          3,3V => 3,3V
                          GND =>GND
                          select J-link and there you go.
                          I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
                          the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
                          Indeed!
                          • alowhumA
                            alowhumA
                            alowhum
                            JLinkExe gives me this:
                            WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
                            I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
                            • alowhumA alowhum
                              O
                              O
                              Omemanti
                              #1611
                              @alowhum
                              Hey, sorry, I'm not familiar with your error messages.
                              Can you please sum everything up what you did so far and what your setup looks like (pic)
                              • Drivers
                              • Libraries
                              • what software you use
                              • Number of modules you tested
                              • etc
                              just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
                              • Nca78N
                                wrote on last edited by Nca78
                                #1612
                                For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
                                https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
                                [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
                                https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                                  #1613
                                  Looks as though there is also a new DK for the nRF52840 as well:
                                  https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                                  just not in stock.
                                  Looks like HolyIOT is ahead of the curve on this chip.
                                  JokgiJ 1 Reply Last reply
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    @nca78 said in nRF5 Bluetooth action!:
                                    Cool!
                                    • alowhumA alowhum
                                      Cool!
                                      Cool!
                                      If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
                                      • Nca78N Nca78
                                        Cool!
                                        Toyman
                                        @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
                                        • T Toyman
                                          alowhumA
                                          alowhumA
                                          alowhum
                                          I was wondering the exact same thing!
