  3. nrf24 : transmission of data works fine, but constant NACK's produced
19 Posts 6 Posters 3.8k Views 6 Watching
  • I itbeyond
    @rzylius thanks for that testing - it follows almost exactly the same problems I have seen since the release of 2.3.0 and is the reason I do not use 2.3.0 anymore and have reverted my entire network to 2.2.0. Sorry @mfalkvidd this is another example of the same 2.3.0 problems, I feel I am looking like a problem to the community but I did extensive testing on 2.3.0 - made posts in the release page - received nothing in reply and it seems the errors are continuing. The above logs are very similar in aspect to the testing I did so not sure what other logs you may need but I am happy to try to help if there is something I can do, but it is hard to diagnose anything when the radio network just starts NACK'ing and then eventually the node stops working?
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    @itbeyond @rzylius are you using nrf24l01+ with pa + lna?
    Can you test if the problems still persist using this version: https://github.com/tekka007/MySensors/tree/RF24Test
    I 3 Replies Last reply
    • tekkaT tekka
      I
      I
      itbeyond
      @tekka have downloaded and will look at this and report shortly. Yes most of my Gateway & Repeater nodes are nrf24l01+ with pa + lna but I have also been using and seen the problem with E01-ML01DP5 but I think this is the same underlying technology.
      • tekkaT tekka
        I
        I
        itbeyond
        @tekka Loaded onto my MEGA based Ethernet gateway connected to openHab using a E01-ML01DP5 with 9db antenna - this previously lasted less than 6 hours. Will advise as testing goes ahead. I do not send much with this unit more receive but have some test nodes I will code to toggle back and forth - I am unable to add my signed nodes to this as yet!
        I will also grab my MEGA based repeater on a different network and see what happens this is a nrf24l01+ with pa + lna.
        • tekkaT tekka
          I
          I
          itbeyond
          @tekka I think you have solved it - I had a look at the code changes you made removing the 10ms pulse and wonder how it could be but without reading the rest of the code and understanding the specs of the card I am only guessing. So can this version of the code still work well with the regular nrf24 modules or will this pulse adjustment have a different impact on them? At present i have only loaded this on the 2 nodes I have mentioned. Will this modification be released as a point release update to the community as something like 2.3.1 or how will this be migrated to a stable release?
          Great work by the way and thanks for fixing it.
          YveauxY mfalkviddM 2 Replies Last reply
          • I itbeyond
            @itbeyond the CE pulse is apparently used by amplified nrf24 radios to enable the lna receiver. This is not an issue when only sending, but for hardware acks the lna receiver should be enabled until the transmitted message has been acknowledged by the receiving node.
            Shortening the CE pulse, and thereby disabling reception causes nacks to occur...
            I 1 Reply Last reply
            • YveauxY Yveaux
              I
              I
              itbeyond
              wrote on last edited by itbeyond
              @yveaux The comment above the section indicates that TX starts after 10us, and setting CE high also enables PA+LNA mode - so I wonder why would we be trying to set it low after 10us - seems like a conflicting set of statements. Then the statement datasheet: Pulse CE at least 10us - it is confusing - Does this mean for at least 10us or after 10us and should the pulse be a set of LOW then HIGH > 10us. If I read these statements without the datasheet I would be holding it UP for at least 10us then pulse it quickly LOW/HIGH until the status updates as we need to be high to enable the PA+LNA mode. Anyway I am only looking at a very small part of the code and reading peoples comments. I would need more time to cross check the datasheet. But the removal of the 10us set it LOW is still working.
              • I itbeyond
                @itbeyond to me the datasheet is clear and the mySensors implementation was changed to match the Nordic reference implementation.
                However, as said that doesn't accommodate for non-Nordic, undocumented pa+lna modules.
                Guess we found out the hard way...
                • I itbeyond
                  @itbeyond yes that's generally how the MySensors releases work
                  • sundberg84S
                    sundberg84S
                    Will 2.3 release be updated with this update? @tekka ?
                    tekkaT 1 Reply Last reply
                    • sundberg84S sundberg84
                      tekkaT
                      tekkaT
                      tekka
                      @sundberg84 Yes, the patch will be included in 2.3.1.
