  3. Advice for Newbie trying to get started
5 Posts 4 Posters 1.4k Views 4 Watching
  • G Offline
    G Offline
    grumpazoid
    Hello
    I have got a few components on order for my first project based on nrf24l01+. I want to build some PIR sensors and be alerted when movement occurs.
    I am a total newbie to arduino and home automation but have some experience with the raspberry pi.
    I have just installed openHAB on a pi to test it. I am thinking I have a huge mountain to climb!
    Should I maybe start with Domoticz. From what I have seen, it could be simpler in the first instance.
    I am also struggling on which gateway to build. I can't find a definitive answer on what the benefits of serial/ethernet/mqtt offer.
    Maybe start with serial as I can just plug it into the pi via usb?? What will mqtt do for me that a serial interface doesn't.
    Raspberry Pi 3B - Domoticz + Node Red
    Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
    Arduino Mega, RFLink 433Mhz
    Sonoff/ESP8266/Tasmota switches
    • O Offline
      O Offline
      Omemanti
      wrote on last edited by Omemanti
      Hey, Welcome,
      If you just want to get started, prepare for some trial and error (that's almost half the fun if you ask me :)).
      I suggest you start with a serial monitor and use myscontroller as a controller.
      If you ask me this is the easiest way to test if everything is working.
      when you are confident on your progress, hook up a wifi gateway and link that to whatever you like (I only have experiences with domotics + dachticz in combination with a wifi-gateway ( ESP8266+NRF52832))
      • G Offline
        G Offline
        grumpazoid
        Thanks Omemanti
        I will check out myscontroller...looks useful.
        Ive been playing with openHAB today, and after a bit of a struggle, I've managed to create a virtual switch that sends me an email. This gives me hope that a mysensors PIR node will be able to do the same.
        Certainly a great way to learn about many new things!
        • MGHaffM Offline
          MGHaffM Offline
          MGHaff
          I started with Domoticz and my sensors. Now I have half my house controlled and monitored by Domoticz. A LOT OF TRIAL AND ERROR! But my god thanks to everyone that has the same passions as I do!!!
          • TmasterT Offline
            TmasterT Offline
            Tmaster
            wrote on last edited by Tmaster
            My advise if you want upgrade and improve your domotics in your house is what i done. Domoticz,serial gateway, rfm69h and rfm69hw instead of nrf24 that i used before and replace all cards. Nrf24 have many range problems for me and the the chinise clone that are unknown quality in each order.all diferents each time i order...
            i'm a arduino fan .Even sometimes don't undestanding how to use it :P
